Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » xml to ecore
xml to ecore [message #48896] Wed, 06 September 2006 18:41 Go to next message
Originally posted by: rahil.shah.yahoo.com
I hav ean emf model tht was defined using UML diagram. I used to store
those files in the database.
I now have the part of xml file tht is get as a search result on xml
files. I want to map this back to ecore ..
Can anyone please help me in how to go about doin this??
Thank You
Rahil
Re: xml to ecore [message #48927 is a reply to message #48896] Thu, 07 September 2006 02:19 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Rahil,
Unfortunately I can't understand the exact nature of your issue.
Did you say that you store models in a database?
Which technology do you use to do so?
Cheers
/Eike
> Thank You
> Rahil
Re: xml to ecore [message #49024 is a reply to message #48896] Thu, 07 September 2006 08:59 Go to previous message
Rahil,
You can use Resource.load(InputStream, Map) to load directly from any
stream. You could also use XMLResource.load(Node, ...) or
XMLResource.load(InputSource,...).
> Thank You
> Rahil
Re: xml to ecore [message #590353 is a reply to message #48896] Thu, 07 September 2006 02:19 Go to previous message
Rahil,
Cheers
/Eike
> Thank You
> Rahil
Re: xml to ecore [message #590391 is a reply to message #48896] Thu, 07 September 2006 08:59 Go to previous message
Rahil,
> Thank You
> Rahil
Previous Topic:OCL compilation
Next Topic:How to implement constraint for group of objects?
Current Time: Sat Oct 25 03:27:36 EDT 2025
Powered by FUDForum. Page generated in 0.05127 seconds
