Re: Task and Problem Toolbars Missing [message #481925 is a reply to message #481861] |
Mon, 24 August 2009 18:07 |
Harry wrote:
> Eclipse Package for PHP - pdt-all-in-one-win32-2.0.1.zip
> Eclipse Version: 3.4.2
> Build id: M20090211-1700
> I am new to Eclipse and have searched the newsgroups and on-line and
> have not seen a solution to this problem. In the PHP version I do not
> see the toolbars for Tasks or Problems and I have so far not seen where
> to turn these on if that is an option. I have older versions of Eclipse
> and the toolbars are there and I downloaded the Java version and they
> are there.
> Is the package missing files, can I copy them from the Java version or
> am missing some obvious and easy solution?
> Thanks for your help in advance
I believe you're referring to Views, in which case the "Window"
menu's "Show View..." submenu should contain them.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.02965 seconds
