Home » Language IDEs » C / C++ IDE (CDT) » Memory and register changing
Memory and register changing [message #48866] Tue, 05 November 2002 06:08 Go to next message
Hi all!
I downloaded new CDT packages from CVS in order to use new Memory and
Registers view. But I didn't manage to change memory from Memory View(I
just didn't find how to do it) and I didn't manage to change register
values: after I've changed a value of some register(using right mouse
click) an old one appeared again.
May be someone prompt what's the problem is?
Igor S. Zamyatin
Interstron Ltd.
Re: Memory and register changing [message #48925 is a reply to message #48866] Tue, 05 November 2002 11:23 Go to previous messageGo to next message
Originally posted by: mikhailk.qnx.com
The problem with registers is a bug. I have submitted a bug for it (25730).
To change memory you have to type the values and then press the 'Save
changes' button.
This works only for hexadecimal format.
Mikhail Khodjaiants
"Igor S. Zamyatin" <isz@interstron.ru> wrote in message
news:aq88ql$o9u$1@rogue.oti.com...
> Hi all!
> Igor S. Zamyatin
> Interstron Ltd.
Re: Memory and register changing [message #48953 is a reply to message #48925] Tue, 05 November 2002 11:36 Go to previous messageGo to next message
"Mikhail Khodjaiants" <mikhailk@qnx.com> wrote in message
news:aq8pag$2k9$1@rogue.oti.com...
(25730).
Fixed.
> changes' button.
> Mikhail Khodjaiants
> > Hi all!
> > Thanks,
> > Igor S. Zamyatin
> > Interstron Ltd.
Re: Memory and register changing [message #49001 is a reply to message #48925] Wed, 06 November 2002 01:54 Go to previous messageGo to next message
> changes' button.
Could you please specify more exactly what should I put into "Address"
memo in Memory View before pressing "Save changes" button because I'm
typing "0x0 5", then pressing that button and nothing happenning.
And another one. I've noticed that when I want to look at register
values Debugger had posted to gdb following commands
29-data-list-register-values x 0
30-data-list-register-values x 0
31-data-list-register-values x 0
32-data-list-register-values x 1
33-data-list-register-values x 1
34-data-list-register-values x 1
35-data-list-register-values x 2
36-data-list-register-values x 2
37-data-list-register-values x 2
38-data-list-register-values x 3
39-data-list-register-values x 3
40-data-list-register-values x 3
41-data-list-register-values x 4
42-data-list-register-values x 4
43-data-list-register-values x 4
44-data-list-register-values x 5
45-data-list-register-values x 5
46-data-list-register-values x 5
47-data-list-register-values x 6
48-data-list-register-values x 6
49-data-list-register-values x 6
50-data-list-register-values x 7
51-data-list-register-values x 7
52-data-list-register-values x 7
53-data-list-register-values x 8
54-data-list-register-values x 8
55-data-list-register-values x 8
56-data-list-register-values x 9
57-data-list-register-values x 9
58-data-list-register-values x 9
59-data-list-register-values x 10
60-data-list-register-values x 10
61-data-list-register-values x 10
62-data-list-register-values x 11
63-data-list-register-values x 11
64-data-list-register-values x 11
65-data-list-register-values x 12
66-data-list-register-values x 12
67-data-list-register-values x 12
68-data-list-register-values x 13
69-data-list-register-values x 13
70-data-list-register-values x 13
71-data-list-register-values x 14
72-data-list-register-values x 14
73-data-list-register-values x 14
74-data-list-register-values x 15
75-data-list-register-values x 15
76-data-list-register-values x 15
77-data-list-register-values x 16
78-data-list-register-values x 16
79-data-list-register-values x 16
80-data-list-register-values x 17
81-data-list-register-values x 17
82-data-list-register-values x 17
83-data-list-register-values x 18
84-data-list-register-values x 18
85-data-list-register-values x 18
86-data-list-register-values x 19
87-data-list-register-values x 19
88-data-list-register-values x 19
89-data-list-register-values x 20
90-data-list-register-values x 20
91-data-list-register-values x 20
92-data-list-register-values x 21
93-data-list-register-values x 21
94-data-list-register-values x 21
95-data-list-register-values x 22
96-data-list-register-values x 22
97-data-list-register-values x 22
98-data-list-register-values x 23
99-data-list-register-values x 23
100-data-list-register-values x 23
101-data-list-register-values x 24
102-data-list-register-values x 24
103-data-list-register-values x 24
104-data-list-register-values x 25
105-data-list-register-values x 25
106-data-list-register-values x 25
107-data-list-register-values x 26
108-data-list-register-values x 26
109-data-list-register-values x 26
110-data-list-register-values x 27
111-data-list-register-values x 27
112-data-list-register-values x 27
113-data-list-register-values x 28
114-data-list-register-values x 28
115-data-list-register-values x 28
116-data-list-register-values x 29
117-data-list-register-values x 29
118-data-list-register-values x 29
119-data-list-register-values x 30
120-data-list-register-values x 30
121-data-list-register-values x 30
122-data-list-register-values x 31
123-data-list-register-values x 31
124-data-list-register-values x 31
Is it important to post 3 equal commands?
Igor S. Zamyatin
> Mikhail Khodjaiants
> > Hi all!
> > Thanks,
> > Igor S. Zamyatin
> > Interstron Ltd.
Re: Memory and register changing [message #49062 is a reply to message #49001] Wed, 06 November 2002 10:40 Go to previous message
news:aqaeaj$s8l$1@rogue.oti.com...
(25730).
> > changes' button.
To view a memory block you have to an expression into 'Address' field and
press Enter. It could a direct address or a correct 'C/C++' expression. For
example, '&x' where 'x' is a local variable in the current context. The size
of block is hardcoded for now but it will probably be added to the
preferences of the Memory view.
As soon as have a memory block in your view you can change the format, unit
size and number of columns and switch on/off the ascii presentation.
The 'Refresh' button updates the memory block. If you want the memory block
to be automatically updated at every step of your debug session switch on
the 'Auto-Refresh' button.
To modify your memory block just type the values and press the 'Save
Changes' button.
I will look at it.
> Thanks
> Igor S. Zamyatin
Thank you,
Mikhail Khodjaiants
> > Mikhail Khodjaiants
> > > Hi all!
View(I
> > > Thanks,
> > > Igor S. Zamyatin
> > > Interstron Ltd.
Previous Topic:(How) does cross referecing work?
Next Topic:Refreshing workspace hangs
Current Time: Fri Aug 29 18:54:11 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
