Home » Archived » BIRT » errors with flat file
errors with flat file [message #48842] Tue, 21 June 2005 15:21 Go to next message
Originally posted by: no.spam.com
Trying to test BIRT with a flat file (don't ask, aaargh) and keep getting
the following error when setting up a data set:
A Birt exception occurred.
Error Code:odaconsumer.CannotPrepareStatement
Error Message:Failed to prepare the follwing query for the data set type
(org.eclipse.birt.report.data.oda.flatfile.dataSet).
[select l sIncidentType, x nPotentialLossAmount from Incidents_2005-06-15]
Source data error
Source data error
Anyone have any thoughts as to why?
No thoughts, on this? (eom) [message #49145 is a reply to message #48842] Wed, 22 June 2005 09:05 Go to previous messageGo to next message
found another instance of error mssg [message #49358 is a reply to message #48842] Wed, 22 June 2005 10:49 Go to previous messageGo to next message
Originally posted by: ugaman94.gmail.com
Documented at
http://dev.eclipse.org/newslists/news.eclipse.birt/msg00759. html
Can anyone report successfully working with flat file data sources?
Re: found another instance of error mssg [message #49928 is a reply to message #49358] Wed, 22 June 2005 17:40 Go to previous messageGo to next message
Hi Mark,
I was messing around with flat file stuff a bit back
the format of the data in the flat file, has to be something like
a,b,c
string,string,string
1,2,3
4,5,6
7,8,9
where abc are your labels
string,string,string are your data type for each column
and then of course the data
hope that helps some.
- Mike
Mark wrote:
> Documented at
Re: found another instance of error mssg [message #50094 is a reply to message #49928] Wed, 22 June 2005 22:16 Go to previous messageGo to next message
Thanks...are you saying the data types have to be 'declared' in the 2nd
rows of cells? I'm not following, completely...
or... [message #50362 is a reply to message #49928] Thu, 23 June 2005 09:48 Go to previous messageGo to next message
...are you saying that all the data types must be strings?
figured it out Mike, thanks! (eom) [message #50390 is a reply to message #49928] Thu, 23 June 2005 10:08 Go to previous message
Previous Topic:Parameter in "in" SQL clause
Next Topic:HTTP 500 error, previewing my report in the report designer
Current Time: Thu Jul 17 00:56:06 EDT 2025
Powered by FUDForum. Page generated in 0.08881 seconds
