Home » Archived » OHF » Set Value?
Set Value? [message #48838] Thu, 09 October 2008 00:18 Go to next message
XML:<value xsi:type="PQ" value="155" unit="mm[hg]"/>
Creating a datatype PQ pq,I can use pq.setUnit("mm[hg]"),but the
parameter of the pq.setValue is an object.I do not known how to create the
right object.
Can someone help me?
Re: Set Value? [message #48900 is a reply to message #48838] Thu, 09 October 2008 05:16 Go to previous messageGo to next message
<value xsi:type="RTO_PQ_PQ">
<numerator value="88"/>
<denominator value="1" unit="min"/>
</value>
How to Create the value element? The getValue.add() can add the PQ,but the
PQ do not have the setNumerator or getNumerator?
I do not find the way to create the value element and the way to set the
element value.Can someone help me?
Re: Set Value? [message #48962 is a reply to message #48900] Thu, 09 October 2008 10:51 Go to previous message
The 'value' element in the observation is of type 'ANY' which is the
base data type of every underlying datatype in the CDA. So you need to
create an instance of the datatype of your choice and then the mehtods
should be available to you. Numbers use their object wrapper types.
PQ quantityValue = CDAR2Factory.eINSTANCE.createPQ();
quantityValue.setValue(new Double(1.234567890));
quantityValue.setUnit("mg/Hg");
- Sarah
> </value>
> the PQ do not have the setNumerator or getNumerator?
Re: Set Value? [message #587888 is a reply to message #48838] Thu, 09 October 2008 05:16 Go to previous message
</value>
Re: Set Value? [message #587901 is a reply to message #48900] Thu, 09 October 2008 10:51 Go to previous message
- Sarah
> </value>
Previous Topic:How to Create Organization Information
Next Topic:Will SAT be maintained
Current Time: Wed Jul 30 18:11:12 EDT 2025
Powered by FUDForum. Page generated in 0.03736 seconds
