Home » Eclipse Projects » Equinox » Empty folders in eclipse/configuration/org.eclipse.osgi/bundles
Empty folders in eclipse/configuration/org.eclipse.osgi/bundles [message #48819] Thu, 21 July 2005 09:25 Go to next message
OSGI/Eclipse seem to leave empty folders (named 1, 2, 3 etc) in
eclipse/configuration/org.eclipse.osgi/bundles directory over time. Shoud these directories be
cleaned periodically ? Is there a fix/workaround for this problem ?
I am using Eclipse 3.1 M6 driver. Is this fixed in later drivers ?
Appreciate your help.
Subbarao.
Re: Empty folders in eclipse/configuration/org.eclipse.osgi/bundles [message #48848 is a reply to message #48819] Thu, 21 July 2005 15:38 Go to previous messageGo to next message
When running Eclipse/OSGi On z/OS, I notice that a file jdtcore.jar is not being cleaned up from
eclipse/configuration/bundles/*/.cp subdirectories (size 3376087 bytes). It seem to happen every
time the OSGi App is launched.
Is this a known problem ? Any insight you can provide is greatly apprecited.
Subbarao
"Subbarao Meduri" <mkv@us.ibm.com> wrote in message news:dbo7nm$h2h$1@news.eclipse.org...
> Subbarao.
Re: Empty folders in eclipse/configuration/org.eclipse.osgi/bundles [message #48968 is a reply to message #48848] Thu, 28 July 2005 10:42 Go to previous messageGo to next message
Subbarao,
I would not mess up with Exclipse configuration.
This is a important cache and configuration area.
Clean it, and Eclipse will crash or refuse to start. ;-)
news:dbotjc$g8m$1@news.eclipse.org...
apprecited.
> Subbarao
> > Regards,
> > Subbarao.
Re: Empty folders in eclipse/configuration/org.eclipse.osgi/bundles [message #49055 is a reply to message #48968] Mon, 08 August 2005 11:35 Go to previous message
Originally posted by: jeff_nospam_mcaffer.ca.ibm.com
this was a bug that was cleared up I believe.
Jeff
"Philippe Ombredanne" <pombredanne@nexb.com> wrote in message
news:dcaqv9$3v3$1@news.eclipse.org...
> Subbarao,
not
> apprecited.
> > Regards,
> > Subbarao
> > > Regards,
> > > Subbarao.
Previous Topic:embedding eclipse - osgi
Next Topic:standalone
Current Time: Fri Aug 29 18:55:58 EDT 2025
Powered by FUDForum. Page generated in 0.03934 seconds
