Home » Eclipse Projects » Commercial » OrindaBuild 5.0 Launched - Writes Java to connect Oracle to Apache Axis
OrindaBuild 5.0 Launched - Writes Java to connect Oracle to Apache Axis [message #4270] Fri, 22 April 2005 03:40
Originally posted by: drolfe_ec.orindasoft.com
OrindaBuild runs as a stand alone Java application or as an Eclipse Plugin.
OrindaBuild was developed to generate Java source code to access tables,
stored procedures, packages, functions and sequences in Oracle databases.
It also generates matching Java to run any SQL statement and turns the
results of SQL queries into arrays of records.
The new Version 5.0 of OrindaBuild also creates a matching Data Access
Object Factory class and Apache Axis compatible Web Service classes for
your chosen SQL statements and PL/SQL procedures. It is the only product
that can generate JDBC calls for complex PL/SQL procedures without using
SQLJ.
A free fully functioning limited life demo of OrindaBuild can be
downloaded here. OrindaBuild can be bought online for between US$49 and
US$499 using WorldPay. If you buy OrindaBuild you end up with a 100% human
readable Java source code solution that doesn't require additional
libraries, third party tools or precompilers.
For more information on how OrindaBuild works see the link below:
http://www.orindasoft.com/public/ecfeatures.php4?adsrc=UN
A 3 minute Flash presentation is available here:
http://www.orindasoft.com/public/flashdemotwo.php4?adsrc=UN
Orinda's corporate blog is two-thirds general Oracle, Java and PL/SQL
information:
http://www.jroller.com/page/orindasoft
Previous Topic:[ANN] Instantiations WindowBuilder Pro 4.0 released
Next Topic:OrindaBuild 5.0 Launched - Writes Java to connect Oracle to Apache Axis
Current Time: Wed Jul 30 08:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.24134 seconds
