Home » Newcomers » Newcomers » organizing multiple projects in one workspace
organizing multiple projects in one workspace [message #48798] Thu, 07 April 2005 14:45 Go to next message
With Eclipse 3.1M6
I have following file structure
D:\dev\ . . . . . . . . . . . Workspace (-data); containing .metatdata
D:\dev\MainProject\ . . . project already in Workspace; runs fine
D:\dev\tst\TestProj1\ . . 1st test project; containing .project .classpath from earlier WS config
D:\dev\tst\TestProj2\ . . 2nd test project; not containing any Eclipse metatdata
D:\dev\tst\TestProj3\ . . 3rd test project;
I want to include these multiple test projects as separate projects
in the Eclipse Workspace inside d:\dev, which already contains MainProject.
1.) NOK - create from existing source
new-project-java project -
create from existing source ... pointing to d:\dev\tst\TestProj1
Dlg= "New Java Project"
Error Msg= Cannot create project content in workspace
Buttons "Next" and "Finish" are greyed out.
2.) NOK - test project as Linked Sources
new-project-java project - create new project in workspace "TestProj1" -
add linked root folder d:\dev\tst called "src" in new project -
include d:\dev\tst\testproj1 only
under d:\dev a new project folder for new "TestProj1" is created
whereby the "bin"-folder is forced to be within dev/TestProj
.... err msg= "output folder must denote location inside project" ...
bin is duplicated and the idea to group test projects under
directory tst is perverted.
3.) NOK Import existing project from file system
.... applied to d:\dev\tst\TestProj1 or ...\TestProj1\src
Error msg=
Invalid project description
D:/dev/tst/TestProj1 and D:/dev overlap.
I read the docu twice now but I can't organize it the way I want it.
Is there a way to organize the projects as outlined
above inside one single Eclipse Workspace?
Could it be that the Workspace data are corrupted?
Is there a way to rebuild a Workpsace?
Could it be a bug in 3.1M6 or am I doing something wrong?
Thanks for your help.
Lophiomys
Re: organizing multiple projects in one workspace [message #48994 is a reply to message #48798] Fri, 08 April 2005 04:05 Go to previous messageGo to next message
Originally posted by: user.server.net
Just a couple of remarks, probably not yet the solution:
(a) Eclipse requires the project directories to be direct subdirectories
of the workspace. So, your idea of subgouping won't work.
(b) To import, move the projects outside the workspace, then it should
work (but I havn't imported projects yet with 3.1 M6).
(c) Corrupted files: The only files that would harm being corrupt would
be the metadata and -java files. For the .java files, you can easily
test it with a simple text editor. Same applies in general to the
metadata files, though, they might me more difficult to read in plain
text. The .class files will be rebuilt on the first compile, so you can
simply delete them.
(d) You can force rebuild the workspace, if I remember it correctly, by
deleting the .metadata directory in your workspace directory. (but save
it somewhere else before you try!!!) But this will make you lose all
your editor and other settings for eclipse (they are stored in the
..plugins subdirectory. Just in case, there should also be hints on this
in the platform newsgroup and in the FAQ.
Hope this helps,
Kai
Lophiomys wrote:
> With Eclipse 3.1M6
> Error msg=
> Lophiomys
Re: organizing multiple projects in one workspace [message #51999 is a reply to message #48994] Thu, 14 April 2005 08:55 Go to previous message
Kai,
thanks for your reply.
So far I could determine by other test that none of the control files is damaged.
A partial solution would be,
- to create a project under d:\dev\tst\
- exclude it form the BuildPath
-- then for every TestProjX in dev\tst
- add \dev\tst\TestProjX\src as source folder on the BuildPath
- set a specific output folder to \dev\tst\TestProjX\bin
....drawback this leaves .class and .projects files for TestProj1 under \dev\tst\.
.... and its a tedious manual setup
Looking at it from the other side, this was caused by by the aim of
- having one single .metatdata for all projects, i.e. same syntax colors, code formatter
- subgrouping a multirude(:-O) of minor projects in one sub-folder within one workspace
Any suggestions for a better solution?
Lophiomys
>simply delete them.
>Hope this helps,
>Kai
>Lophiomys wrote:
>> With Eclipse 3.1M6
>> [... snip until end...]
Previous Topic:error after launching eclipse
Next Topic:run configuration and dlls
Current Time: Wed Jul 16 20:37:44 EDT 2025
Powered by FUDForum. Page generated in 0.09021 seconds
