Home » Archived » BIRT » Unable to insert image
Unable to insert image [message #48785] Tue, 21 June 2005 14:27 Go to next message
I added an image. In preview I got "There are errors on the report page:
Error1:Failed to evaluate file:///e:/test/Sun_Logo_W_on_SunBlue.jpg
Unexpected end of file (#1)" error even though I can see the image.
When I try to generate html report the image is not in the html file at all
due to exceptions.
Any one can help? Thanks!!!!
Jim
Re: Unable to insert image [message #51753 is a reply to message #48785] Mon, 27 June 2005 13:10 Go to previous message
Hi, Jim,
The quick solution is to just quote your URL.
The reason is that image URL is an expression, not a string. It is an
expression to give you more power to dynamically generate URL, but is
cubersome in the simple case where you only have a simple link. The UI
could do better, but that is an enhancement for the next release.
Stanley Wang
BIRT Engine
Previous Topic:How to change parameter at runtim
Next Topic:DynamicList Combo Parameter
Current Time: Mon Jul 14 19:20:29 EDT 2025
Powered by FUDForum. Page generated in 0.23809 seconds
