Re: excel emitter [message #481109 is a reply to message #480904] |
Wed, 19 August 2009 16:14 |
Kris,
Have you tried using the text block properties on a style?
Try the no wrapping under the whitespace category.
Jason
Kris Chappell wrote:
> I need to output an excel spreadsheet where the columns do not
> automatically wrap. I don't want to resize the report and set the column
> width to the widest it needs to be to accommodate a particular field. Is
> there any way that I can use onRender (or any other scripting
> opportunity) to tell the excel emitter not to wrap the text within a
> column. Or perhaps grab the excel object and set the worksheet to nowrap?
> Thank you.
Re: excel emitter [message #481339 is a reply to message #481334] |
Thu, 20 August 2009 14:38 |
Kris,
Are you using the Tribix emitter or the built in excel emitter? Can you
post a small report that shows the problem?
Jason
> Yes, thank you. I've tried this. It works for HTML and PDF, but not
> xls. That is why I though if during the rendering phase I could do
> something. Can I change the attribute at the time it is actually
> rendered? Maybe that will work. I'm open to suggestions.
> Thanks again,
> Kris
FUDForum. Page generated in 0.03140 seconds
