Home » Eclipse Projects » Plugin Development Environment (PDE) » Issues creating custom debugger
Issues creating custom debugger [message #48769] Sun, 01 March 2009 13:22 Go to next message
Hello
I am working on creating a custom debugger plugin for Eclipse.
I have several things working already. I can launch debug configurations,
breakpoints, threads, stack traces, stepping, variable inspection it all
works.
There are two problems that I have that I have been unable to solve
despite digging into other debugger code.
1. When a breakpoint is reached and I fire a suspend event in a thread
with DebugEvent.BREAKPOINT as the details, the actual breakpoint doesn't
get highlighted in the file editor.
How do I have Eclipse open the file in question, jump to the breakpoint
line and add the little arrow and line highlight that indicates that we're
at that point in the code?
2. After my threads and process terminate (and it all says terminated in
the debug view) if I launch another debug configuration, eclipse's debug
view gets all confused. It tried to re-use the old items and inserts the
new process in the old list of process/threads. The view doesn't update
right either.
I'm firing all the terminate events that I think I need to, but for some
reason Eclipse isn't "cleaning up" the items.
Could someone out there point me in the right direction to solve these two
issues?
Re: Issues creating custom debugger [message #48802 is a reply to message #48769] Sun, 01 March 2009 17:53 Go to previous message
Robert Schultz wrote:
> Hello
> configurations, breakpoints, threads, stack traces, stepping, variable
> inspection it all works.
> we're at that point in the code?
> right either.
> two issues?
Since your question is pretty detailed, I would consider sending an
email to the Platform Debug mailing list:
https://dev.eclipse.org/mailman/listinfo/platform-debug-dev
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/caniszczyk | http://twitter.com/eclipsesource
Re: Issues creating custom debugger [message #592583 is a reply to message #48769] Sun, 01 March 2009 17:53 Go to previous message
> Hello
> right either.
> two issues?
Previous Topic:Issues creating custom debugger
Next Topic:Missing Jar in Target Platform
Current Time: Mon May 12 11:53:17 EDT 2025
Powered by FUDForum. Page generated in 0.02264 seconds
