How to use compiler provided with JDK 1.4.1_02 in Eclipse [message #48756] |
Wed, 12 March 2003 09:09  |
Originally posted by: ppatel.lukensgroup.com
I would like to use the compiler bundled with sun's JDK 1.4.1_02 to
compile my application in Eclipse. I think, Eclipse comes with its own
incremental compiler. I have following questions about it.
1) What's the difference between the Eclipse compiler and Sun's compiler?
2) I am kind of confused over compiler compliance level. There are two
compiler compliance level (1.3 & 1.4) in Eclipse. So if i use compliance
level 1.3, does it mean that Eclipse is using java 1.3 compiler (that
bundled with Eclipse) to comiple the application? And if i use compliance
level 1.4, does it mean that Eclipse is using java 1.4 compiler (that
3) If i would like to use Sun's Java compiler or IBM's Java compiler in
Eclipse, how could i do that?
Any type of help would be appreciated.
Prashant Patel
Re: How to use compiler provided with JDK 1.4.1_02 in Eclipse [message #48847 is a reply to message #48756] |
Wed, 12 March 2003 15:35  |
Originally posted by: mccull1NOSPAMPLEASE.us.ibm.com
For future reference, eclipse.tools is the place for this...
<SNIP>
It is written in Java. It is incremental. It is integrated into the IDE.
It has more features. Etc.
The compliance level indicates "equivalence". 1.3.x compliance is "as if
you compiled with JDK 1.3.X" and 1.4 compliance is "as if you compiled with
JDK 1.4.x". So 1.4.X compliance means Eclipse .class files will run on a
JDK 1.4 JVM.
Only way is to use ANT.
-Andrew
Re: How to use compiler provided with JDK 1.4.1_02 in Eclipse [message #591544 is a reply to message #48756] |
<SNIP>
JDK 1.4 JVM.
-Andrew
FUDForum. Page generated in 0.04611 seconds
