Home » Archived » OHF » How to Create Organization Information
How to Create Organization Information [message #48687] Tue, 07 October 2008 05:51 Go to next message
<representedOrganization>
<id root="8a54f393-8015-460c-abd2-f29aad15481c"/>
<name>Good Health Disease Management</name>
<telecom value="tel:(999)555-1212" use="DIR"/>
<addr>
<streetAddressLine>21 North Ave</streetAddressLine>
<city>Burlington</city>
<state>MA</state>
<postalCode>01803</postalCode>
<country>USA</country>
</addr>
</representedOrganization>
What is the object type in the function
representedOrganization.getName().add(Object)? And the object type
representedOrganization.getTelecom().add£šObject£©?
In other words, how to write code to set the Organization Information.
This confused me for hours.
Thanks in advance!
Re: How to Create Organization Information [message #48751 is a reply to message #48687] Wed, 08 October 2008 05:40 Go to previous messageGo to next message
The addr was setted sucessful.But the use of telecom attributes value was
not setted.
How can set it?
Thanks!
Re: How to Create Organization Information [message #48781 is a reply to message #48751] Wed, 08 October 2008 13:56 Go to previous messageGo to next message
Hi Robert,
Using the CDA schema and CDA examples as a guide will help you. telecom
is of type TEL and the actual telephone number/email/web
address/whatever will be set in the value attribute:
// create a TEL data type
TEL telecom = CDAR2Factory.eINSTANCE.createTEL();
// set the value
telecom.setValue("<telephone number>");
// add to the list of telecom for the organization
organization.getTelecom().add(telecom);
Again, EMF tutorials will be your best way to learn how to interact with
EMF.
- Sarah
> was not setted.
> How can set it?
> Thanks!
Re: How to Create Organization Information [message #48869 is a reply to message #48781] Thu, 09 October 2008 01:30 Go to previous messageGo to next message
XML:<telecom value="tel:(999)555-1212" use="DIR"/>
The telecom element have two attributes,vaule and use.Thank you for your
code.The code that you give me can set the value's value,but how to set
the use value?
Re: How to Create Organization Information [message #48933 is a reply to message #48869] Thu, 09 October 2008 10:46 Go to previous message
Pretty much you can set it the same way ... there is a setUse method and
it will take an enumeration value from the TelecomAddressUse (or
something named simmilar -- I don't have access to the code at the
moment) enumeration.
- Sarah
> the use value?
Re: How to Create Organization Information [message #587855 is a reply to message #48687] Wed, 08 October 2008 05:40 Go to previous message
not setted.
How can set it?
Thanks!
Re: How to Create Organization Information [message #587859 is a reply to message #48751] Wed, 08 October 2008 13:56 Go to previous message
Hi Robert,
// set the value
EMF.
- Sarah
> was not setted.
> How can set it?
> Thanks!
Re: How to Create Organization Information [message #587882 is a reply to message #48781] Thu, 09 October 2008 01:30 Go to previous message
the use value?
Re: How to Create Organization Information [message #587893 is a reply to message #48869] Thu, 09 October 2008 10:46 Go to previous message
- Sarah
> the use value?
Previous Topic:Set Value?
Next Topic:Set Value?
Current Time: Sun May 25 23:53:06 EDT 2025
Powered by FUDForum. Page generated in 0.07235 seconds
