Home » Eclipse Projects » Eclipse Platform » Probably a stupid question: File Search
Probably a stupid question: File Search [message #48651] Tue, 27 May 2003 01:45 Go to next message
Java search works fine for me to find things in the Eclipse source code,
but every time I try a File Search, it says "Problems encountered during
text search" and in the details for every file it says "Resource is out of
sync with file system". So I end up using grep. What am I doing wrong?
Don
Re: Probably a stupid question: File Search [message #48694 is a reply to message #48651] Tue, 27 May 2003 02:11 Go to previous messageGo to next message
Originally posted by: hcs33.egon.gyaloglo.hu
This message shows that those files are modified outside Eclipse. Try to
refresh your projects in the Navigator view and file search should work.
HTH,
Csaba
"Don Estberg" <destberg1@earthlink.net> wrote in message
news:bauu1j$7rn$1@rogue.oti.com...
> Don
Re: Probably a stupid question: File Search [message #50917 is a reply to message #48694] Wed, 28 May 2003 01:10 Go to previous message
Horváth, Csaba wrote:
> HTH,
> Csaba
Yes, that helps.
Don
Previous Topic:Help!!!A problem that blocks me to use Eclipse,I am a freshman in using Eclipse!!!
Next Topic:key bindings overview as pdf-file
Current Time: Wed May 07 21:23:35 EDT 2025
Powered by FUDForum. Page generated in 0.12743 seconds
