| Probably a stupid question: File Search [message #48651] |
Tue, 27 May 2003 01:45  |
Java search works fine for me to find things in the Eclipse source code,
but every time I try a File Search, it says "Problems encountered during
text search" and in the details for every file it says "Resource is out of
sync with file system". So I end up using grep. What am I doing wrong?
Don
| Re: Probably a stupid question: File Search [message #50917 is a reply to message #48694] |
Wed, 28 May 2003 01:10  |
Horváth, Csaba wrote:
> This message shows that those files are modified outside Eclipse. Try to
> refresh your projects in the Navigator view and file search should work.
> HTH,
> Csaba
Yes, that helps.
Don
FUDForum. Page generated in 0.26046 seconds
