| Re: [JET] XPath query to select unique nodes [message #48973 is a reply to message #48943] |
Mon, 25 August 2008 18:25  |
Originally posted by: mozafara.cs.man.ac.uk
Paul,
I eventually used a very similar approach to yours, but had to copy the
unique nodes (without children) under a new subtree for future
reference. Before copying each node I checked if it already existed
under the new tree.
Paul Elder wrote:
> Amin:
> Well, it is certainly possible that there is a defect in preceding-sibling -
> can you post an example?
> But, more importantly, there was a comment on that linked page which caught
> my eye: "this is O(N^2) and will be very slow for a large list..."
> So, I'd be looking for an alternative anyhow...
> With JET 0.9 (ganymede), there is a sort function that could be used to do a
> directory like solution similar that described in this "What's new in XSLT
> 2.0" article (http://www.xml.com/pub/a/2002/04/10/xslt2.html?page=2)
> Assuming a document like:
> <cities>
> <city name="milan" country="italy" pop="5"/>
> <city name="paris" country="france" pop="7"/>
> <city name="munich" country="germany" pop="4"/>
> <city name="lyon" country="france" pop="2"/>
> <city name="venice" country="italy" pop="1"/>
> </cities>You could write a template like this:
> <c:setVariable var="lastCountry" select=" 'NotACountry' "/>
> <c:iterate select="sort(/cities/city, '@country')" var="city">
> <c:if test="not($lastCountry = $city/@country)">
> Country: <c:get select="$city/@country"/>
> <c:setVariable var="lastCountry" select=" $city/@country "/>
> </c:if>
> City: <c:get select="$city/@name"/>
> </c:iterate>
> The sort uses the standard Java Collections.sort(), so the above approach is
> at worst O(N-log(N)).
> Paul
FUDForum. Page generated in 0.06366 seconds
