Home » Eclipse Projects » Remote Application Platform (RAP) » [LifeCycle] Problem with disposed Context
[LifeCycle] Problem with disposed Context [message #48632] Fri, 21 September 2007 09:26 Go to next message
Hi all, I've found this problem with new CVS updates, When you launch
Demo app and close workbench, If you try to refresh page, to entry into
application again, an exception is thrown:
java.lang.IllegalStateException: The context has been disposed.
org.eclipse.rwt.internal.service.ServiceContext.checkState(S erviceContext.java:154)
org.eclipse.rwt.internal.service.ServiceContext.getRequest(S erviceContext.java:82)
org.eclipse.rwt.internal.service.ContextProvider.getRequest( ContextProvider.java:128)
org.eclipse.rwt.internal.service.ContextProvider.getSession( ContextProvider.java:147)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHandlerProcessor.bufferThrowable(RWTLifeCycleBlockCon trol.java:90)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleBlockControl$ ServiceHandlerProcessor.run(RWTLifeCycleBlockControl.java:70 )
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olRunnable.run(RWTLifeCycleThreadPool.java:38)
org.eclipse.rwt.internal.lifecycle.RWTLifeCycleThreadPool$Po olWorker.run(RWTLifeCycleThreadPool.java:66)
I've created this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204076 there are several
situations when this problem happens.
I was waiting for new performance improvements planned for this week,
but with this problem I'm blocked, My new application release will have
to await.
I'm not an expert in RAP Lifecycle but I think that Context should be
re-created when Entrypoint is called, but I don't know...
Please, a patch/workaround will be welcome.
Thanks in advance.
Roberto.
Re: [LifeCycle] Problem with disposed Context [message #49180 is a reply to message #48632] Sun, 23 September 2007 22:38 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
please update against the latest CVS versions and tell me whether the
situation has improved. Sorry for your inconvenience.
Ciao
Frank
"Roberto S
Re: [LifeCycle] Problem with disposed Context [message #49201 is a reply to message #49180] Mon, 24 September 2007 03:35 Go to previous messageGo to next message
Hi Frank, now It works fine, I would like to test it a bit more, but all
seems to be OK.
Thank you.
Bye
Roberto.
Frank Appel escribió:
> Ciao
> Frank
> "Roberto Sá‡nchez" <roberto@autonomind.com> schrieb im Newsbeitrag
> news:fd0gpg$mt8$1@build.eclipse.org...
>> Hi all, I've found this problem with new CVS updates, When you launch Demo
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> I was waiting for new performance improvements planned for this week, but
>> with this problem I'm blocked, My new application release will have to
>> await.
>> Thanks in advance.
>> Roberto.
Re: [LifeCycle] Problem with disposed Context [message #128061 is a reply to message #49201] Wed, 15 April 2009 14:17 Go to previous message
We have been experiencing exactly the same problem against 1.2M6 release
at org.eclipse.rwt.internal.service.ServiceContext.checkState(S erviceContext.java:154)
at org.eclipse.rwt.internal.service.ServiceContext.getStateInfo (ServiceContext.java:104)
at org.eclipse.rwt.internal.service.ContextProvider.getStateInf o(ContextProvider.java:166)
at org.eclipse.rwt.internal.lifecycle.CurrentPhase.get(CurrentP hase.java:48)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.readAndDispa tch(RWTLifeCycle.java:236)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :721)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work benchAdvisor.java:807)
at org.eclipse.ui.internal.Workbench$25.runWithException(Workbe nch.java:1430)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:32)
at org.eclipse.rwt.internal.lifecycle.UICallBackManager.addSync (UICallBackManager.java:119)
at org.eclipse.swt.widgets.Display$2.run(Display.java:649)
at org.eclipse.rwt.internal.lifecycle.UICallBackServiceHandler. runNonUIThreadWithFakeContext(UICallBackServiceHandler.java: 455)
at org.eclipse.rwt.lifecycle.UICallBack.runNonUIThreadWithFakeC ontext(UICallBack.java:44)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:647)
at org.eclipse.ui.internal.StartupThreading.runWithoutException s(StartupThreading.java:110)
at org.eclipse.ui.internal.Workbench.init(Workbench.java:1425)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2404)
at org.eclipse.ui.internal.Workbench.access$5(Workbench.java:22 95)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:514)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:497)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:157)
at com.turquality.server.rap.Application.createUI(Application.j ava:60)
at org.eclipse.rwt.internal.lifecycle.EntryPointManager.createU I(EntryPointManager.java:92)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.createUI(RWT LifeCycle.java:228)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:116)
at java.lang.Thread.run(Thread.java:636)
Exception in thread "UIThread [79F5701409C7E6F2FCF5B12D127B16AD]" java.lang.IllegalStateException: The context has been disposed.
at org.eclipse.rwt.internal.service.ServiceContext.getRequest(S erviceContext.java:82)
at org.eclipse.rwt.internal.service.ContextProvider.getRequest( ContextProvider.java:129)
at org.eclipse.rwt.internal.service.ContextProvider.getSession( ContextProvider.java:148)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.setShutdownA dapter(RWTLifeCycle.java:345)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle.access$0(RWT LifeCycle.java:342)
at org.eclipse.rwt.internal.lifecycle.RWTLifeCycle$UIThreadCont roller.run(RWTLifeCycle.java:130)
Any hints?
Hasan Ceylan
> seems to be OK.
> Thank you.
> Bye
> Roberto.
>> Ciao
>> Frank
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> to await.
>>> Thanks in advance.
>>> Roberto.
Previous Topic:Performance
Next Topic:Drag and Drop
Current Time: Wed Jul 30 13:28:05 EDT 2025
Powered by FUDForum. Page generated in 0.03960 seconds
