Home » Language IDEs » Java Development Tools (JDT) » Updating existing JUnit TestCases
Updating existing JUnit TestCases [message #48615] Wed, 04 June 2003 09:13
Originally posted by: delworthy.unveil.com
I am making the transition from NetBeans to Eclipse for Java development.
In netbeans, I can select a Java source file and use a command which
creates a JUnit test case from it, with skeletons for each method.
Something similar exists in Eclipse, but there is one difference. NetBeans
does this: suppose I already have a unit test FooTest for a class Foo, and
I add a new method doIt() to Foo. In NetBeans, I can recreate FooTest,
leaving any existing methods intact, and adding a skeleton version of
testDoIt. I have not been able to do this in Eclipse - it seems you can
only create the whole FooTest from scratch. Am I right? Is there a way to
get the same functionality in Eclipse that I can get in NetBeans?
Previous Topic:JavaCore.getOption(COMPILER_CODEGEN_TARGET_PLATFORM) always returns 1.1
Next Topic:error when running ant
Current Time: Thu Jul 17 19:46:19 EDT 2025
Powered by FUDForum. Page generated in 0.05606 seconds
