Home » Archived » XML Schema Definition (XSD) » Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema"
Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema" [message #48597] Fri, 02 July 2004 10:14 Go to next message
I receive the mentioned error message when importing a schema file to
create a new EMF model. The error refers to an import statement.
My versions:
Eclipse Version: 3.0.0 Build id: 200406251208
Eclipse Modeling Framework (EMF) Version: 2.0.0 Build id: 200406280827
XML Schema Infoset Model (XSD) Version: 2.0.0 Build id: 200406280827
When I open the main schema file in WSAD, no errors are reported. The
schema is displayed correctly, including the imported schema elements.
This suggests the schema is syntactically OK.
Help?
Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #48628 is a reply to message #48597] Fri, 02 July 2004 10:47 Go to previous messageGo to next message
I forgot to mention, the error message appears in the "Problems" view.
When importing the schema, the EMF model wizard reports, "Specify a
valid XML Schema and try loading again".
Thanks, chris
Chris Giblin wrote:
> My versions:
> Help?
> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #48662 is a reply to message #48628] Fri, 02 July 2004 11:09 Go to previous message
Dear Chris,
You fell victim to the infamous Sun Crimson XML parser problem.
http://fullmoon.torolab.ibm.com/tools/emf/scripts/downloads- xerces.php
Yourself
Chris Giblin wrote:
> Thanks, chris
> Chris Giblin wrote:
>> My versions:
>> Help?
>> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #589578 is a reply to message #48597] Fri, 02 July 2004 10:47 Go to previous message
Thanks, chris
Chris Giblin wrote:
> My versions:
> Help?
> Thanks, chris
Re: Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema&quo [message #589587 is a reply to message #48628] Fri, 02 July 2004 11:09 Go to previous message
Dear Chris,
Yourself
Chris Giblin wrote:
> Thanks, chris
> Chris Giblin wrote:
>> My versions:
>> Help?
>> Thanks, chris
Previous Topic:Error, "XSD: The location 'http://.. ' may not resolve to something other than a schema"
Next Topic:Eclipse, EMF, XSD and Maven
Current Time: Mon Jul 07 15:01:57 EDT 2025
Powered by FUDForum. Page generated in 0.71640 seconds
