Home » Eclipse Projects » Equinox » Why using .jar file plugins for platform fragments?
Why using .jar file plugins for platform fragments? [message #48578] Mon, 13 June 2005 09:20 Go to next message
when there is a shared library or an executable in a osgi .jar
plugin, the plugin gets unpacked into the configuration\org.eclipse.osgi\bundles
directory.
What is the advantage to install a platform fragment as .jar file
over the classical directory distribution, where the shared library is
accessed directly?
Should plugin fragments that only contain shared libraries and executables
be shipped as directories?
Isn't this copy of libraries a potential cause of trouble?
Is there a document/bugzilla entry that describes the rational
behind this?
Michael
Re: Why using .jar file plugins for platform fragments? [message #48608 is a reply to message #48578] Tue, 14 June 2005 15:50 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
Some of the benefits are listed here in this document:
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-core-home/documents/3.1/run_from_jars.html
An added benefit is it allow eclipse to start through java web start, which
is important for RCP.
The extracted libraries are managed by the runtime itself and do not cause
any problem.
As indicated in the document, not all plugins must or could be jared and it
is up to the plugin developer to decide on the format depending on the
restrictions.
HTH
PaScaL
"Michael Scharf" <Michael.Scharf@windriver.com> wrote in message
news:d8k16c$k9r$1@news.eclipse.org...
> directory.
> accessed directly?
> behind this?
> Thanks
> Michael
Re: Why using .jar file plugins for platform fragments? [message #49483 is a reply to message #48608] Mon, 22 August 2005 05:01 Go to previous message
> restrictions.
And how is the developer supposed to deploy plugins that can't be jared
using web start? How are library plugin supposed to be deployed?
Marcus
Previous Topic:RCP App and role based, dynamic policy
Next Topic:plugin cannot startup
Current Time: Sun Jul 27 02:48:47 EDT 2025
Powered by FUDForum. Page generated in 0.04912 seconds
