Home » Eclipse Projects » DTP » Jdbc Derby connect URL failed with a double byte language character
Jdbc Derby connect URL failed with a double byte language character [message #48570] Fri, 08 August 2008 10:31 Go to next message
Originally posted by: jinx.us.ibm.com
Hi:
When I use DTP connection profile to connect to a derby database with
UDB driver, and the database name or the path to the database has a
double byte language character, i.e.
URL:jdbc:derby:net://localhost:1527/"C:/近/mydatabase", I get the exception:
com.ibm.db2.jcc.b.SqlException: [jcc][10402][11146][3.50.152] Cannot
convert Unicode string to Ebcdic string. ERRORCODE=-4220, SQLSTATE=null
Does anyone know how I can specify a database name with a double byte
language character?
Cindy
Re: Jdbc Derby connect URL failed with a double byte language character [message #48779 is a reply to message #48570] Mon, 11 August 2008 15:22 Go to previous messageGo to next message
Hi Cindy,
This is a known problem, see:
https://issues.apache.org/jira/browse/DERBY-728
The workaround is to use characters of the ISO-8859-1 set.
BTW, it is recommended to use the Derby database driver instead of the
IBM driver.
Stephan.
> Hi:
> exception:
> language character?
> Thanks
> Cindy
Re: Jdbc Derby connect URL failed with a double byte language character [message #49058 is a reply to message #48779] Wed, 20 August 2008 13:37 Go to previous message
Originally posted by: brianf.sybase.com
Thanks Stephan for responding to Cindy's question!
--Fitz
"Stephan van Loendersloot" <stephan@republika.nl> wrote in message
news:g7q3i0$qk0$1@build.eclipse.org...
> Hi Cindy,
> BTW, it is recommended to use the Derby database driver instead of the IBM
> driver.
> Stephan.
>> Hi:
>> When I use DTP connection profile to connect to a derby database with UDB
>> driver, and the database name or the path to the database has a double
>> URL:jdbc:derby:net://localhost:1527/"C:/?/mydatabase", I get the
>> exception:
>> language character?
>> Thanks
>> Cindy
Re: Jdbc Derby connect URL failed with a double byte language character [message #592643 is a reply to message #48570] Mon, 11 August 2008 15:22 Go to previous message
Hi Cindy,
IBM driver.
Stephan.
> Hi:
> exception:
> language character?
> Thanks
> Cindy
Re: Jdbc Derby connect URL failed with a double byte language character [message #592764 is a reply to message #48779] Wed, 20 August 2008 13:37 Go to previous message
--Fitz
> Hi Cindy,
> driver.
> Stephan.
>> Hi:
>> exception:
>> language character?
>> Thanks
>> Cindy
Previous Topic:Useability
Next Topic:Is this the question about dtp?(jee-ganymede)
Current Time: Sat Jul 26 00:04:03 EDT 2025
Powered by FUDForum. Page generated in 0.03588 seconds
