Home » Modeling » TMF (Xtext) » Using the EMF classes and from a new plugin
Using the EMF classes and from a new plugin [message #48536] Fri, 05 June 2009 11:06 Go to next message
I am trying to use the EMF classes generated from xtext to save the file to
the text format, but when I save the file it saves as xml. I am not using
the editor plugin that is generated, but instead another hello world plugin
that includes the plugin that has the generated xtext emf model. I must be
missing something simple (some google juice hook maybe).
Here is the code I use to create and save the file.
XtextResourceSet rsrcSet = new XtextResourceSet();
URI uri = URI.createFileURI(file.getAbsolutePath()+".tmp");
Resource theConnRes = rsrcSet.createResource(uri);
ParseStatementsList sl =
Package.eINSTANCE.getFactory().createParseStatementsList();
TerminatedStatement sc =
Package.eINSTANCE.getFactory().createTerminatedStatement();
sl.getStatements().add(sc);
theConnRes.getContents().add(sl);
theConnRes.save(rsrcSet.getURIResourceMap());
Re: Using the EMF classes and from a new plugin [message #48601 is a reply to message #48536] Fri, 05 June 2009 11:30 Go to previous messageGo to next message
Got around this by.
a)using the correct file extension for the file.
b)including the ui text editor generated plugin.
Seems odd that I need the UI plugin, but it works for now.
"drew" <drew@acm.org> wrote in message
news:h0bc98$8ai$1@build.eclipse.org...
Re: Using the EMF classes and from a new plugin [message #48659 is a reply to message #48536] Fri, 05 June 2009 11:39 Go to previous messageGo to next message
Hi Drew,
I assume "tmp" is the file extension for your specific DSL?
Can you confirm, that theConnRes is an instance of XtextResource?
Sebastian
Am 05.06.2009 17:06 Uhr, schrieb drew:
Re: Using the EMF classes and from a new plugin [message #48688 is a reply to message #48601] Fri, 05 June 2009 11:45 Go to previous message
Hi Drew,
please find my comment below.
Am 05.06.2009 17:30 Uhr, schrieb drew:
> Got around this by.
nice :-)
Please have a look at the plugin.xml of your editor plugin and find a
secion <!-- Resource factories -->.
If you want to use your resource without the ui plugin, you'll have to
come up with something similar in your runtime plugin.
Sebastian
> "drew"<drew@acm.org> wrote in message
Previous Topic:Xtext Plan
Next Topic:[XText] Attaching a behavioral extension
Current Time: Sun Jul 27 03:03:52 EDT 2025
Powered by FUDForum. Page generated in 0.05130 seconds
