Home » Eclipse Projects » GEF » Is it possible to have two figures attached to the same model?
Is it possible to have two figures attached to the same model? [message #48485] |
Sun, 08 December 2002 20:38  |
Originally posted by: rspbr.hotmail.com
I'm trying to implement an editor that shows a figure for a particular
element of a model and a label for that figure.
The problem is that I wished that the label could be manipulated as an
independent figure - the user should be able to move it around separately
from the "main" figure, allowing him to better place the labels to avoid
collisions.
Even better than that: Would it be possible to have that label to act like a
connection figure? I mean, the user can modify it but when the main figure
is selected the label is unselected?
I was trying to "brute force" adding those extra labels by overriding the
add(IEditorPart) method, but without success. Anybody has any idea on the
right way of doing this?
Thanks for any help,
Ricardo
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.427 / Virus Database: 240 - Release Date: 6/12/2002
Re: Is it possible to have two figures attached to the same model? [message #48576 is a reply to message #48517] |
Mon, 09 December 2002 14:13   |
> Can you give a better description of what you want to do? Instead of
> describing the behavior completely, maybe there is another program that
does
> the same thing.
Well, I'm working in a complete Petri net editor for Eclipse. Normally,
places and transitions have a label associated to them, but this label has
to be "moveable" so users can place them out of the arcs' way.
The problem is that I'm having trouble adding this label as an independent
figure. For example, the idea is to have a figure (EllipseFigure) that
represents the place and a figure (Label) to display the place's label.
The question is: how to make this label independent from the ellipse, even
if they do refer to the same model?
At a later time, I wish that the label would behave like connections. That
means: user can select it directly and move it around, but when a marquee
selection is made, the labels are excluded.
That way I could update the position of the label each time that the ellipse
is moved around. The label would have then a "relative" position to the
ellipse instead of an "absolute" position to the canvas.
Thanks again for any help,
Ricardo
Re: Is it possible to have two figures attached to the same model? [message #48606 is a reply to message #48576] |
Mon, 09 December 2002 20:23   |
Originally posted by: hudsonr.us.eye-bee-em.com
I've had to do the same thing in an Editor. Basically, I made the labels
child EditParts to the things which they label (connection or node). It
isn't really a child in the model, so the EditPart returns a bogus list of
model children (one for each label), which are simply strings. You could
make something more elaborate, but I didn't see the point.
List getModelChildren() {
ArrayList list = new ArrayList();
list.add("Source label");
list.add("Target label");
return list;
Now, for each item in the List, and you may have just one, an EditPart needs
to get created. So, you can override createEditPart(Object model) in that
EditPart, and instantiate a LabelEditPart, passing it the real model (the
node or connection), and perhaps the label type if you display 2 or more
labels.
If you want to prevent these EditParts from getting found by Marquee, please
open a bugzilla, and any suggestions are welcome.
"Ricardo Sangoi Padilha" <rspbr@hotmail.com> wrote in message
news:at2pr9$a19$1@rogue.oti.com...
> does
> > the same thing.
ellipse
> Ricardo
Re: Is it possible to have two figures attached to the same model? [message #49356 is a reply to message #48606] |
Thu, 12 December 2002 17:49   |
Thanks for the help, but (correct me if I'm wrong) this method creates the
label _inside_ the "parent" figure (in terms of painting). What I had in
mind was something like a label that could be moved outside the boundaries
of the parent figure and still be visible.
Any suggestions?
"Randy Hudson" <hudsonr@us.eye-bee-em.com> wrote in message
news:at3fhc$m7k$1@rogue.oti.com...
> return list;
needs
> labels.
please
> > Hi,
that
> > does
> > > the same thing.
has
independent
even
That
marquee
> ellipse
> > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #49446 is a reply to message #49356] |
Fri, 13 December 2002 09:28   |
For a connection, children can be anywhere, and the connections bounds will
automatically include the children.
For a node, you could do some work to make the children EditParts have
Figures that are *not* children. You would have to override
addChildVisual(), removeChildVisual(). Perhaps these methods would place
the labels on another layer, instead of inside the contents pane. You need
to be sure that these figures are removed when the EditPart is removed.
This won't happen automatically, since the figures aren't contained, so you
would have to override removeNotify().
news:atb3js$k0$1@rogue.oti.com...
> Any suggestions?
labels
of
could
> > return list;
> needs
that
(the
> > labels.
> please
> > > Hi,
> that
> > > does
> > > > the same thing.
Normally,
> has
> independent
label.
> even
> That
> marquee
> > ellipse
the
> > > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #49475 is a reply to message #48606] |
Fri, 13 December 2002 17:21   |
Hi!
I have the same need in my project.
I have written a ConnectionLabelEditPart that creates a draw2d.Label and
added a getModelChildren as you said below that returns a List of one
String.
Running this code I get a call to my EditPartFactory with this string as
model and I returned a new ConnectionLabelEditPart here that get displayed
in the window.
But then I'm confused. Where can I override a createEditPart? This method is
not part of EditPart. Do you mean createChild of the parent EditPart (a
ConnectionEditPart in my case) and filter away this bogus model from getting
to the EditPartFactory?
This works for me, but I get an error later if I do setModel of the new
ConnectionLabelEditPart to the ConnectionEditPart model.
/Dag
"Randy Hudson" <hudsonr@us.eye-bee-em.com> skrev i meddelandet
> return list;
needs
> labels.
please
> > Hi,
that
> > does
> > > the same thing.
has
independent
even
That
marquee
> ellipse
> > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #49505 is a reply to message #49475] |
Fri, 13 December 2002 17:39   |
"Dag Rende" <dag.rende@applied.se> wrote in message
news:atdm5o$gag$1@rogue.oti.com...
> Hi!
> String.
> in the window.
is
getting
Yes, I meant createChild(). What error do you get?
You generally should set the model immediately on the LabelEditPart.
> /Dag
labels
of
could
> > return list;
> needs
that
(the
> > labels.
> please
> > > Hi,
> that
> > > does
> > > > the same thing.
Normally,
> has
> independent
label.
> even
> That
> marquee
> > ellipse
the
> > > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #50308 is a reply to message #49505] |
Tue, 17 December 2002 11:32   |
OK. Now I think I know how to do this.
In MyConnectionEditPart i override getModelChildren() and createChild(Object
model).
I let getModelChildren return a List of a unique object - a string for
example. In createChild, i check if the model is the unique object above,
and create MyConnectionLabelEditPart and set its model. Here it is important
to not use the same model as for the parent (the MyConnectionEditPart),
because GEF keeps a map of all models and their corresponding EditParts. If
I use the same model for two edit parts GEF will not be able to find the
right EditPart later on. In my test code i simply wrap the
MyConnectionEditPart model in an array to get a unique object of it, and now
it works.
The above code is only a proof of concept, and places the label in the wrong
position relative to the connection figure.
What is left now to design is handling of placement of connection label
figures, policies for moving them with the mouse, updating their text as the
main model changes etc. I think the main ConnectionEditPart may take the
reponsibility to create the label part and connect them with a Locator
object that has an offset from midpoint o any end point so that the labels
will be placed relative to the right part of the connection figure. The
moving policy could then change the locator offset when the user uses the
mose on the label.
/Dag
Here is my test code for the above methods and the label edit part class:
in MyCoonectionEditPart:
* fake model children for the label
public List getModelChildren() {
list.add("Connection label");
return list;
* @see org.eclipse.gef.editparts.AbstractEditPart#createChild(Objec t)
protected EditPart createChild(Object model) {
if (model instanceof String
&& "Connection label".equals(model)) {
EditPart editPart = new ConnectionLabelEditPart();
editPart.setModel(new Object[] {getModel()});
return editPart;
return super.createChild(model);
public class AssociationLabelEditPart extends AbstractGraphicalEditPart {
protected IFigure createFigure() {
MyConnectionModel[] model = (MyConnectionModel[])getModel();
IFigure labelFigure = new Label(model[0].getName());
labelFigure.setOpaque(true);
return labelFigure;
protected void createEditPolicies() {
news:atdnbk$gtp$1@rogue.oti.com...
> > Hi!
> > String.
displayed
> > in the window.
method
> is
> getting
> > /Dag
> labels
It
list
> of
> could
> > > return list;
> > needs
> that
> (the
more
> > > labels.
> > please
> > > > Hi,
of
> > that
> > > > does
> > > > > the same thing.
> Normally,
label
> > has
> > independent
that
> label.
ellipse,
> > even
connections.
> > That
> > marquee
> > > ellipse
> the
> > > > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #50454 is a reply to message #50308] |
Wed, 18 December 2002 12:27   |
news:atnj4v$fj2$1@rogue.oti.com...
createChild(Object
> model).
important
If
Actually, if one of the two EditParts does not require connection support
(it is neither the source or target of connections), then you can prevent
that EditPart from registering its model by overriding the appropriate
method to do nothing. The only reason EditParts are registered by model is
so a Connection can find its source/target. This will remove the collision
you describe, and you can use the same model for both.
now
> it works.
wrong
the
> mose on the label.
We provide half of this already in ConnectionEndpointLocator. This locator
supports an offset from the node (u distance), and an offset from the
connection (v distance). You would still have to write your own
NonResizableEditPolicy to interpret "move" requests, and re-calculate the
new U and V values. This would imply that you have the inverse algorithm of
our ConnecitonEndpointLocator . . . good luck! Feel free to submit anything
you come up with.
> /Dag
> return list;
> return editPart;
> return labelFigure;
> > > Hi!
and
> > > String.
as
> displayed
> > > in the window.
> method
> > is
(a
> > getting
new
> > > /Dag
> > labels
> It
> list
> > of
> > could
> > > > return list;
EditPart
> > > needs
> > that
> > (the
> more
> > > > labels.
Marquee,
> > > please
> > > > > Hi,
Instead
> of
program
> > > that
> > > > > does
> > > > > > the same thing.
> > Normally,
> label
> > > has
> > > independent
> that
> > label.
> ellipse,
> > > even
> connections.
> > > That
> > > marquee
the
> > > > ellipse
to
> > the
> > > > > Ricardo
Re: Is it possible to have two figures attached to the same model? [message #59616 is a reply to message #59595] |
Wed, 29 January 2003 11:43  |
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b18v93$2lh$1@rogue.oti.com...
> Selecting just the label is useful in programs like Rational Rose, where
the
> user can say that he doesn't want to see the multiplicity label by
deleting
> it.
> Go back and read my original suggestions. Making the labels children of
the
> connection is the easiest way to do this.
To clarify "this" == what you are describing, as well as the behavior of
Rational Rose. i.e. either way.
Current Time: Mon Jul 21 21:48:22 EDT 2025
Powered by FUDForum. Page generated in 0.11821 seconds
