Home » Modeling » UML2 » [ATL][UML] set stereotyped tagged value
[ATL][UML] set stereotyped tagged value [message #477479] |
Tue, 03 June 2008 15:16 |
Ivano Messages: 35 Registered: July 2009 |
Member |
Hi all,
I have a strange problem while developing an ATL transformation using UML2.
This is a simplified version of a rule:
rule port_SAport2 {
from
s_9 : saveccm!Port
to
t_15 : UML2!Port (
name <- s_9.name,
t_16 : UML2!Component()
do {
t_15.applyStereotype(thisModule.SAportStereotype);
t_16.applyStereotype(thisModule.SAtypeStereotype);
t_15.setValue(thisModule.SAportStereotype, 'type', t_16);
So, my rule produces a stereotyped UML Port and I want to set
the value of the 'type' tagged value with t_16.
I tested the helpers and they work, the problem is that if I declare
the type of the 'SAPort' tagged value as a uml:Component everything works,
but if I declare it as a SAtype (that is another stereotype) I get an
exception (listed at the end of this message).
It seems as it does recognize only standard UML elements, and not the
Stereotypes...
I am sure that someone manages to set tagged values with stereotypes,
I hope you will help me!
Ivano
this is the Exception:
GRAVE: ****** BEGIN Stack Trace
GRAVE: message: ERROR: exception during invocation of operation
applyStereotype on UML2!Component (java method: public
org.eclipse.emf.ecore.EObject
org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereoty pe(org.eclipse.uml2.uml.Stereotype))
GRAVE: exception:
GRAVE: org.eclipse.uml2.uml.internal.impl.StereotypeImpl@f701e2 (name:
SAtype, visibility: <unset>) (isLeaf: false, visibility: public,
isAbstract: false) (isActive: false, isAbstract: false)
java.lang.IllegalArgumentException:
org.eclipse.uml2.uml.internal.impl.StereotypeImpl@f701e2 (name: SAtype,
visibility: <unset>) (isLeaf: false, visibility: public, isAbstract:
at
org.eclipse.uml2.uml.internal.operations.ElementOperations.a pplyStereotype(ElementOperations.java:1410)
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.applyStereoty pe(ElementImpl.java:501)
at sun.reflect.GeneratedMethodAccessor44.invoke(Unknown Source)
at
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.real Invoke(ASMUMLModelElement.java:614)
at
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModel.applyDelaye dInvocations(ASMUMLModel.java:552)
at
org.eclipse.m2m.atl.drivers.uml24atl.AtlUML2ModelHandler.sav eModel(AtlUML2ModelHandler.java:49)
at
org.eclipse.m2m.atl.drivers.uml24atl.AtlUML2ModelHandler.sav eModel(AtlUML2ModelHandler.java:37)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:362)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at
org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at
org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
GRAVE: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to
allow continuation after errors).
Re: [ATL][UML] set stereotyped tagged value [message #477500 is a reply to message #477479] |
Tue, 10 June 2008 14:45 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Ivano,
From the stack trace it looks like there is an exception coming from the
application of the Stereotype but you mention that the error is from the
setting of the 'type' value; is the problem with the application of the
Stereotype itself? The Element.applyStereotype() will throw
IllegalArgumentExceptions if the stereotype had previously been applied or
if the extension or definition could not be found.
In general, setting a tagged value to a Stereotype is not currently
supported since you could run into problems if the Profile gets updated.
If you are not worried about migration issues, then it should work. I
believe a defect already exists on that issue.
- James.
"Ivano" <ivanomalavolta@yahoo.it> wrote in message
news:g23n7d$cfc$1@build.eclipse.org...
> Hi all,
> UML2.
> rule port_SAport2 {
> from
> s_9 : saveccm!Port
> to
> t_15 : UML2!Port (
> name <- s_9.name,
> do {
> Stereotypes...
> Ivano
> GRAVE: exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> INFO: Execution terminated due to error (see launch configuration to allow
Re: [ATL][UML] set stereotyped tagged value [message #477503 is a reply to message #477500] |
Wed, 11 June 2008 10:02 |
Member |
Yes, you are right, but I pasted the wrong stack trace!
Do you have any suggestions on how to work out this problem?
This is the original one:
setValue on UML2!Component (java method: public void
org.eclipse.uml2.uml.internal.impl.ElementImpl.setValue(org. eclipse.uml2.uml.Stereotype,java.lang.String,java.lang.Objec t))
GRAVE: exception:
GRAVE: org.eclipse.uml2.uml.internal.impl.ComponentImpl@1ccadea (name:
DataIn, visibility: <unset>) (isLeaf: false, visibility: public,
(isIndirectlyInstantiated: true)
org.eclipse.uml2.uml.internal.impl.ComponentImpl@1ccadea (name: DataIn,
false) (isActive: false, isAbstract: false) (isIndirectlyInstantiated: true)
at
org.eclipse.uml2.uml.internal.operations.ElementOperations.s etValue(ElementOperations.java:754)
at
org.eclipse.uml2.uml.internal.impl.ElementImpl.setValue(Elem entImpl.java:306)
at
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModelElement.real Invoke(ASMUMLModelElement.java:631)
at
org.eclipse.m2m.atl.drivers.uml24atl.ASMUMLModel.applyDelaye dInvocations(ASMUMLModel.java:569)
at
org.eclipse.m2m.atl.drivers.uml24atl.AtlUML2ModelHandler.sav eModel(AtlUML2ModelHandler.java:61)
at
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:337)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:426)
at
org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:398)
at
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:42)
at
org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:759)
at
at
at
James Bruck ha scritto:
> Hi Ivano,
> Cheers,
> - James.
>> Hi all,
>> UML2.
>> rule port_SAport2 {
>> from
>> s_9 : saveccm!Port
>> to
>> t_15 : UML2!Port (
>> name <- s_9.name,
>> do {
>> Stereotypes...
>> Ivano
>> GRAVE: exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: [ATL][UML] set stereotyped tagged value [message #626690 is a reply to message #477479] |
Hi Ivano,
- James.
> Hi all,
> UML2.
> rule port_SAport2 {
> from
> s_9 : saveccm!Port
> to
> t_15 : UML2!Port (
> name <- s_9.name,
> do {
> Stereotypes...
> Ivano
> GRAVE: exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: [ATL][UML] set stereotyped tagged value [message #626693 is a reply to message #477500] |
Member |
GRAVE: exception:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
> Hi Ivano,
> Cheers,
> - James.
>> Hi all,
>> UML2.
>> rule port_SAport2 {
>> from
>> s_9 : saveccm!Port
>> to
>> t_15 : UML2!Port (
>> name <- s_9.name,
>> do {
>> Stereotypes...
>> Ivano
>> GRAVE: exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Current Time: Mon May 13 18:29:17 GMT 2024
Powered by FUDForum. Page generated in 0.04499 seconds
