Home » Archived » M2M (model-to-model transformation) » [ATL]should the passed in name be same with the package name in KM3?
[ATL]should the passed in name be same with the package name in KM3? [message #48465] Mon, 25 June 2007 01:32 Go to next message
during invoking ATL transformation programmatically,
I have a question, see following method:
public abstract ASMModel loadModel(String name, ASMModel metamodel,
InputStream in);
here,Should the passed in name be 'MonitorModel'?
The 'MonitorModel' is the package name of KM3 which is metamodel.
package MonitorModel
class ManagedNodeInfo
attribute hostName:String;
attribute ipAddress:String;
attribute machineType:String;
Re: [ATL]should the passed in name be same with the package name in KM3? [message #48671 is a reply to message #48465] Mon, 25 June 2007 04:49 Go to previous message
> InputStream in);
Obviously, the name should never be 'MonitorModel' if you are, for
instance, running the Family2Person transformation ;-).
However, if one of your source or target model is named MonitorModel,
then the name argument of *one of* the calls to loadModel may indeed be
'MonitorModel'.
Frédéric Jouault
Previous Topic:[ATL] How to?The enhaced Family2Person case [java objects transformation]
Next Topic:[ATL] Developing a plugin which executes ATL transformations
Current Time: Thu Jul 17 10:23:05 EDT 2025
Powered by FUDForum. Page generated in 0.31161 seconds
