Home » Language IDEs » PHP Development Tools (PDT) » Browser not available
Browser not available [message #48420] Thu, 30 August 2007 14:51 Go to next message
When I try and run my PHP scripts on the local server I following error
shows up in my log:
Error initializing the web browser.
Stack Trace:
org.eclipse.ui.PartInitException: Could not open a Web browser because there
are none configured. Check the Web Browser preferences.
org.eclipse.ui.internal.browser.DefaultBrowserSupport.create Browser(DefaultBrowserSupport.java:107)
org.eclipse.ui.internal.browser.WorkbenchBrowserSupport.crea teBrowser(WorkbenchBrowserSupport.java:97)
org.eclipse.php.internal.debug.core.debugger.PHPWebServerDeb uggerInitializer$1.run(Unknown
Source)
org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:155)
at org.eclipse.ui.internal.UISynchronizer$2.run(UISynchronizer. java:126)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3296)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2974)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
.... Eclipse launcher stuff
OK. So I look in Window->Web Browswer and there is nothing there. It looks
like there should be submenu because Web Browswer has a little arrow beside
it but when I hold my mouse over Web Browswer all that shows up is tiny
little white square (which I'm assuming is an empty menu). If I try and
open and iternal browser manually (Window->Show View->Internal Web
Browswer) it tells me the following:
Embedded Browser not Available.
Problem details: The embedded browser widget for this editor cannot be
created. It is either not available for your operating system or the
system needs to be configured in order to support embedded browser.
Details>> contains a large stack trace that starts with:
No more handles [Unknown Mozilla path (MOZILLA_FIVE_HOME not set)]
org.eclipse.swt.SWTError: No more handles [Unknown Mozilla path
The rest is ommited for readability. If you think it's relevant I'll post
it.
Anyway, I'm running eclipse sdk 3.3 on an x86_64 platform.
Does anyone know what I need to do to make a browser available to eclipse?
Philip
Re: Browser not available [message #48826 is a reply to message #48420] Mon, 03 September 2007 03:20 Go to previous message
Try the following steps:
1) Install XULRunner (check whether there's a package for your Linux distribution - it should be available)
2) Edit your eclipse.ini, and add the following line after "-vmargs":
-Dorg.eclipse.swt.browser.XULRunnerPath=/path/to/XULRunner
I hope this helps.
On Thu, 30 Aug 2007 14:51:20 -0400
Philip Graham <philip@lightbox.org> wrote:
> Hello,
> shows up in my log:
> Stack Trace:
> at
> at
> at
> Source)
> at
> at
> at
> it.
> Philip
Michael
Previous Topic:Milestone 3 & Voting for the PDT 1.0
Next Topic:Specifying command line arguments for php scripts
Current Time: Sat Jul 26 05:01:07 EDT 2025
Powered by FUDForum. Page generated in 0.03749 seconds
