Home » Eclipse Projects » Remote Application Platform (RAP) » RAP UI Testing (automation)
RAP UI Testing (automation) [message #48414] Wed, 19 September 2007 17:39 Go to next message
Originally posted by: just4lists.nospammail.net
------=_NextPart_000_004E_01C7FB0D.F5D62FF0
Content-Type: text/plain;
charset="iso-8859-1"
From the patch posted at http://wiki.eclipse.org/RapUITesting
writer.set("UserData", new String[] {newValue, "selenium"});
Shouldn't it be?
writer.set("UserData", new String[] {"selenium", newValue});
I'm doing some research to fix the IDs in the rendered html code (needed =
for test automation). If you have any further ideas on this, please use =
this thread to share them.
Joel Oliveira
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-1">
<META content=3D"MSHTML 6.00.6000.16527" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV><FONT face=3DVerdana size=3D2>From the patch&nbsp;posted at =
</FONT><A=20
href=3D"http://wiki.eclipse.org/RapUITesting"><FONT face=3DVerdana=20
size=3D2>http://wiki.eclipse.org/RapUITesting</FONT></A></DIV>
<DIV><FONT face=3DVerdana size=3D2></FONT>&nbsp;</DIV>
<DIV><FONT face=3DVerdana size=3D2><EM>writer.set("UserData", new =
String[]=20
{<STRONG>newValue, "selenium"</STRONG>});</EM><BR></FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>Shouldn't it be?</FONT></DIV>
String[]=20
{<STRONG>"selenium", newValue</STRONG>});</EM></FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>I'm doing some research to fix the =
IDs in the=20
rendered html code (needed for test automation). If you have any further =
ideas=20
on this, please use this thread to share them.</DIV>
<DIV><BR></DIV></FONT>
<DIV><FONT face=3DVerdana size=3D2>Best regards,</FONT></DIV>
<DIV><FONT face=3DVerdana size=3D2>Joel =
Oliveira</DIV></FONT></BODY></HTML>
------=_NextPart_000_004E_01C7FB0D.F5D62FF0--
Re: RAP UI Testing (automation) [message #48444 is a reply to message #48414] Wed, 19 September 2007 18:11 Go to previous messageGo to next message
From a post in the qooxdoo list:
> Jim Hunter schrieb:
> We just add an id to the controls we want to test using
> ctrl.setHtmlAttribute('id', 'ourID'). I understand that
> setHtmlAttribute is getting changed to setHtmlProperty (at least I
> think this is true) in the very near future.
Joel Oliveira
> "Joel Oliveira" <just4lists@nospammail.net> escreveu na mensagem
> news:fcs4vs$go5$1@build.eclipse.org...
> Shouldn't it be?
> ideas on this, please use this thread to share them.
> Best regards,
> Joel Oliveira
Re: RAP UI Testing (automation) [message #48519 is a reply to message #48444] Thu, 20 September 2007 03:55 Go to previous messageGo to next message
Hi Joel,
see comments inline:
That's what i suggested in the "Anyone from Qooxdoo on this newsgroup?"
thread. Unfortunately this is a little bit complicated as you have to
hack RAP (or register a PhaseListener) and provide some better
identifier than the existing id. Nice ideas how to say that for example
a button should be called "mytestablebutton" on the client-side? Sure
there are ways but no way which is really nice and non intrusive.
> Best regards,
> Joel Oliveira
>> Shouldn't it be?
That's right but this patch step is not needed as the id is assigned
automatically by the WidgetManager on the client-side. Just ask the
widgets for getUserData("id").
>> Best regards,
>> Joel Oliveira
Re: RAP UI Testing (automation) [message #50213 is a reply to message #48519] Thu, 27 September 2007 15:34 Go to previous messageGo to next message
Patch submitted.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=204859
Comments?
"Benjamin Muskalla" <bmuskalla@innoopract.com> escreveu na mensagem
news:fct967$jlk$1@build.eclipse.org...
> Hi Joel,
> thread. Unfortunately this is a little bit complicated as you have to hack
> RAP (or register a PhaseListener) and provide some better identifier than
> the existing id. Nice ideas how to say that for example a button should be
> called "mytestablebutton" on the client-side? Sure there are ways but no
>> Best regards,
>> Joel Oliveira
>>> Shouldn't it be?
>>> Best regards,
>>> Joel Oliveira
Re: RAP UI Testing (automation) [message #50503 is a reply to message #50213] Sat, 29 September 2007 09:40 Go to previous messageGo to next message
Originally posted by: fappel.innoopract.com
to me it seems to be a valid approach to improve the possibilities of
automated testing of RAP UIs. Benny do you agree? But I also think - as the
id generation increases the streams sent from and to the client - we should
add a system property to switch this functionality on and off (standard
would be off). This would not hurt since there is no need for human readable
ids in a non testing environment.
By the way we do not really need the w-prefix of the widgets anymore, do we
(R
Re: RAP UI Testing (automation) [message #50560 is a reply to message #50503] Tue, 02 October 2007 03:25 Go to previous message
Comments inline.
Joel Oliveira
"Frank Appel" <fappel@innoopract.com> escreveu na mensagem
news:fdlkkc$sgj$1@build.eclipse.org...
> the id generation increases the streams sent from and to the client - we
> should add a system property to switch this functionality on and off
> (standard would be off). This would not hurt since there is no need for
> human readable ids in a non testing environment.
This is true. It should be just a small amount of extra info... but I
agree... it's always extra info that is not always needed.
> we (Rüdiger?), so we could actually use only the integer values of from
> IdGenerator at generall runtime mode (beside that this would break our
> current unit tests...).
I already learned (from previous experiences _:) ) only integer values are
not such a good idea (they get messed up with the array index - never know
if you getting the widget by id or by it's position in the elements array -
but this also dependes on the implementation).
> In case we use different ids for automated UI tests, we could also use
> fully qualified names for the ids and may add some additional
> functionality like whether a button is in radio, check or push mode
> (org.eclipse.swt.widgets.button[radio]4711 as id for example).
I believe that adding the fully qualified name could be overkilling... but
button-radio-4711 looks better.
> One last thing - I think this discussion actually belongs to the rap-dev
> mailing-list. As far as I know, the eclipse-newsgroups are dedicated to
> user questions (in our case people that are developing their application
> by using rap).
Agree. I will post further discussion in the mailing-list.
> Ciao
> Frank
> "Joel Oliveira" <just4lists@nospammail.net> schrieb im Newsbeitrag
> news:fdh0kh$n7b$1@build.eclipse.org...
>> Patch submitted.
>> Comments?
>>> Hi Joel,
>>>> Best regards,
>>>> Joel Oliveira
>>>>> Shouldn't it be?
>>>>> Best regards,
>>>>> Joel Oliveira
Previous Topic:org.eclipse.rwt.clientLogLevel - how to use?
Next Topic:Performance
Current Time: Sat Jul 26 12:38:59 EDT 2025
Powered by FUDForum. Page generated in 0.06946 seconds
