Home » Archived » Test and Performance Tools Platform (TPTP) » Real UML2 models from TPTP traces
Real UML2 models from TPTP traces [message #48405] Wed, 28 December 2005 03:41
Originally posted by: jomppak.hotmail.com
We have an analysis system that reads UML sequence diagrams and applies
pattern matching techniques to it. I have used Visual Trace (found in
Rational XDE) to generate sequence diagrams from program execution, but
XDE has it's limitations (it is based on eclipse 2.0).
So, I wonder if it is possible to convert UML2 Object/Class Interactions
generated from Execution Time Analysis to reqular UML2 model files
(.uml2) with collaborations and interactions following the UML 2.0
metamodel?
Of course I can convert generated XML-based trace file, but I already
have a sequence diagram "image" on the screen - only corresponding UML
model is missing.
I have also used IBM Rational Software Architect in order to get traces.
Again, the funny thing is, that I cannot convert generated UML2 Object
Interactions to UML2 models even if both of them are located in the same
project - side by side. Or can I?
JK
Previous Topic:Using the Automated GUI Recorder for an executable-supported Eclipse plugin
Next Topic:TPTP and Java Web Start
Current Time: Mon Jul 21 23:55:29 EDT 2025
Powered by FUDForum. Page generated in 0.30105 seconds
