Home » Eclipse Projects » DTP » [ODA Ecore] URLs to identify models
[ODA Ecore] URLs to identify models [message #48396] |
Thu, 07 August 2008 16:51  |
Originally posted by: jconlon.apache.org
I have a use case where I would like to report on Ecore model instances
that reside on remote webservers.
When creating ODA Ecore DataSources, I see that models can be browsed
for (located) in the workspace and the file system ...
but could URLs be used to identify Ecore models that are located on web
servers (etc.) as well?
If not, is this a constraint based on EMF/Ecore limitations or the
present implementation of ODA Ecore?
cheers,
John
Re: [ODA Ecore] URLs to identify models [message #48480 is a reply to message #48452] |
Thu, 07 August 2008 22:19   |
Hi Ed,
The Dialog only gives a check box with two choices:
1. Use model from workspace
2. Use model form filesystem
and a text field with a browse button.
On the off chance the ODA Ecore DataSource wizard would maybe accept a
http url, I tried pasting in a URL for a model instance that is on a
http server, but got the exception:
org.eclipse.datatools.connectivity.oda.OdaException ;
org.eclipse.datatools.connectivity.oda.profile.OdaConnection Wrapper.open(OdaConnectionWrapper.java:215)
org.eclipse.datatools.connectivity.oda.profile.OdaConnection Wrapper. <init>(OdaConnectionWrapper.java:59)
org.eclipse.datatools.connectivity.oda.profile.OdaConnection Factory.createConnection(OdaConnectionFactory.java:26)
org.eclipse.datatools.connectivity.internal.ConnectionFactor yProvider.createConnection(ConnectionFactoryProvider.java:83 )
org.eclipse.datatools.connectivity.internal.ConnectionProfil e.createConnection(ConnectionProfile.java:355)
org.eclipse.datatools.connectivity.ui.PingJob.createTestConn ection(PingJob.java:76)
org.eclipse.datatools.connectivity.oda.design.internal.ui.Da taSourceWizardPageCore$1.run(DataSourceWizardPageCore.java:2 31)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
org.eclipse.datatools.connectivity.ui.wizards.ConnectionProf ileDetailsPage.testConnection(ConnectionProfileDetailsPage.j ava:194)
org.eclipse.datatools.connectivity.ui.wizards.ConnectionProf ileDetailsPage$2.widgetSelected(ConnectionProfileDetailsPage .java:131)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1158)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3401)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3033)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
org.eclipse.birt.report.designer.ui.actions.NewDataSourceAct ion.run(NewDataSourceAction.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
Caused by: java.lang.NullPointerException
at java.io.File.<init>(File.java:222)
at org.eclipse.emf.common.util.URI.createFileURI(URI.java:832)
org.eclipse.datatools.enablement.oda.ecore.impl.Connection.d ataSourceUriFromProperties(Connection.java:83)
org.eclipse.datatools.enablement.oda.ecore.impl.Connection.g etModel(Connection.java:63)
org.eclipse.datatools.enablement.oda.ecore.impl.Connection.o pen(Connection.java:52)
org.eclipse.datatools.connectivity.oda.consumer.helper.OdaCo nnection.open(OdaConnection.java:235)
org.eclipse.datatools.connectivity.oda.profile.OdaConnection Wrapper.open(OdaConnectionWrapper.java:209)
... 45 more
BTW - Welcome back from your voyage,
John
Ed Merks wrote:
> John,
> EMF itself definitely supports arbitrary URLs right at the core. Our
> Load Resource dialog allows an arbitrary URI to be entered? Of course
> there are only browse buttons for workspace and file system, but you can
> enter a URL (such as an http-based one) directly in the entry field.
> Maybe that the dialog you're already seeing?
>> instances that reside on remote webservers.
>> web servers (etc.) as well?
>> cheers,
>> John
Re: [ODA Ecore] URLs to identify models [message #48510 is a reply to message #48480] |
Fri, 08 August 2008 01:39   |
Hi John,
I definitely appreciate these use cases you are submitting and your
active interest in the project. This was certainly something we clearly
overlooked and we will add it to the backlog.
Thanks again.
-----Tim-----
> Hi Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
> at
> at
> at
> ... 45 more
> John
> Ed Merks wrote:
>> John,
>> can enter a URL (such as an http-based one) directly in the entry
>> field. Maybe that the dialog you're already seeing?
>>> cheers,
>>> John
Re: [ODA Ecore] URLs to identify models [message #48599 is a reply to message #48510] |
Fri, 08 August 2008 16:45   |
Hi Tim,
Glad to help in anyway I can.
I am very enthusiastic about the work you and Jeff Ramsdale have done
with ODA Ecore to date, as it adds the whole range of BIRT functionality
to the already powerful capabilities of EMF.
thanks again all your work,
John
Tim Myer wrote:
> Hi John,
> Thanks again.
> -----Tim-----
>> Hi Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 45 more
>> John
>> Ed Merks wrote:
>>> John,
>>> course there are only browse buttons for workspace and file system,
>>> but you can enter a URL (such as an http-based one) directly in the
>>> entry field. Maybe that the dialog you're already seeing?
>>>> browsed for (located) in the workspace and the file system ...
>>>> cheers,
>>>> John
Re: [ODA Ecore] URLs to identify models [message #49213 is a reply to message #48599] |
Fri, 22 August 2008 10:35  |
Hi John,
There is now an option on the dialog that allows entry of an arbitrary
URI. Filesystem and Workspace locations still allow browsing.
Arbitrary URIs must be entered by hand.
Let us know if this is what you had in mind. Thanks!
------Tim-------
> Hi Tim,
> John
> Tim Myer wrote:
>> Hi John,
>> clearly overlooked and we will add it to the backlog.
>> Thanks again.
>> -----Tim-----
>>> Hi Ed,
>>> a http url, I tried pasting in a URL for a model instance that is on
>>> a http server, but got the exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 45 more
>>> John
>>> Ed Merks wrote:
>>>> John,
>>>> Our Load Resource dialog allows an arbitrary URI to be entered? Of
>>>>> cheers,
>>>>> John
Re: [ODA Ecore] URLs to identify models [message #592524 is a reply to message #48396] |
Thu, 07 August 2008 17:20  |
John,
> cheers,
> John
Re: [ODA Ecore] URLs to identify models [message #592537 is a reply to message #48452] |
Hi Ed,
... 45 more
John
Ed Merks wrote:
> John,
>> cheers,
>> John
Re: [ODA Ecore] URLs to identify models [message #592541 is a reply to message #48480] |
Hi John,
Thanks again.
-----Tim-----
> Hi Ed,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 45 more
> John
> Ed Merks wrote:
>> John,
>>> cheers,
>>> John
Re: [ODA Ecore] URLs to identify models [message #592577 is a reply to message #48510] |
Hi Tim,
John
Tim Myer wrote:
> Hi John,
> Thanks again.
> -----Tim-----
>> Hi Ed,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 45 more
>> John
>> Ed Merks wrote:
>>> John,
>>>> cheers,
>>>> John
Re: [ODA Ecore] URLs to identify models [message #592840 is a reply to message #48599] |
Hi John,
------Tim-------
> Hi Tim,
> John
> Tim Myer wrote:
>> Hi John,
>> Thanks again.
>> -----Tim-----
>>> Hi Ed,
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 45 more
>>> John
>>> Ed Merks wrote:
>>>> John,
>>>>> cheers,
>>>>> John
Current Time: Mon Jul 21 23:57:00 EDT 2025
Powered by FUDForum. Page generated in 0.07544 seconds
