Home » Modeling » UML2 » Loop Node and Conditional Node
Re: Loop Node and Conditional Node [message #476388 is a reply to message #476360] |
Thu, 11 October 2007 23:21 |
kevin Messages: 22 Registered: July 2009 |
Thanks for your answer.
James Bruck wrote:
>> The conditional node consists of clauses which in turn consist of tests
>> (ExecutableNode) and bodies (ExecutableNode).
>> Loop node has tests and bodyParts.
>> You should be able to add any subtype of executable node to the tests. It
>> seems to work in the editor.
>> Are you first creating clauses' with tests?
>> Can you provide a JUnit test or exact scenario that fails? I'm not sure I
>> see the issue.
I just want to find out the test/body sections in .uml file, like:
<clause>
<body xmi:type="UML:ReadVariableAction"
xmi:id="condbody_ReadVariableAction2">
<result xmi:idref="loopbody_output"/>
<variable xmi:idref="loop_element"/>
</body>
<test xmi:type="UML:ReadVariableAction"
xmi:id="condtest_ReadVariableAction_count">
<variable xmi:idref="loop_count"/>
<result xmi:idref="condtest_OutputPin_count"/>
<outgoing xmi:idref="condtest_cf2"/>
</test>
</clause>
It seems that there is another format in it, like:
<clause xmi:id="_Dxwa4HhMEdy5av3IsZJsmg" test="_U279sHhNEdy5av3IsZJsmg"
body="_CS3lkHhNEdy5av3IsZJsmg _SGqOcHhNEdy5av3IsZJsmg"/>
There is no difference between two formats. But I still need to know
whether it is possible or not, the first format to create.
By the way, how to create xmi:id with the name of Node, like
xmi:id="ReadSelfAction" ?
>> 2. In loop node there is a loop variable, but if I try to save the
>> model, an exception about this loop variable occurs: it has no owner.
>> But everything I have added to the loop node should have gotten its
>> parent as owner automatically. How to solve this problem?
> Can you provide a stack trace for the error?
The stack trace:
org.eclipse.emf.ecore.xmi.DanglingHREFException: The object
'org.eclipse.uml2.uml.internal.impl.OutputPinImpl@178e131 (name: <unset>,
visibility: <unset>) (isLeaf: false) (ordering: FIFO, isControlType:
false) (isOrdered: false, isUnique: true, isControl: false)' is not
contained in a resource.
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.handleDanglingH REF(XMLHelperImpl.java:759)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getURIFragment( XMLHelperImpl.java:730)
at
org.eclipse.emf.ecore.xmi.impl.XMLHelperImpl.getIDREF(XMLHel perImpl.java:752)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveIDRefMany(XML SaveImpl.java:1934)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1286)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElementID(XML SaveImpl.java:2590)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:1105)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveElement(XMLSa veImpl.java:986)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveContainedMany (XMLSaveImpl.java:2291)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.saveFeatures(XMLS aveImpl.java:1464)
at
at
at
at
at
at
at
at
at
at
at
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.writeTopObject(XM LSaveImpl.java:653)
at
org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.traverse(XMLSaveI mpl.java:581)
at org.eclipse.emf.ecore.xmi.impl.XMLSaveImpl.save(XMLSaveImpl. java:253)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doSave(XMLRes ourceImpl.java:205)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:1253)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.saveOnlyIfC hangedWithMemoryBuffer(ResourceImpl.java:1083)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.save(Resour ceImpl.java:956)
at
org.eclipse.uml2.uml.editor.presentation.UMLEditor$14.execut e(UMLEditor.java:1380)
at
org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1797)
at
org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
at
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:113)
Gruss
Zengyu
Re: Loop Node and Conditional Node [message #476390 is a reply to message #476388] |
Mon, 15 October 2007 15:13 |
james bruck Messages: 1724 Registered: July 2009 |
Hi Zengyu,
Those features that are not directly owned but defined somewhere in the
model and referenced will be serialized like this ...
<node xmi:type="uml:LoopNode" xmi:id="_RtcBQHsuEdyZsKXxkoCTuw"
name="LoopNode" bodyPart="_6IAyoHsuEdyZsKXxkoCTuw"
test="_6IAyoHsuEdyZsKXxkoCTuw"/>
The actual item being referred to would be serialized like this ..
<node xmi:type="uml:ReadVariableAction" xmi:id="_6IAyoHsuEdyZsKXxkoCTuw"
name="ReadVariableAction"/>
I don't believe the first xml sample that you have listed below is properly
formatted (although possibly meaning the same thing as above)
To get and set the id's in a more friendly format you can try
UML2Util.getXMIIdentifier();
Have a look at ConvertModelAction to see how this is used.
- James.
"Zengyu Lu" <sizeluuu@gmail.com> wrote in message
news:182a74b9a29fd9e3b43935b4fce24528$1@www.eclipse.org...
>>> It seems to work in the editor.
>>> I see the issue.
> <clause>
> </body>
> </test>
> </clause>
> The stack trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Gruss
> Zengyu
Re: Loop Node and Conditional Node [message #625180 is a reply to message #476360] |
>> see the issue.
<clause>
</body>
</test>
</clause>
The stack trace:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Gruss
Zengyu
Re: Loop Node and Conditional Node [message #625223 is a reply to message #476388] |
Hi Zengyu,
- James.
>>> I see the issue.
> <clause>
> </body>
> </test>
> </clause>
> The stack trace:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Gruss
> Zengyu
Current Time: Wed May 22 02:32:24 GMT 2024
Powered by FUDForum. Page generated in 0.04526 seconds
