Home » Modeling » M2T (model-to-text transformation) » JET and JET2
JET and JET2 [message #48353] Fri, 08 August 2008 15:43 Go to next message
Hi all,
i just want to start to investigate the JET2 project. For that, i have
downloaded Eclipse Ganymede. But where can find the JET2 project? On the
Ganymede update site, I only found the JET-Plugin (Incubtaion - version
1.9.0) for the installation. Is the this the XPath-like JET-plugin?
Thx
Timothy
Re: JET and JET2 [message #48383 is a reply to message #48353] Fri, 08 August 2008 16:27 Go to previous messageGo to next message
Timothy,
It's 0.9.0 I believe. And yes, that's the one for JET2 with the xpath
support.
Timothy Marc wrote:
> Hi all,
> the Ganymede update site, I only found the JET-Plugin (Incubtaion -
> version 1.9.0) for the installation. Is the this the XPath-like
> JET-plugin?
> Thx
> Timothy
Re: JET and JET2 [message #48413 is a reply to message #48383] Fri, 08 August 2008 17:35 Go to previous messageGo to next message
Thx
Ed Merks schrieb:
> Timothy,
> support.
> Timothy Marc wrote:
>> Hi all,
>> JET-plugin?
>> Thx
>> Timothy
Re: JET and JET2 [message #48525 is a reply to message #48413] Tue, 12 August 2008 10:20 Go to previous message
Timothy:
Thanks for your interest in JET/JET2. I'm off on vacation for a week, so I
thought I'd send some links that you might find useful.
JET FAQ: http://wiki.eclipse.org/M2T-JET-FAQ
In particular, this page has links to some articles/further reading:
http://wiki.eclipse.org/JET_FAQ_What_learning_resources_are_ available_for_JET%3F
Also, you can see some real JET transformations in the Eclipse CVS
repository. These are all Eclipse projects, so you can check them out with
the Eclipse CVS client:
JET transformation backing the new JET Project wizard:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/transforms/org.eclipse.jet.transforms.newprojec t/?root=Modeling_Project
JET transformation for generating JET's tag library documentation from a
plugin.xml:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/transforms/org.eclipse.jet.transforms.taglibdoc /?root=Modeling_Project
JET transformation for building SWT wizard pages from a XML document (demo'd
at EclipseCon):
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/examples/org.eclipse.jet.ec2008.swtgen.codebehi nd/?root=Modeling_Project
There is an XSD schema for the above transformation in this project:
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.m2t/org .eclipse.jet/examples/org.eclipse.jet.examples.ec2008/?root= Modeling_Project
Hopefully, this, and the other watchers on the newsgroup will keep you busy
for the next week. I'll check on your progress/questions when I return on
the 20th.
Paul Elder
JET component lead
M2T project lead
Previous Topic:Model-To-Text-Language (MTL) Implementation
Next Topic:Mofscript doesn't show action button
Current Time: Mon Jul 21 23:57:09 EDT 2025
Powered by FUDForum. Page generated in 0.37235 seconds
