Where are Projects Stored [message #48352] |
Wed, 06 April 2005 17:00  |
Originally posted by: alex.peake.comac.com
Where is the info about Projects stored?
When I start up Eclipse it opens with the last project. In experimenting I
created a few test projects, which I messed up. Then I could not get rid
of them. I deleted the folders and started getting all sorts of error
messages.
Re: Where are Projects Stored [message #49046 is a reply to message #48352] |
Fri, 08 April 2005 04:16  |
Originally posted by: user.server.net
Alex,
If you can't remember the location of your workspace, there are two ways
of getting there:
(1) In the eclipse preferences, turn on the flag, that determins, if
eclipse should prompt you for the workspace. The dialog will default to
the last workspace used (Window | Preferences; in the tree go to
"General" | "Startup and Shutdown"; tick the "Prompt for workspace on
startup" option.)
(2) Seach for a file called "org.eclipse.ui.prefs" on your computer. It
depends on the version and OS where it is stored.
Hope this helps,
Kai
> I created a few test projects, which I messed up. Then I could not get
> rid of them. I deleted the folders and started getting all sorts of
> error messages.
FUDForum. Page generated in 0.08413 seconds
