Home » Eclipse Projects » Equinox » registering a URLStreamHandlerService as osgi service does no longer work
registering a URLStreamHandlerService as osgi service does no longer work [message #48344] Mon, 30 May 2005 02:47 Go to next message
Originally posted by: egglersim.post.ch
i have replaced the standart sun https handler with my own handler by
implementing the URLStreamHandlerService and registering it as a osgi
service:
Hashtable properties = new Hashtable(1);
properties.put(URLConstants.URL_HANDLER_PROTOCOL, new
String[]{Handler.PROTOCOL});
String serviceClass = URLStreamHandlerService.class.getName();
BundleContext context = //got it from the bundle's activator
start method;
context.registerService(serviceClass, new Handler(), properties);
it has been working fine with the 3.1 releases up to the m6 build. from
m7 on, it stopped working.
it hasn't been mentioned on any release note, any clues?
help is greatly apreciated.
cheers,
simon
Re: registering a URLStreamHandlerService as osgi service does no longer work [message #48403 is a reply to message #48344] Tue, 31 May 2005 00:11 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Hi Simon,
It looks like there was a related bug fix done in
org.eclipse.osgi.framework.internal.protocol.StreamHandlerFa ctory as you say
between M6 and M7.
http://dev.eclipse.org/viewcvs/index.cgi/org.eclipse.osgi/co re/framework/org/eclipse/osgi/framework/internal/protocol/St reamHandlerFactory.java.diff?r1=1.11&r2=1.12
In an OSGi environment built in handlers take priority over handlers from
the service registry. To make this work the implementation ends up having to
look in <system default package>.<protocol>.Handler -- this is where the
"sun.net.www.protocol" bit comes in.
Hope this helps identify the problem at least,
(another) Simon
Note: I'm no expert in this area but the "sun.net.www.protocol" isn't in the
public API -- the details of the lookup are somewhat implementation
dependent and typically buried in the java.net.URL class so this looks like
a best effort approach.
"Simon F. Eggler" <egglersim@post.ch> wrote in message
news:429ab6fc$1@news.post.ch...
> service:
> start method;
> cheers,
> simon
Re: registering a URLStreamHandlerService as osgi service does no longer work [message #48437 is a reply to message #48403] Tue, 31 May 2005 03:07 Go to previous message
Simon,
They will revert the URLStreamHandlerFactory behaviour to pre-M7, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=97175.
Simon
Simon Kaegi wrote:
> Hi Simon,
> between M6 and M7.
> (another) Simon
>>service:
>>start method;
>>cheers,
>>simon
Previous Topic:Bundles, classloaders and the Factory Pattern
Next Topic:communication with an embedded RCP
Current Time: Mon Jul 14 06:40:51 EDT 2025
Powered by FUDForum. Page generated in 0.32239 seconds
