Home » Eclipse Projects » Mylyn » Multiple Task Focus Levels
Multiple Task Focus Levels [message #48337] |
Fri, 16 May 2008 04:50  |
if I understand the context concept of Mylyn correctly, for every resource an interest is computed
and every resource which interest is above a threshold is displayed. I think this can be seen in the
Context pane of a task.
Moving the slider in the context pane shows more or less task, but does not influence the display in
the Package explorer. Does it make sense to define different thresholds (two would be OK in the
beginning) which are used in the package explorer display and could be switched easily?
In this way, you could widen your focus to move your attention to different parts of your context.
Are there any plans / RFEs to implement such a feature. Just supplying different configurable focus
thresholds seems to be a rather simple implementation.
Cheers, Jörg
Re: Multiple Task Focus Levels [message #48804 is a reply to message #48654] |
Mon, 19 May 2008 02:10   |
Hi Mik,
On 05/16/08 22:28, Mik Kersten wrote:
> In version 0.2. Mylyn used to expose exactly such a slider Package
> Explorer view. The problem is that it made the UI overly complicated.
Agreed. A slider is far too difficult to handle. I would slightly adapt the Mylyn button to
have (at least) one more state: No filtering - Wide filtering - Narrow filtering. Pressing
the button cycles through the modes, a drop down box allows to select it explicitely.
> My current sense is that the best approach would be to automate the most
> common use case via the following:
> 178891: provide adaptive interest filter to prevent scroll bar in
> navigator views
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=178891
Actually, the above use case is some sort of opposite to the one of my colleagues:
They touch a lot of different files during their work in a task context, and after they have focused
one a specific sub-set, they want to go back to the wider context with more files.
IMHO, the natural way to accomplish this without several interest thresholds would be to use
sub-task which inherit their initial context from the parent task.
So an alternative approach would be to support sub-tasks between different repositories. Esp. it
would be great if I could attach local tasks as sub-tasks to repository tasks.
Would be great if you have some ideas how we could progress here.
Thanks, Jörg
> Jörg Thönnes wrote:
>> switched easily?
>> Cheers, Jörg
Re: Multiple Task Focus Levels [message #50161 is a reply to message #48804] |
Tue, 17 June 2008 12:46  |
Jörg,
Your suggestion of supporting this by having subtasks inherit the parent
task's context is a really interesting one. We brainstormed this a
while back but have not picked it up yet. In my PhD thesis I called
these "cascading contexts". I would really like to explore this
further, so please file a new bug outlining what you've suggested and
post a link to this thread. Before filing the new bug please take a
look at the following bug, in particular the description and comment#2.
137543: support displaying task relationships and dependencies, such as
subtasks
https://bugs.eclipse.org/bugs/show_bug.cgi?id=137543
Mik
Jörg Thönnes wrote:
> Hi Mik,
>> navigator views
> Thanks, Jörg
>> Jörg Thönnes wrote:
>>> Hi,
>>> switched easily?
>>> Cheers, Jörg
Re: Multiple Task Focus Levels [message #589564 is a reply to message #48337] |
Fri, 16 May 2008 16:28  |
navigator views
Mik
Jörg Thönnes wrote:
> Cheers, Jörg
Re: Multiple Task Focus Levels [message #589605 is a reply to message #48654] |
Hi Mik,
> navigator views
Thanks, Jörg
> Jörg Thönnes wrote:
>> switched easily?
>> Cheers, Jörg
Re: Multiple Task Focus Levels [message #590109 is a reply to message #48804] |
Jörg,
subtasks
Mik
Jörg Thönnes wrote:
> Hi Mik,
>> navigator views
> Thanks, Jörg
>> Jörg Thönnes wrote:
>>> Hi,
>>> switched easily?
>>> Cheers, Jörg
Current Time: Tue Jul 22 00:41:42 EDT 2025
Powered by FUDForum. Page generated in 0.04555 seconds
