Home » Archived » BIRT » master page margins
master page margins [message #48298] Mon, 20 June 2005 15:17 Go to next message
I'm trying to find my way in BIRT (on Ubuntu Linux).
One of the problems I keep running into is that I can't set the master
page margins.
Whatever values I enter for whatever measurement unit (cm, inch, ...), I
keep getting a 'for input string ' error.
The logs tell me that this has to do with a
'java.lang.NumberFormatException', but that doesn't help me to solve this
problem.
Any help is appreciated...
Bart
Re: master page margins [message #50003 is a reply to message #48298] Wed, 22 June 2005 19:01 Go to previous messageGo to next message
Can you attach the report design file.
Did you set the margins of the master page through the property editor UI ?
--Thanks
Rima
Bart Maertens wrote:
> page margins.
> problem.
> Bart
Re: master page margins [message #50774 is a reply to message #50003] Thu, 23 June 2005 15:15 Go to previous message
Hi Rima,
I've sent the report design file to you by e-mail.
I did set the margins of the master page throught the property editor UI.
Is there another way except for directly modifying the xml file?
Thanks and best regards,
Bart
Op Wed, 22
Jun 2005 16:01:57 -0700, schreef Rima Kanguri:
> --Thanks
> Rima
>> page margins.
>> problem.
>> Regards,
>> Bart
Previous Topic:HTTP 500 error, previewing my report in the report designer
Next Topic:How do I use multiple parameters in BITR?
Current Time: Tue Jul 22 13:52:58 EDT 2025
Powered by FUDForum. Page generated in 0.05129 seconds
