Home » Eclipse Projects » Technology Project and PMC » eclipse on freebsd
eclipse on freebsd [message #48287] Thu, 06 March 2003 02:16 Go to next message
Originally posted by: p.p.com
im trying to install eclipse on free bsd...
after compiling it, i run eclipse and it goes to a splash screen that
says: "finishing the install", it stays on this splash screen indefinitely
and takes up 90% of my cpu. I left it for an hour once to no avail, so
i'm assuming that it crashes. any ideas?
Re: eclipse on freebsd [message #48513 is a reply to message #48287] Fri, 07 March 2003 06:09 Go to previous messageGo to next message
I got similiar symptoms when running the Linux-Motif build with lesstif.
Replacing lesstif with OpenMotif (which apparently implements a critical
method which lesstif only has stubbed) fixed the problem.
I would recommend checking stderr for any related error messages.
HTH,
Ian
Re: eclipse on freebsd [message #541946 is a reply to message #48287] Wed, 23 June 2010 06:36 Go to previous messageGo to next message
I am trying to install eclipse for free bsd. I am not getting any eclipse version specific to free bsd. Could you share with me what did you do to install eclipse for free bsd.
Thank You in advance
Re: eclipse on freebsd [message #542026 is a reply to message #541946] Wed, 23 June 2010 10:51 Go to previous message
I do not have an answer.
I recommend that you pose this question on the eclipse.platform forum.
HTH,
Wayne
Re: eclipse on freebsd [message #591428 is a reply to message #48287] Fri, 07 March 2003 06:09 Go to previous message
HTH,
Ian
Re: eclipse on freebsd [message #601992 is a reply to message #48287] Wed, 23 June 2010 06:36 Go to previous message
Re: eclipse on freebsd [message #602000 is a reply to message #601992] Wed, 23 June 2010 10:51 Go to previous message
HTH,
Wayne
Previous Topic:Registry refresh for Extensions
Next Topic:AJDT is not working in eclipse
Current Time: Tue Jul 22 09:04:42 EDT 2025
Powered by FUDForum. Page generated in 0.05150 seconds
