Home » Eclipse Projects » Mylyn » ctrl+f12 in java perspective does not work
ctrl+f12 in java perspective does not work [message #48275] |
Thu, 15 May 2008 05:55  |
Hi All,
When editing a file, Ctrl+F12 (the shortcut to open a mylyn task) works
for me in any other perspective but 'Java perspective'. This is rather
strange.
Is this a bug, a known issue or a feature?
Alexey
Re: ctrl+f12 in java perspective does not work [message #48863 is a reply to message #48568] |
Tue, 20 May 2008 12:26   |
Mik,
Thanks for the response.
I see Mylyn's bindings there: Ctrl+F12, Ctrl+Shift+F12, =
Ctrl+Alt+Shift+F12. I don't see any conflicts. And none of these binding=
s =
work in Java perspective for me and work well in other perspectives.
I've checked 'keys' section in Preferences: typed 'F12' in the filter =
input field, and saw no conflicts, only the 3 shortcuts mentioned above =
and the standard F12 'Activate Editor'.
I don't see any messages in the error log either. Only the following one=
which I suppose does not relate to the issue:
!MESSAGE Conflict for 'org.eclipse.ui.navigate.selectWorkingSets':
HandlerActivation(commandId=3Dorg.eclipse.ui.navigate.select WorkingSets,=
handler=3DActionDelegateHandlerProxy(null,org.eclipse.ui.int ernal.actio=
ns.SelectWorkingSetsAction),
expression=3DAndExpression(ActionSetExpression(org.eclipse.u i.WorkingSe=
tActionSet.toolbar,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),Work=
benchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)),=
sourcePriority=3D16640)
tActionSet,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),WorkbenchWin=
dowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)),sourcePr=
iority=3D16640)
What/where else could I check? Should I provide the list of plugins =
installed for someone to try reproduce the issue? I will definitely try =
create another installation of Eclipse and check if the problem is prese=
nt =
there.
Any help in figuring out the reason will be appreciated. I use Mylyn in =
my =
day-to-day work, and this issue is a real pain.
Alexey
On Sat, 17 May 2008 00:23:07 +0400, Mik Kersten <mik.kersten@tasktop.com=
wrote:
> Please hit Ctrl+Shift+L to inspect your keybindings, as there could be=
a =
> conflict. I have verified that it works by default in the Java =
> Perspective.
> Mik
> Alexey Semenov wrote:
>> Hi All,
>> When editing a file, Ctrl+F12 (the shortcut to open a mylyn task) =
>> works for me in any other perspective but 'Java perspective'. This is=
>> rather strange.
>> Thanks,
>> Alexey
Re: ctrl+f12 in java perspective does not work [message #48923 is a reply to message #48863] |
Wed, 21 May 2008 03:22   |
Now I've checked and it appears, that the same Eclipse works well on bot=
h =
another workspace and on a new specially created workspace.
So the issue is specific to my workspace.
Could you please suggest me what actions to take now? I definitely can =
simply migrate to a new workspace as there's not so much tuning, but I =
think it'l more interesting and useful for us to try to find the root =
cause of my trouble =3D)
Best,
Alexey
On Tue, 20 May 2008 20:26:45 +0400, Alexey Semenov <alexeysem@gmail.com>=
wrote:
> Mik,
> Ctrl+Alt+Shift+F12. I don't see any conflicts. And none of these =
> bindings work in Java perspective for me and work well in other =
> perspectives.
> input field, and saw no conflicts, only the 3 shortcuts mentioned abov=
e =
> I don't see any messages in the error log either. Only the following =
> one, which I suppose does not relate to the issue:
> HandlerActivation(commandId=3Dorg.eclipse.ui.navigate.select WorkingSet=
s,
> handler=3DActionDelegateHandlerProxy(null,org.eclipse.ui.int ernal.act=
ions.SelectWorkingSetsAction),
> expression=3DAndExpression(ActionSetExpression(org.eclipse.u i.Working=
SetActionSet.toolbar,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),Wo=
rkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)=
),sourcePriority=3D16640)
s,
SetActionSet,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),WorkbenchW=
indowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)),source=
Priority=3D16640)
> installed for someone to try reproduce the issue? I will definitely tr=
y =
> create another installation of Eclipse and check if the problem is =
> present there.
> Any help in figuring out the reason will be appreciated. I use Mylyn i=
n =
> my day-to-day work, and this issue is a real pain.
> Alexey
> On Sat, 17 May 2008 00:23:07 +0400, Mik Kersten =
> <mik.kersten@tasktop.com> wrote:
>> Please hit Ctrl+Shift+L to inspect your keybindings, as there could b=
e =
>> a conflict. I have verified that it works by default in the Java =
>> Perspective.
>> Mik
>>> Hi All,
>>> works for me in any other perspective but 'Java perspective'. This i=
s =
>>> rather strange.
>>> Thanks,
>>> Alexey
Re: ctrl+f12 in java perspective does not work [message #50132 is a reply to message #48923] |
Tue, 17 June 2008 12:40  |
First try: Window -> Reset Perspective
Then: Window -> Preferences -> Keys -> Restore Defaults
That should reset all your keybindings as well as the commands available
in the perspective. I added a note to:
http://wiki.eclipse.org/Mylyn/User_Guide#Key_Mappings
Mik
> both another workspace and on a new specially created workspace.
> cause of my trouble =)
> Best,
> Alexey
> wrote:
>> Mik,
>> perspectives.
>> above and the standard F12 'Activate Editor'.
>> HandlerActivation(commandId=org.eclipse.ui.navigate.selectWo rkingSets,
>> handler=ActionDelegateHandlerProxy(null,org.eclipse.ui.inter nal.actions.SelectWorkingSetsAction),
>> expression=AndExpression(ActionSetExpression(org.eclipse.ui. WorkingSetActionSet.toolbar,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)),sourcePriority=16640)
>> expression=AndExpression(ActionSetExpression(org.eclipse.ui. WorkingSetActionSet,org.eclipse.ui.internal.WorkbenchWindow@15c40eb),WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@15c40eb)),sourcePriority=16640)
>> try create another installation of Eclipse and check if the problem is
>> present there.
>> in my day-to-day work, and this issue is a real pain.
>> Thanks,
>> Alexey
>>> be a conflict. I have verified that it works by default in the Java
>>> Perspective.
>>> Mik
>>>> Hi All,
>>>> is rather strange.
>>>> Thanks,
>>>> Alexey
Re: ctrl+f12 in java perspective does not work [message #589534 is a reply to message #48275] |
Fri, 16 May 2008 16:23  |
Please hit Ctrl+Shift+L to inspect your keybindings, as there could be a
conflict. I have verified that it works by default in the Java Perspective.
Mik
> Hi All,
> strange.
> Alexey
Re: ctrl+f12 in java perspective does not work [message #589629 is a reply to message #48568] |
Mik,
s =
iority=3D16640)
nt =
there.
my =
Alexey
a =
> Perspective.
> Mik
>> Hi All,
>> rather strange.
>> Thanks,
>> Alexey
Re: ctrl+f12 in java perspective does not work [message #589654 is a reply to message #48863] |
h =
Best,
Alexey
wrote:
> Mik,
> perspectives.
e =
s,
s,
Priority=3D16640)
y =
> present there.
n =
> Alexey
e =
>> Perspective.
>> Mik
>>> Hi All,
s =
>>> rather strange.
>>> Thanks,
>>> Alexey
Re: ctrl+f12 in java perspective does not work [message #590098 is a reply to message #48923] |
Mik
> Best,
> Alexey
> wrote:
>> Mik,
>> perspectives.
>> present there.
>> Thanks,
>> Alexey
>>> Perspective.
>>> Mik
>>>> Hi All,
>>>> is rather strange.
>>>> Thanks,
>>>> Alexey
Current Time: Tue Jul 22 09:04:18 EDT 2025
Powered by FUDForum. Page generated in 0.45176 seconds
