Home » Modeling » M2T (model-to-text transformation) » Load UML model in JET
Load UML model in JET [message #48264] Thu, 07 August 2008 12:50 Go to next message
How can I load an RSA UML model into JET without having to convert it to
an .ecore? I read that I can use the org.eclipse.jet.emf model loader to
load either an EMF or UML based model but I keep get an exception when I
try to load it.
Re: Load UML model in JET [message #48294 is a reply to message #48264] Thu, 07 August 2008 14:03 Go to previous messageGo to next message
Hi I was looking around the forumns and I just wanted to clarify that I'd
like to use an RSA .emx file as my input. I'm not sure if this is
possible, but any help would be great.
Re: Load UML model in JET [message #48324 is a reply to message #48294] Fri, 08 August 2008 07:20 Go to previous message
> Thanks
Roshan:
The RSA .emx file format is an XMI serialization derived from EMF/ecore -
JET can load it just like any other EMF-base model. You don't even have to
set a model loader.
Incidentally, the main difference between an .emx file and a .uml2 file is
that the .emx file may contain embedded diagrams (within EAnnotations). I
think an .emx file may also have some additional profiles applied.
Paul
Previous Topic:XML extraction problem
Next Topic:MTL Project - first evaluation
Current Time: Tue Jul 22 02:30:53 EDT 2025
Powered by FUDForum. Page generated in 0.25037 seconds
