How to implement constraint for group of objects? [message #48256] |
Fri, 01 September 2006 12:39  |
I have a constraint on model objects and relations between them. Check
process needs to traverse over all model elements and is quite expensive.
I want to implement AbstractModelConstraint which will perform such
validation which will be executed only once during validation
session(another way is to execute such constraint on every model element).
If I run validation on root element then it will occure only once during
validation session but I can create resulting failure status only for
current element(root of my model actually), not for each model element
violating the constraint. Any ideas how to implement such validation?
Re: How to implement constraint for group of objects? [message #49052 is a reply to message #48720] |
Thu, 07 September 2006 11:33  |
Hi Yury,
The get/putCurrentConstraintData should allow you to pass information
for later retrieval in the same validation session. This should allow
you to structure your constraint so that it will not report the same
failure on all of the objects that constitute the failure in the same
validation session.
To answer your most recent question, yes, the AbstractModelConstraint is
designed to validate many distinct objects. The same constraint may be
called to validate numerous objects that are instances of the EClass
referenced in the declaration of the constraint in the plugin.xml.
I hope this helps,
Chris McGee
Yury wrote:
> Ed,
> I guess you are talking about EValidator but my question was about
> AbstractModelConstraint from EMF.Validation framework which is
> independent of EValidator. AbstractModelConstraint is not passed a
> context map and that is the main problem. Theoretically I can implement
> EValidator for my model package but this approach is less flexible than
> use of EMF.Validation because in case of EValidator I will need to
> implement all constraints in single class.
> It seems for me that AbstractModelConstraint is designed to validate
> separate element without any knowledge about context where it is placed,
> is it true?
Re: How to implement constraint for group of objects? [message #587070 is a reply to message #48256] |
Fri, 01 September 2006 14:26  |
--------------050001080805010302090803
Yury,
I assume you've ready The EMF Validation Framework Overview
< http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF .Validation.html>?
I'd expect you just to have a named constraint on some type of object,
and as that object is visited, your specialized method would check the
constraint and create a diagnostic if it's violated. This should allow
you to create a diagnostic per instance that violates the constraint.
> expensive. I want to implement AbstractModelConstraint which will
> perform such validation which will be executed only once during
> validation session(another way is to execute such constraint on every
> model element). If I run validation on root element then it will
> occure only once during validation session but I can create resulting
> failure status only for current element(root of my model actually),
> not for each model element violating the constraint. Any ideas how to
<html>
<head>
http-equiv="Content-Type">
</head>
Yury,<br>
<br>
I assume you've ready <a
href=" http://dev.eclipse.org/viewcvs/indextools.cgi/*checkout*/org .eclipse.emf/doc/org.eclipse.emf.doc/references/overview/EMF .Validation.html">The
EMF Validation Framework Overview</a>?
Re: How to implement constraint for group of objects? [message #587121 is a reply to message #48286] |
Mon, 04 September 2006 11:25  |
Ed,
I've read validation The EMF Validation Framework Overview and have
already implemeted some constraints. Following your suggestion I will need
to run call method on every object which can violate the constraint. But
every time I call that method it will have to traverse all objects in the
model. It may result in great performance hit. I think that I can cache
result in a constraint while processing model root(assuming it is
processed berfore other elements) and afterwards reuse that calculated
result while validating model elements. But I do not want to keep that
cache between validation sessions. Can I get know when validation session
is finished?
Re: How to implement constraint for group of objects? [message #587129 is a reply to message #48404] |
Mon, 04 September 2006 11:40  |
Yury,
You can use the context Map to cache information/state during
validation. A new such map is created for each session.
Yury wrote:
> Ed,
> need to run call method on every object which can violate the
> constraint. But every time I call that method it will have to traverse
> all objects in the model. It may result in great performance hit. I
> think that I can cache result in a constraint while processing model
> root(assuming it is processed berfore other elements) and afterwards
> reuse that calculated result while validating model elements. But I do
> not want to keep that cache between validation sessions. Can I get
> know when validation session is finished?
>> object, and as that object is visited, your specialized method would
>> check the constraint and create a diagnostic if it's violated. This
>> should allow you to create a diagnostic per instance that violates
>> the constraint.
Re: How to implement constraint for group of objects? [message #590220 is a reply to message #48424] |
Tue, 05 September 2006 07:21  |
I can see only map in IValidator (it has put/getClientData methods) but
AbstractModelConstraint does not have access to IValidator. What map do
you mean?
Ed Merks wrote:
> Yury,
Re: How to implement constraint for group of objects? [message #590241 is a reply to message #48634] |
Tue, 05 September 2006 08:07  |
--------------050505030702030006080608
Yury,
A named constraint "A" on an EClass Library would generate something
like this in the generated validator:
public boolean validateLibrary_A(Library library, DiagnosticChain
diagnostics, Map context)
So I'm answering EMF basic validation questions but you are asking more
general EMFT validation framework questions. I imagine this get and put
for client data can be used to accomplish the same goal...
> but AbstractModelConstraint does not have access to IValidator. What
> map do you mean?
> Ed Merks wrote:
>> Yury,
<html>
<head>
<title></title>
</head>
Yury,<br>
<br>
like this in the generated validator:<br>
<blockquote>
Re: How to implement constraint for group of objects? [message #590251 is a reply to message #48692] |
Tue, 05 September 2006 09:31  |
Ed,
AbstractModelConstraint from EMF.Validation framework which is independent
of EValidator. AbstractModelConstraint is not passed a context map and
that is the main problem. Theoretically I can implement EValidator for my
model package but this approach is less flexible than use of
EMF.Validation because in case of EValidator I will need to implement all
is it true?
Re: How to implement constraint for group of objects? [message #590399 is a reply to message #48720] |
Hi Yury,
validation session.
I hope this helps,
Chris McGee
Yury wrote:
> Ed,
> is it true?
FUDForum. Page generated in 0.11732 seconds
