Home » Archived » XML Schema Definition (XSD) » xsdComplexType
xsdComplexType [message #48167] Mon, 21 June 2004 14:02 Go to next message
Originally posted by: bikeev.gmx.net
How can a complex type defined in schema_A be copied into the schema_B.
There is an example showing how to do it on the schema elements but I am
failing to do the same for complex types.
Thomas
Re: xsdComplexType [message #48213 is a reply to message #48167] Mon, 21 June 2004 14:24 Go to previous messageGo to next message
Thomas,
What did you try that failed?
> Thomas
Re: xsdComplexType [message #48242 is a reply to message #48213] Mon, 21 June 2004 14:43 Go to previous messageGo to next message
Hello Ed,
I have a ArrayList complexTypeDefinitions containing all the
XSDTypeDefinitions from initial schema.
I create a new schema and looping through ArrayList trying to write
the complexTypes out:
//create new schema
XSDFactory xsdFactory = XSDFactory.eINSTANCE;
XSDSchema newSchema = xsdFactory.createXSDSchema();
newSchema.getQNamePrefixToNamespaceMap().putAll(oldSchema.ge tQNamePrefixToNamespaceMap());
for (Iterator iterator = complexTypeDefinitions.iterator();
iterator.hasNext();) {
XSDTypeDefinition xsdTypeDefinition = (XSDTypeDefinition)
iterator.next();
((XSDSchema) newSchema).getContents().
add((XSDComplexTypeDefinition)
xsdTypeDefinition.cloneConcreteComponent(true, false));
newSchema.updateElement();
resource.getContents().add(newSchema);
resourceSet.getResources().add(resource);
resource.save(Collections.EMPTY_MAP);
I am getting:
org.w3c.dom.DOMException: HIERARCHY_REQUEST_ERR: An attempt was made to
insert a node where it is not permitted.
- Thomas
Ed Merks wrote:
> Thomas,
>>Thanks,
>>Thomas
Re: xsdComplexType [message #48272 is a reply to message #48242] Mon, 21 June 2004 14:51 Go to previous messageGo to next message
Thomas,
If you could send me a zipped up project that I can run to reproduce this problem, I'll have a
close look. Or at least show me the stack trace so I can see what's happening when the
failure strikes...
exquisitus wrote:
> Hello Ed,
> //create new schema
> iterator.next();
> I am getting:
> - Thomas
> Ed Merks wrote:
> > Thomas,
> >>Thanks,
> >>Thomas
Re: xsdComplexType [message #48302 is a reply to message #48272] Mon, 21 June 2004 14:59 Go to previous messageGo to next message
Thanks Ed,
here is the trace - otherwise I will cut down the project using
XSDPrototypicalSchema.html and try to reproduce.
- Thomas
org.apache.xerces.dom.ParentNode.internalInsertBefore(Parent Node.java:413)
at org.apache.xerces.dom.ParentNode.insertBefore(ParentNode.jav a:322)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.forceNiceInser tBefore(XSDConcreteComponentImpl.java:1547)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.niceInsertBefo re(XSDConcreteComponentImpl.java:1478)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.handleElementF orAdopt(XSDConcreteComponentImpl.java:1331)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:360)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:361)
org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:352)
at Reader.main(Reader.java:88)
at com.intellij.rt.execution.application.AppMain.main(Unknown Source)
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #48331 is a reply to message #48272] Mon, 21 June 2004 15:30 Go to previous messageGo to next message
Ed - please find Example and Exception below:
- Thomas
import org.eclipse.xsd.XSDSchema;
import org.eclipse.xsd.XSDComplexTypeDefinition;
import org.eclipse.xsd.XSDFactory;
import org.eclipse.xsd.util.XSDPrototypicalSchema;
import org.eclipse.xsd.util.XSDResourceImpl;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.common.util.URI;
import java.util.Collections;
import java.io.IOException;
public class ComplexTypeTest {
public static void main(String[] args) throws IOException {
//get complex type from PO schema
XSDSchema po = XSDPrototypicalSchema.getPurchaseOrderSchema();
XSDComplexTypeDefinition poType =
po.resolveComplexTypeDefinition("PurchaseOrderType");
//create new schema
ResourceSet resourceSet = new ResourceSetImpl();
Resource resource = new XSDResourceImpl(URI.createURI("test.xsd"));
//clone complex types
((XSDSchema)
newSchema).getContents().add(poType.cloneConcreteComponent(t rue, false));
//add newSchema to the ressource and then save
System.exit(0);
Exception:
at ComplexTypeTest.main(ComplexTypeTest.java:39)
Exception in thread "main" Process terminated with exit code 1
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #48362 is a reply to message #48331] Mon, 21 June 2004 16:59 Go to previous messageGo to next message
Thomas,
I haven't had a chance to look closely, but I noticed that you haven't choosen a schema for schema
namespace for the new XSD. Doing that no doubt will help...
> - Thomas
> //create new schema
> ((XSDSchema)
> System.exit(0);
> Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Thomas,
> > failure strikes...
> > exquisitus wrote:
> >>Hello Ed,
> >>//create new schema
> >>iterator.next();
> >>I am getting:
> >> - Thomas
> >>Ed Merks wrote:
> >>>Thomas,
> >>>>Thanks,
> >>>>Thomas
Re: xsdComplexType [message #48421 is a reply to message #48362] Mon, 21 June 2004 17:50 Go to previous message
Ed -
many thanks - worked like spell !!!
- Thomas
Ed Merks wrote:
> Thomas,
Re: xsdComplexType [message #589442 is a reply to message #48167] Mon, 21 June 2004 14:24 Go to previous message
Thomas,
> Thomas
Re: xsdComplexType [message #589458 is a reply to message #48213] Mon, 21 June 2004 14:43 Go to previous message
Hello Ed,
//create new schema
iterator.next();
I am getting:
- Thomas
Ed Merks wrote:
> Thomas,
>>Thanks,
>>Thomas
Re: xsdComplexType [message #589468 is a reply to message #48242] Mon, 21 June 2004 14:51 Go to previous message
Thomas,
failure strikes...
exquisitus wrote:
> Hello Ed,
> //create new schema
> iterator.next();
> I am getting:
> - Thomas
> Ed Merks wrote:
> > Thomas,
> >>Thanks,
> >>Thomas
Re: xsdComplexType [message #589479 is a reply to message #48272] Mon, 21 June 2004 14:59 Go to previous message
Thanks Ed,
- Thomas
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #589486 is a reply to message #48272] Mon, 21 June 2004 15:30 Go to previous message
- Thomas
//create new schema
((XSDSchema)
System.exit(0);
Exception:
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #589496 is a reply to message #48331] Mon, 21 June 2004 16:59 Go to previous message
Thomas,
> - Thomas
> //create new schema
> ((XSDSchema)
> System.exit(0);
> Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Thomas,
> > failure strikes...
> > exquisitus wrote:
> >>Hello Ed,
> >>//create new schema
> >>iterator.next();
> >>I am getting:
> >> - Thomas
> >>Ed Merks wrote:
> >>>Thomas,
> >>>>Thanks,
> >>>>Thomas
Re: xsdComplexType [message #589514 is a reply to message #48362] Mon, 21 June 2004 17:50 Go to previous message
Ed -
- Thomas
Ed Merks wrote:
> Thomas,
Previous Topic:Re: EMF, SDO & XSD Update Site (was Re: EMF Update Site)
Next Topic:Re: EMF/SDO/XSD Update Site
Current Time: Tue Jul 22 01:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.04669 seconds
