xsdComplexType [message #48167] |
Mon, 21 June 2004 14:02  |
Originally posted by: bikeev.gmx.net
How can a complex type defined in schema_A be copied into the schema_B.
There is an example showing how to do it on the schema elements but I am
failing to do the same for complex types.
Thomas
Re: xsdComplexType [message #48362 is a reply to message #48331] |
Mon, 21 June 2004 16:59   |
Thomas,
I haven't had a chance to look closely, but I noticed that you haven't choosen a schema for schema
namespace for the new XSD. Doing that no doubt will help...
exquisitus wrote:
> Ed - please find Example and Exception below:
> - Thomas
> import org.eclipse.xsd.XSDSchema;
> import org.eclipse.xsd.XSDComplexTypeDefinition;
> import org.eclipse.xsd.XSDFactory;
> import org.eclipse.xsd.util.XSDPrototypicalSchema;
> import org.eclipse.xsd.util.XSDResourceImpl;
> import org.eclipse.emf.ecore.resource.ResourceSet;
> import org.eclipse.emf.ecore.resource.Resource;
> import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
> import org.eclipse.emf.common.util.URI;
> import java.util.Collections;
> import java.io.IOException;
> public class ComplexTypeTest {
> public static void main(String[] args) throws IOException {
> //get complex type from PO schema
> XSDSchema po = XSDPrototypicalSchema.getPurchaseOrderSchema();
> XSDComplexTypeDefinition poType =
> po.resolveComplexTypeDefinition("PurchaseOrderType");
> //create new schema
> ResourceSet resourceSet = new ResourceSetImpl();
> Resource resource = new XSDResourceImpl(URI.createURI("test.xsd"));
> XSDFactory xsdFactory = XSDFactory.eINSTANCE;
> XSDSchema newSchema = xsdFactory.createXSDSchema();
> //clone complex types
> ((XSDSchema)
> newSchema).getContents().add(poType.cloneConcreteComponent(t rue, false));
> //add newSchema to the ressource and then save
> newSchema.updateElement();
> resource.getContents().add(newSchema);
> resourceSet.getResources().add(resource);
> resource.save(Collections.EMPTY_MAP);
> System.exit(0);
> Exception:
> org.w3c.dom.DOMException: HIERARCHY_REQUEST_ERR: An attempt was made to
> insert a node where it is not permitted.
> at
> org.apache.xerces.dom.ParentNode.internalInsertBefore(Parent Node.java:413)
> at org.apache.xerces.dom.ParentNode.insertBefore(ParentNode.jav a:322)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.forceNiceInser tBefore(XSDConcreteComponentImpl.java:1547)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.niceInsertBefo re(XSDConcreteComponentImpl.java:1478)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.handleElementF orAdopt(XSDConcreteComponentImpl.java:1331)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:360)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:361)
> at
> org.eclipse.xsd.impl.XSDConcreteComponentImpl.updateElement( XSDConcreteComponentImpl.java:352)
> at ComplexTypeTest.main(ComplexTypeTest.java:39)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:324)
> at com.intellij.rt.execution.application.AppMain.main(Unknown Source)
> Exception in thread "main" Process terminated with exit code 1
> Ed Merks wrote:
> > Thomas,
> > If you could send me a zipped up project that I can run to reproduce this problem, I'll have a
> > close look. Or at least show me the stack trace so I can see what's happening when the
> > failure strikes...
> > exquisitus wrote:
> >>Hello Ed,
> >>I have a ArrayList complexTypeDefinitions containing all the
> >>XSDTypeDefinitions from initial schema.
> >>I create a new schema and looping through ArrayList trying to write
> >>the complexTypes out:
> >>//create new schema
> >> newSchema.getQNamePrefixToNamespaceMap().putAll(oldSchema.ge tQNamePrefixToNamespaceMap());
> >> for (Iterator iterator = complexTypeDefinitions.iterator();
> >>iterator.hasNext();) {
> >> XSDTypeDefinition xsdTypeDefinition = (XSDTypeDefinition)
> >>iterator.next();
> >> ((XSDSchema) newSchema).getContents().
> >> add((XSDComplexTypeDefinition)
> >>xsdTypeDefinition.cloneConcreteComponent(true, false));
> >>I am getting:
> >> - Thomas
> >>Ed Merks wrote:
> >>>Thomas,
> >>>What did you try that failed?
> >>>>Thanks,
> >>>>Thomas
Re: xsdComplexType [message #48421 is a reply to message #48362] |
Mon, 21 June 2004 17:50  |
Ed -
many thanks - worked like spell !!!
- Thomas
Ed Merks wrote:
> Thomas,
Re: xsdComplexType [message #589442 is a reply to message #48167] |
Mon, 21 June 2004 14:24  |
Thomas,
> Thomas
Re: xsdComplexType [message #589458 is a reply to message #48213] |
Mon, 21 June 2004 14:43  |
Hello Ed,
//create new schema
iterator.next();
I am getting:
- Thomas
Ed Merks wrote:
> Thomas,
>>Thanks,
>>Thomas
Re: xsdComplexType [message #589468 is a reply to message #48242] |
Mon, 21 June 2004 14:51  |
Thomas,
failure strikes...
exquisitus wrote:
> Hello Ed,
> //create new schema
> iterator.next();
> I am getting:
> - Thomas
> Ed Merks wrote:
> > Thomas,
> >>Thanks,
> >>Thomas
Re: xsdComplexType [message #589479 is a reply to message #48272] |
Mon, 21 June 2004 14:59  |
Thanks Ed,
here is the trace - otherwise I will cut down the project using
XSDPrototypicalSchema.html and try to reproduce.
- Thomas
at Reader.main(Reader.java:88)
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #589486 is a reply to message #48272] |
Mon, 21 June 2004 15:30  |
- Thomas
//create new schema
((XSDSchema)
System.exit(0);
Exception:
Ed Merks wrote:
> Thomas,
> failure strikes...
> exquisitus wrote:
>>Hello Ed,
>>//create new schema
>>iterator.next();
>>I am getting:
>> - Thomas
>>Ed Merks wrote:
>>>Thomas,
>>>>Thanks,
>>>>Thomas
Re: xsdComplexType [message #589496 is a reply to message #48331] |
Thomas,
> - Thomas
> //create new schema
> ((XSDSchema)
> System.exit(0);
> Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Ed Merks wrote:
> > Thomas,
> > failure strikes...
> > exquisitus wrote:
> >>Hello Ed,
> >>//create new schema
> >>iterator.next();
> >>I am getting:
> >> - Thomas
> >>Ed Merks wrote:
> >>>Thomas,
> >>>>Thanks,
> >>>>Thomas
Re: xsdComplexType [message #589514 is a reply to message #48362] |
Ed -
- Thomas
Ed Merks wrote:
> Thomas,
FUDForum. Page generated in 0.33378 seconds
