Home » Archived » Service Component Architecture (SCA) Tools » Re: AnnValidator missing from Ganymede Update
Re: AnnValidator missing from Ganymede Update [message #4206] |
Thu, 09 October 2008 08:10  |
Originally posted by: atoulme.intalio.com
Brian, please open a bug with those stacktraces, a reference to this
newsgroup thread, and the version numbers of the STP plugins in your
workspace.
Crossposting to SCA Tools newgroup as one of the exceptions is about the
SCA plugins.
Antoine
Brian wrote:
> I should be more specific. The error in my fist post occurred after I
> removed the annValidator.jar from the plugins directory and restarted
> eclipse. With the jar in the plugins directory, the log shows the
> following at startup:
> eclipse.buildId=M20080911-1700
> java.version=1.6.0_06
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
> !MESSAGE A handler conflict occurred. This may disable some commands.
> !SUBENTRY 1 org.eclipse.ui.workbench 2 0 2008-10-08 15:01:48.806
> !MESSAGE Conflict for 'org.eclipse.gmf.ValidateAction':
> HandlerActivation(commandId=org.eclipse.gmf.ValidateAction,
> handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.eid. datamodel.diagram.part.CimeroEditorValidateAction),
> expression=WorkbenchWindowExpression(org.eclipse.ui.internal.WorkbenchWindow@107c615),sourcePriority=16384)
> handler=ActionDelegateHandlerProxy(null,org.eclipse.stp.sca. diagram.part.SCADiagramValidateAction),
> And then when I go to my JAX-WS project, right click on the annotated
> class I wish to make a webservice from and then choose "JAX-WS
> Tools">"Create Web Service" I see:
> !ENTRY org.eclipse.osgi 2 0 2008-10-08 15:05:05.150
> !MESSAGE The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for
> bundle org.eclipse.stp.sc.sca.java is invalid
> !STACK 0
> org.osgi.framework.BundleException: The activator
> org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
> at
> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy.loadAnnotationResolver(AnnotationSupportProxy.java:91)
> at
> org.eclipse.stp.sc.common.annotations.ext.AnnotationSupportP roxy. <clinit>(AnnotationSupportProxy.java:58)
> at
> org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAnnotationClassesForJavaElement(ScAnnotationSupportUti ls.java:188)
> at
> org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForClass(ScAnnotationSupportUtils. java:54)
> at
> org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getAvailableAnnotationsForType(ScAnnotationSupportUtils.j ava:87)
> at
> org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.isAnnotationValidForMember(ScAnnotationSupportUtils.java: 175)
> at
> org.eclipse.stp.sc.common.annotations.ScAnnotationSupportUti ls.getDefaultedAnnotationNode(ScAnnotationSupportUtils.java: 146)
> at
> org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.initializeFromDefault(AnnotationAttributePage.java: 211)
> at
> org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createAttributeGroup(AnnotationAttributePage.java:1 82)
> at
> org.eclipse.stp.sc.jaxws.wizards.annotations.AnnotationAttri butePage.createControl(AnnotationAttributePage.java:126)
> at org.eclipse.jface.wizard.Wizard.createPageControls(Wizard.ja va:170)
> at
> org.eclipse.jface.wizard.WizardDialog.createPageControls(Wiz ardDialog.java:669)
> at
> org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:543)
> at
> org.eclipse.stp.sc.jaxws.wizards.ScWizardDialog.createConten ts(ScWizardDialog.java:43)
> at org.eclipse.jface.window.Window.create(Window.java:431)
> at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
> at org.eclipse.jface.window.Window.open(Window.java:790)
> at
> org.eclipse.stp.sc.jaxws.actions.CreateWebServiceAction.run( CreateWebServiceAction.java:63)
> at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:583)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:500)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2382)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2346)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:21 98)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:493)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:488)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
> Caused by: java.lang.ClassNotFoundException:
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:481)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:139)
> ... 56 more
> Root exception:
> java.lang.ClassNotFoundException: org.eclipse.stp.sc.sca.java.ScaJavaPlugin
> at
> And when I right click on the root of my JAX-WS project and go to
> "JAX-WS Tools">"Generate WSDL" I see:
> !ENTRY org.eclipse.osgi 2 0 2008-10-08 15:07:39.556
> org.eclipse.stp.sc.annvalidator.AnnValidatorPlugin for bundle
> org.eclipse.stp.sc.annvalidator is invalid
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.internal.events.BuildManager.instantiateBui lder(BuildManager.java:788)
> at
> org.eclipse.core.internal.events.BuildManager.initializeBuil der(BuildManager.java:741)
> at
> org.eclipse.core.internal.events.BuildManager.getBuilder(Bui ldManager.java:480)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:199)
> at
> org.eclipse.core.internal.events.BuildManager$1.run(BuildMan ager.java:253)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:256)
> at
> org.eclipse.core.internal.events.BuildManager.basicBuild(Bui ldManager.java:218)
> at
> org.eclipse.core.internal.events.BuildManager.build(BuildMan ager.java:360)
> at
> org.eclipse.core.internal.resources.Project.internalBuild(Pr oject.java:516)
> at org.eclipse.core.internal.resources.Project.build(Project.ja va:94)
> at
> org.eclipse.stp.sc.jaxws.actions.AssignedJava2WsdlAction.run (AssignedJava2WsdlAction.java:41)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 50 more
> Root exception:
> So what I am doing so wrong that I am missing all these classes?
> Thanks!
Re: AnnValidator missing from Ganymede Update [message #4276 is a reply to message #4206] |
Thu, 09 October 2008 08:47   |
Hi Antoine, Brian,
Sorry, I don't think that SCA Tools is involved in your problem.
> org.osgi.framework.BundleException: The activator org.eclipse.stp.sc.sca.java.ScaJavaPlugin for bundle org.eclipse.stp.sc.sca.java is invalid
This error is coming from the Service Creation component (stp.sc).
This component contains (old) tools for SCA developpers but it doesn't
form part of the SCA Tools project.
However, you discovered a conflict between the Cimero Editor and the SCA
Composite Designer. This message is just a warning and is not related
with the before-mentioned exception.
Thanks ;)
Stéphane Drapeau
Obeo
Re: AnnValidator missing from Ganymede Update [message #4346 is a reply to message #4276] |
Thu, 09 October 2008 10:51  |
Stephane Drapeau wrote:
> Hi Antoine, Brian,
OK.
> Thanks ;)
Aha! I did something useful today. What a nice feeling!
> Stéphane Drapeau
> Obeo
Re: AnnValidator missing from Ganymede Update [message #573660 is a reply to message #4206] |
Hi Antoine, Brian,
Thanks ;)
Stéphane Drapeau
Obeo
Re: AnnValidator missing from Ganymede Update [message #573689 is a reply to message #4276] |
> Hi Antoine, Brian,
OK.
> Thanks ;)
> Stéphane Drapeau
> Obeo
Current Time: Mon Jul 21 21:03:07 EDT 2025
Powered by FUDForum. Page generated in 0.04957 seconds
