Home » Eclipse Projects » Equinox » Running without the URL Handlers Service
Running without the URL Handlers Service [message #48030] Mon, 16 May 2005 00:33 Go to next message
Originally posted by: weyford.sympatico.ca
In the org.eclipse.osgi.framework.internal.core.Framework
initialize(FrameworkAdaptor)
two singleton operations get called:
1) URL.setURLStreamHandlerFactory(...)
2) URLConnection.setContentHandlerFactory(...)
If a factory has been previously set for either the framework fails to
initialize.
I understand that these two calls both have to succeed in order to provide
an OSGi URL Handlers Service (at least in R3).
My question is can Eclipse be modified reasonably to run without these
calls?
In the environment in which I'm running these singleton operations may have
been called already.
I have a working prototype in which I've fixed up a few "reference:" URLs
that were being created from String but to be honest don't know all the
repercussions.
Is "bundleresource:" or "bundleentry:" used to create URLs by string
anywhere?
What is "platform:" used for -- I see it mentioned in the odd bug report --
are there plans for it?
Thanks.
-Simon
Re: Running without the URL Handlers Service [message #48062 is a reply to message #48030] Mon, 16 May 2005 00:38 Go to previous messageGo to next message
Originally posted by: skaegi.sympatico.ca
Correcting sender info.
-Simon
"Weyford" <weyford@sympatico.ca> wrote in message
news:d6989j$q3a$1@news.eclipse.org...
> initialize.
> calls?
have
> repercussions.
> anywhere?
report --
> Thanks.
> -Simon
Re: Running without the URL Handlers Service [message #48092 is a reply to message #48062] Mon, 16 May 2005 20:41 Go to previous messageGo to next message
Originally posted by: pascal.ibm.canada
You could probably find a way around the bundle urls.
However the platform urls are APIs and some plugins might construct them
directly and use them to access data.
Therefore you might be able to run but it is unclear how far you could go.
HTH,
PaScaL
> -Simon
>>initialize.
>>calls?
> have
>>repercussions.
>>anywhere?
> report --
>>Thanks.
>>-Simon
Re: Running without the URL Handlers Service [message #48200 is a reply to message #48092] Tue, 17 May 2005 14:12 Go to previous message
Hi Pascal,
Thanks for your reply.
What if the URL creation changes were restricted to just org.eclipse.osgi
and org.eclipse.core.runtime -- I really just want the non-UI basics.
In this way the eclipse core could still initialize without necessarily
calling the singleton operations. I don't believe that externally the API
would be affected.
I'm not sure what might be the best way to control whether the ops get
called but certainly a flag/property would work or perhaps there is a
better way(?)
I'd be pleased to volunteer to do this work (even just for a prototype) if
you think it's feasable/reasonable.
You mentioned the platform URL as being API...
Is there a way to create a "platform" URL other than by spec (and the
default URLStreamHandlerFactory)?
Is "reference" also considered API?
-Simon
Previous Topic:Eclipse OSGi performance issue
Next Topic:fragment.xml or plugin.xml
Current Time: Sat Jul 26 07:37:53 EDT 2025
Powered by FUDForum. Page generated in 0.05785 seconds
