Home » Archived » Visual Editor (VE) » seeing the invisible
seeing the invisible [message #47983] |
Tue, 06 July 2004 14:33  |
Originally posted by: mb.thomas-daily.de
==may be my pattern is of interest to other users==
public final class DesignTimeHelper
* If <code>Beans.isDesignTime()</code> you
* usually want to see "invisible" GUI elements.
* Tested with <code>JButton</code> and
* <code>JFormattedTextField</code>.
public static void setVisibleDT (JComponent c, boolean visible)
assert Beans.isDesignTime ( );
if (!visible)
Border in = c.getBorder ( );
Border out = BorderFactory.createLineBorder (Color.CYAN, 2);
c.setBorder (BorderFactory.createCompoundBorder (out, in));
==example how to use it==
public class BasicButton extends JButton
* @see javax.swing.JComponent#setVisible(boolean)
public void setVisible (boolean visible)
if (Beans.isDesignTime ( ))
DesignTimeHelper.setVisibleDT (this, visible);
else
super.setVisible (visible);
==cheers!==
Marcus Beyer
Re: seeing the invisible [message #48964 is a reply to message #48783] |
Wed, 07 July 2004 13:19   |
--------------020307060008090302050307
Content-Type: text/plain; charset=us-ascii; format=flowed
Paul Mischler wrote:
> http://www.dfki.uni-kl.de/km/java/java/tutorial/swing/exerci ses/
Ah, thank you. This is how the dashed version looks like.
I atached a small screenshot: three elements are "invisible".
One of them is selected. Only tested on XP. I am curious how
it looks like on OS X.
Comments please :-) Maybe to discuss: should VE do that job?
import java.awt.*;
import java.beans.*;
import java.util.*;
import javax.swing.*;
import javax.swing.border.*;
private static Map borders = new HashMap ( );
* @param c
* @param visible
if (visible)
* set default border
Border defaultBorder = (Border) borders.get (c);
if (defaultBorder != null)
c.setBorder (defaultBorder);
else
* set dashed border
Border defaultBorder = c.getBorder ( );
borders.put (c, defaultBorder);
if (defaultBorder instanceof LineBorder)
LineBorder lb = (LineBorder) defaultBorder;
c.setBorder (new DashedBorder (lb.getLineColor ( ), 1));
return;
Insets oldInsets = defaultBorder.getBorderInsets (c);
Insets halfInsets = new Insets (oldInsets.top / 2,
oldInsets.left / 2,
oldInsets.bottom / 2,
oldInsets.right / 2);
Border halfBorder = new EmptyBorder (halfInsets);
Border dashedBorder = new DashedBorder (Color.GRAY, 1);
Border newBorder = new CompoundBorder (dashedBorder,
halfBorder);
newBorder = new CompoundBorder (halfBorder, newBorder);
c.setBorder (newBorder);
class DashedBorder implements Border
Color color;
int thickness;
int dashWidth;
int dashHeight;
public DashedBorder ( )
this (Color.black, 1);
public DashedBorder (Color color, int thickness)
this (color, thickness, thickness * 2, thickness * 2);
int thickness,
int dashWidth,
int dashHeight)
assert thickness > 0;
assert dashWidth > 0;
assert dashHeight > 0;
this.color = color;
this.thickness = thickness;
this.dashWidth = dashWidth;
this.dashHeight = dashHeight;
public void paintBorder (Component c,
Graphics g,
int x,
int y,
int width,
int height)
Insets insets = getBorderInsets (c);
g.setColor (color);
int numWide = (int) Math.round (width / dashWidth);
int numHigh = (int) Math.round (height / dashHeight);
int startPoint;
for (int i = 0; i <= numWide; i += 2)
startPoint = x + dashWidth * i;
g.fillRect (startPoint, y, dashWidth, thickness);
y + height - insets.bottom,
dashWidth,
thickness);
for (int i = 0; i <= numHigh; i += 2)
startPoint = x + dashHeight * i;
g.fillRect (x, startPoint, thickness, dashHeight);
g.fillRect (x + width - insets.right,
startPoint,
thickness,
dashHeight);
public boolean isBorderOpaque ( )
return false;
public Insets getBorderInsets (Component c)
return new Insets (thickness, thickness, thickness, thickness);
Content-Type: image/png;
name="VE_invisible.png"
Content-Disposition: inline;
filename="VE_invisible.png"
iVBORw0KGgoAAAANSUhEUgAAAa4AAAKMCAIAAAA8G8ttAAAgAElEQVR4nOy9 e3wU1f3//57Z
ABUEoQRC/QjZgBcu8YJiLQhmI0p3pVq1ARX9ektsQa21dgP2q22Cxd9HSLRI pWDd9fa1XjD1
CiaisItcbCVKWyIEUHcFqwkJGrGgJLtzfn/M7uzs3HZ2M3tJ8no+9gGz73mf c97n7Mw773Nm
5j1ce2szAQBM06//wCFDRx/uONDVeTTbtgDL4LNtAAAAZB+4QgCSACFhbyUv 2wakC47jFALF
Jkc6CgZ7YzJF7Qr1+L1cfOtyhfj/4gpwcV8VbSk7o1exfFO2Rz0WpFYys1dh mrIN7RHWsDG+
LU5zr45N8vY0FFRtabWg+LmUv2a8JQQ/2Cvpta6QMaYQKDYVuwEAfRlMkAEA ID4q9Ps2ZcsO
AADIIjFX6PdtKqu7JIumgO5QV/aGo7Qk21YAy/D7NuEHzSQRV+j3bZr78k94 W3aNAakz9+Wf
rKG1OHkASI1YVGizKa+UAQBAHyHmCnkerhAA0EcxigoXFq3WLLMsMD+NFgGr 2fbU1ZryaTc8
n2FLAMhZEkyQq24oJPuNcsnixYvn0KKXbMvSbRmwirDAXXLXdoVwX8Mvtz11 NbwhACKyCbJN
6x7DeD9IRIWFhVU3FFL1wlf616bTMEA3D/ytuPH40f81FhoTZhp/5PoPGj5u /FR4QwBEYu7P
ZuMUH4Wqw+F3OPxFRUU3VvuJ6PJOt7pIDn3sg/61ZNAFPbd+G0dEDy1/7KHl j9088Lei5OaB
vxUlZn4viRDjBEbi54Mvvj5z/l/u+rO//6Dh/QYNHzv+Rxs816bjwMoyB+rm XF13INtWgB5E
Eq5QpKSk5Mknn7zpppvURfJseQ8uHn5o8cDp6XQQefaBOxYPnC5urBp+KPYZ +qBdbgxxRJxc
WaPU4F+kbIZYv45tVrlCkYeWP3bDgLtvGHC36AST+r2IKBTmBIEJApM/jDji rNtPOr+qaNaf
QvEx45yC8fnRT9U2cweRWb/zn2eujlUufuYsXpacz1K0lVaXB3/al+jWFWRl kdEDLqTOd6j/
FYXf/SN9RxDPiU1zPEcHv7tiybfvxvZxPB+v9p9vf7iESFRWlzpvUMvvB+6O qyFpM+KWFf7z
ndicJc8zPissoztvEd2f3AnedectzwrLeNNtdDFOEB+7lj13LYSJiIijLiH+ RyxdsuP5stFE
dKBuzpTxVS83L56WqIHRZS+ammT/z3XPN18n1lxJD4mt5DJm+wV6A/KokFd8 1Np2+5Mcx914
441Vvip1kWnn9KOmzvVttgvP6SdKeNuANSuGtawY1rJi2Jofqb4WDnwv8vX4 ChvPFw5873cD
p4kFxe3Cge/9buDSX8hr6Lf0xu+NGfm9l1cMe+8SG3EcF29DrM7K743hOC5S p3YpvjH0zkjb
JBs/7fIhLRFLhiwtjLQubzeuZlGH5xSt8z86vmXFsJbfDZymWeGK4ytiY3J8 hUpHPf42G/8C
V3vXnbfIf4K77rzlBa5WU1nvNw6HxQ8TBJmQsbBAIYFCYZ0/gaPLXmxcsmtF 3QEiOlAXjRYr
njlARHTg2YpIZHd13QEpeoqpxeTPLDaMMcWyB+rmXL2s6mpRLRI8RvRVTWuj qSarVrfCmJHL
tsor3LYs0gt5Z6UiMeX3qgqWbVXrgJ5GEhPkTZtKqx3BQKCq2hG8keipp56K 17ddfjrn/7fw
9M7QmNP7T7VxNpvtgf87kHv+8Bj34THuw9d9oPja/4XfDPj0+cNj3IfL/LYl t/TPs3FEHB+Z
fka2acSAsTsPj3EfHvN86IKLj5tmE3731879bZ1l7sPT32I0YsBLfzzhP+Ln /x431Rarc8zy
zv1iDcTxilLRVqb99HsXtLFmG9f4xhHRqjHPsxtc/fNU7U619X/hN7bHRJ3l 4dLrj5smszYy
O/7gW6lRZYVfHHtsV78fn8fZbFzeef0v2BV6WqWTcJps8EsZT5C7BD4UcXwx XxgKU5gJgsA6
9VwhEY0eM9H3yX56r2rKJ3e2Nre3Nrc3Ol+trDtwoO6uX5/6amtze2vzqxM+ 2R/Rfq9qyr0T
XxbVlpSKMt+9+y5ubm9tbn/55pUrDCebvr2n1DS3v3zzyiuqqEbSVzVNRL57 J0sOd8q9vkjT
KjV5taIBVyzbqlPhvoub21sXni+3Z9pCqRej53naxSIvn3rn4+/R6LI7b318 vehYt/lX3uo4
X60DehryK8jap4TD4b+xmvxPPhkIVBUVLa66gex2ctjpiaqSmxafULjwsKjG TuxfyoV+/QXH
fdG1+eoBl43mtlP/Uq7z1zs48Xk+dqLiq83eHvm6/V+hA7/qd+NbAscR2Tie iHHEcUQcce2d
D+/geBuxVuEAR2TjOHGXuNHeWVZzrDFqKhs9QKozVoO61Ij+dbX9iYjE4jaO O3HAll/1j8zX
2oUfqtsdbbNT3h9qh/wh0lRoIhezVoJJrSgqtIWebgr94cx+/I7Q9WfyT68P 8TaOqXQaScmV
x+6ST41JnCnfectLAx4y9fMSEVGXwIXDjCgu816YMY4RIxZmiWbaB/bvosdX Fjwe/X7z/tGO
iXTvTwvo1daF51ctpAN1y0W10iUPKWbTpUsqRMnosaXGrZQ6S0YT0djS0rGR Dc2maWxsCk+R
uba2Wly1RNMct9FfAtvGalZYYbwIcKBuTsTnEpWOPUA/PP/im3/61nuLp/1w 61t7l9+8UFMn
16f/IB5TD949WU2bNj1V7SgJPFFSdNOmqhtK/EQOO1XdUOI/7tIDnWuJ6JzJ eaPz+bql/cUi
9sm2vH8TEfE2LvJks03/q42IiFNJeA0Jl6faiD05rV9DXKn2zrkPdb4fKcLZ Tuzvvz3P/8h/
qz8nOrG//2rNduNLEdGJ/W9RtC4pjx6wRVkhl/fPzv93Yf8bbNzFI0IrWjnb aHWj8VUR/fTo
ryU/KE6TY+uGd97y6sA/6v1eCkIhLszYp98c+X++2HtswmEijnGMOkP6JQ/s 31U6toIozvsQ
EdH5rc2L6b2qgvE/pZtfbRxLRHTgE5/kgCxE0bTodlNWS0ozqjBnSsNPG5tf HB31vEQ07drl
K/66lWj9bmfFaB0d0KNIPEGufpKI6IYbbnjST/4gBZ4oWfzUpmCQ/EGy28ke tIvKl03kt/7t
yKm/O3Lq746c+rfQ6In9zm0Nb6L+vzonWqHyK9ufH/l67pl5o5vDz/Ec5fMT bVEJcTwvm4RK
25Iar5yi2lrZ/vy8y07SqsGgFM9Re3hdq2G7MmttCntOGuD//773f+RCdYU2 zmZj63bzs67P
K9wd/qdmo/oT3rvuvGXt4OVrBy+XrxuanyB3Mj4cJiJq+vf+je/8a+YZp/72 2ulhQZwycyHd
qPC9qin3TryjbPToMRN993rkK30H6qqe/Q/RDxe3blheujcgTkenOW7zNWyy dplM3XTKatv8
K0udJdMSacatA0aJhpYHNjdE4j76n5LL9q5f7N912dTRujqgJyG/gqx9Sjjs Dr+fNm3ifE9U
EUW8oRgb2u301FNPnfb7VURUQqFF/47Uwf4tbP1Zv0v/J3RfXejt+YP2/oyI aOtL396s+Lpa
+hpeXCXwJCza8r1n/zComujAnvCB6OVgnud5Iha5YsvzraHH9xxX/Ye88j1h yrc9/4d+UUvZ
X1d/d/NLbM+tg65T1yAvRYyX97Y19Pih48R69NsVZNYStYfm1UV0OJ4j4ji5 cmuXqkKeJ9rx
oTBmPvf4c8TzvFajGj+A6PveOGGFuOuNE1ZQ1Bvq/V5qwmFOEOjE4wb99sYZ RDRxVH6YESPi
BCJOUF5B9t07ueBeIiKavryx+brRRPTDxY1L5kwZny8qlC7Z8fwY+vXM/F8T EZX+ccOLo999
lYjoh4tf9udPGX9nVM2keYaomq5JUi3WnZtfbS0bTWSuQhmjy+6cMF6spPTW m6Vp/ugZzl2/
/uTO1v8x0AE9CE58+afft+n3e65X7JvLljocDumrw+EQ3R8ROewkesMg2beP 1X5UuQ/Czui3
awa7dmXon9lo/b7TntZM0rXygYrrF73FiOOIEXHSuwzE/55ZevGtd3ssNmXb svy3HO1VP7S4
2mTp5l0725blrxi7I0s3/SBfYYYxXCsM0RNPPCF9e+KJJ2666aaqG0qI6Mkg Vd1QsvipTacv
eRNJDomIEb/6nn7nE3vW07lTteqXXQTGef73x+LLlSRfyFHEF9qU78NKna2L x//0z+Lmza+2
ZtsPdov3qgquX0nTlzcuxNWPPkIsKvxD4EYzBYZ+N8setD/11FM33HDDP8f/ Jb3WgWT4XdGT
iCN6DYgKM4w8KjS19vTNoLd3TqKzl3l2Rq6XAgBAjwdZrAEAAFmsAQAAUWEv A69v7U3g18wk
cIW9h4cP/TzbJgDQU7EkmxQAAPRs8hTfXy7bo1Za/WjdPb+7x6AWjovclAMA AD0RRIUAAABX
CAAAcIUAAEBwhQAAQHCFAABAcIUAAEBwhQAAQOr7CoEZ8gvGZ9sEAPoKmbln Ga4wRXBLOQAZ
IGNhBybIAAAAVwgAAHCFAABAWCvsPmfNf96M2j9XX51uSwAAKQNXaAH+mqvE DT6CzWbLs9ls
eXl5NpuN522Tbnw4uxYCAIzBBNky9Pyg+Xe3AwCyBc5SazDwgzyvfDNgfsF4 +ac77aZcPIWC
5ouY0bT2JgnzLRpo4nbRvgwmyBZg7Ac1o0L5bYn5BeN7012KJrvTm7oMegGI Ci3A2A+anyAr
4kQpilFI5MoKNXUNmhUqGjXTuqKsXkirVjauX92EZuVmJIqx0iul11DCmBH0 bhAVWoCxH9R0
hfJTToyP5MGUtK3ekNPe2izJDcoa1GNSWdwwVlablLB+hYLeXjMSA2vlu4x7 0cvCc5AUcIUW
YOwHzU+Q1SFJsmem2tOZaVeP7vsFY2MUmprBr3xXe2uz5t8DTWvlFeqBGBBI wBVagLEf5Diz
E2TLQ5KEni6TcZD5hvT8XVLWKoK+bpoEej1YK7QAYz/IcUm/YDq1cMbAU+RU +KNnvJ5Q2qUZ
6FkS+uXU+ICsgKjQAlLwg+q1Qvl5rufR5FNFxeKa2muYr9CkstSWSWVNyxVF 1D1Sa5qRGLSo
dqAGvcByYZ8FrtACkvWDBmev3lf1ipjiaolmnSlUaKCsWdygUYMKjS1PQWJ+ rAx6ASfYl4Er
tAA8V5cy6ugYgKwAV9hdkGehO8D9gRwBl00AAACuEAAA4AoBAIDgCgEAgOAK AQCA4AoBAIDg
CgEAgOAKAQCA4AoBAIDgCgEAgOAKAQCA4AoBAIDgCgEAgOAKAQCAkKQrZZAC HoDeBFxhiiDR
HgAZIGMxBybIAAAAVwgAAHCFAABAcIWWk9rSBi7CAJBd4ApzAlyEASC7wBVm gvyC8eJHIaFo
PKj4V/669yyYC0DfAzfTpM6b630KyY9nlarV8gvGS0GfuC1J1J5Ovqu9tVke LaqbA6AXM++6
+YcO7slYc3CF3WLedfPlX5P95US3qJCYbAuAXsyzz6zOcItwhd0lY3+4MvkX EoC+BtYKswmW
AgHIERAVWo/cwYnrfZJEnP9KEvUEWV0VLi4DkAHgCi1G03OphQqJ5CINJACA 9AFXmAUUYWMW
LQEAiMAVZgG4PwByDVw2AQAAuEIAAIArBAAAgisEAACCKwQAAMIVZAByCkEI dx3rDIdDjLGs
GBDqPJaZhvL6DxA3OI7jOOL5vH4D+vO8LTOta9iTrYZ7GX9a+2m2TQDZ55c/ KexmDV3HOjme
f3Tdx2s2f7Tvsw5LrMpxCoYNvPz8sYuvO0cIC3CFvYHqm2dl2wSQTaofX9/9 SgQhtHrdx3tb
Oh9bdE3JWWO7X2HusyvYWv34+j+9tvtXV0zKohlYKwQgt1iz+aNbr5h2wZlF rG8woXDErVdM
XfPOXputXxaHHVEhADkEY7Tvs44LzrQzJjBGRNlZMcwkjLHzTi3Y91kHb+sX DmVopVINXCEA
OQTHERGFw0JfcIJERMS6Oju7Or8jIk7sfJaAKwQg5xCEcB9xhYwxIRwKh0LZ NgSuMJ0o/sqx
LN0ewXFchptWt5iCDcZFLGkiZxGEMBH1BW/IGBNYWBDgCns78pMzK+eq2GhP dBMJDe6JnTIN
k/2baQYOHHL06OFMtcainywDV5gdpIBROpkVPkutYFyKkok61fp6EnVbim21 AeK2gZ8y6Jpi
BPSakIrrtWJmoMx0OXuwLF4zOXLk64yNgHQdOTPNGYCbabKAeFqKyCfRipNf oWBcSiE007q6
5oRtmakwchLr+0GDrum1lVQfzQxUN7ucbhhjMi+RgEGDThg06ARxQy6Rf5Wr GeuYqcd8K6bJ
7ngTISpMN/KTKuEPrqmQWimpdRZ1TOoASl0wtUPSwgOZ6bghvSZM9kstz4mT Tx9m+OdEzuDB
w7755isiOv74oWIRSSIKpb3yDQMdqWljHTOtmOxpjvhCuML0ovcbG8cdco/Q zaMk6wFOutH0
hqn1OpfGKqm1QkZE33zz5eDB3xe3Bw8ept4rq80aHTM1mDMea4V9GPOxXjcv DsjrSbmSnoVi
TdN8wVyITUTMR4UKNXH78OFDBlVZpWOmBjPG50hUiLXCLKN5rlrithQ+VD33 VLdifrWx++ZZ
WLPetDplO7P+Z4Mxsx9JeciQ4eK2vPiQIcMVEmt1zOw135HsgqgwCySc/2oq mJ81GweSTHU1
1kCip2byWormQl43azbuVMq1WbgoYQVmJ8hff91+wgnDoxv5REySiEKtqizQ MVODmX5igtwn
MPZHxhKTl1A0pyR60yuFQlL26NVgYEBCNZMGGDehWYN5A3LzWkpSE+SOjjZF EVEi/ypVJW13
U8dkDSZ6KuTIBBmuEGSfpK6z9wUYMxsoDR06Utru6DiYC+FVcjDGBIGRQERE eAYZ9G3g/hSE
uroYMYr4BiMH0d72uaxU9h9fSwpGTAiHujqPhbq6iIiDKwQAROEKhg3c+dFn 40YdLzCBIy7r
13DSB2NMEMKhrq59n3cUDBvI2/KoK2vGwBUCkEPwNtvl08bWrPnHNTOKzhk7 LHGBngwjRox9
1PLNqvq9ZRecwiN1a+/AknzuoI/Tr1+/+2/+0cOv7LxvzT/7zrtN5pSctnT+ rCy+2ITgCq2i
++/3AYCIbHn9eVu/hVdP/+11F3Icz2V8AY239c9MQ0K4U2qT44gx9u3RQ0YF 0gxcIQA5BGNC
OHQsi3nt+yx42gQAABAVdo9nn1mdbRMAABYAV5g6866bn20TAADWAFeYOocO 7sm2CQAAa4Ar
TJH8gvHZNgEAYBlwhSnS3tqcbRMA6P1kLObAFWQAAIArBAAAuEIAACC4QgAA ILhCAAAguEIA
ACC4QgAAILhCAAAguEIAACA8bZIyePAOgN4EXGGK4ME7ADIAHrwDAIDMAVcI AABwhQAAgLVC
y5EvbWRrPTG/YDyWMgFICrhC65HcEFwSAD0FTJAzQX7BePFjXqLYpd7W1Jck 8n8BAAlBVJg6
b673KSQ/nlWqVpPHhuK2GYmiuKZQsa3ekBdRWwtALjPvuvmZfH0QXGG3ULz0 TvzlpFhM8keK
6EyStLc2K3QUEsX82njGbTwZx/v5QA8i86/VhSvsLuo/XAb+S+El5bvUknTb CQCQwFph5lCv
A0rBoFpC8YGhZpAIALAKRIVpRz75VWyQ1iTajL9LqK+5wggA0AOu0GI0XY9i FqypZlxQrWDw
1aAVAIAmmCADAABcIQAAwBUCAADBFQIAAMEVAgAAwRUCAADBFQIAAOG+QgBy CkEIdx3rDIdD
jLGsGBDqPJaZhvL6DxA3OI7jOOL5vH4D+vO8LTOta9iTrYZ7GX9a+2m2TQBZ 45c/KbSqqq5j
nRzPP7ru4zWbP9r3WYdV1eYyBcMGXn7+2MXXnSOEBbjC3kD1zbOybQLIAtWP r7ewNkEIrV73
8d6WzscWXVNy1lgLa85ZdgVbqx9f/6fXdv/qiklZNANrhQDkFms2f3TrFdMu OLOI9Q0mFI64
9Yqpa97Za7P1y+KwIyoEIIdgjPZ91nHBmXbGBMaIKDsrhpmEMXbeqQX7Puvg bf3CoQytVKqB
KwQgh+A4IqJwWOgLTpCIiFhXZ2dX53dExImdzxJwhQDkHIIQ7iOukDEmhEPh UCjbhsAVphPF
XzmWpdsjOI7LcNOZb7E75KC1ghAmor7gDRljAgsLAlxhb0d+jmXllBMbzcGz HRjCZP9mmoED
hxw9ejhTrbHoJ8vAFWYHKWCUPJTCZ6kVjEtRMlGnWl9Pom5Lsa02QNxWOF89 O012Uy3UNEZh
mKb9CoVc/QvBsnjN5MiRrzM2LNJ15Mw0ZwBupskC4tkoIp9EK/yLQsG4lEJo pnV1zQnbMlNh
5CRWHdwmW0mq7wlNSjjC2V2q14MxJvMSCRg06IRBg04QN+QS+Ve5mrGOmXrM t2KabI84osJ0
Iz/TEv7gmgqplZJaZ1HHpJ4jqwumdkiaLJVCcwYDIvVI/W+yNuSgN2Q6f07U DB487JtvviKi
448fKhaRJKJQ2ivfMNCRmjbWMdOKyZ7miC+EK0wver+x8eknPz+7eZTk4Hku R22eZt8tHJAe
QlJrhYyIvvnmy8GDvy9uDx48TL1XVps1OmZqMGc81gr7MOYDom5e8ZDXk3Il aUKxxifJNftu
1YD0CMxHhQo1cfvw4UMGVVmlY6YGM8bnSFSItcIso+mhLHFbCpehngmqWzG/ 2piaPWZ2mR8Q
+YzYzOw4WauyCGNmP5LykCHDxW158SFDhisk1uqY2Wu+I9kFUWEWSDjd6+Yk 0dgpMNWVXAOJ
nprJaymKsM6gXXlz3Z8gmx/h3FwrND9B/vrr9hNOGB7dyCdikkQUalVlgY6Z Gsz0ExPkPoGx
PzKWmLyEojkl0ZteqSeb5u3Rq8HAAHUlJk0yf/nIoJT5Ec6F2ZmCpCbIHR1t iiKiRP5Vqkra
7qaOyRpM9FTIkQkyXCEAOQdjZgOloUNHStsdHQdzIbxKDsaYIDASiIgIzyCD 3k4u/NnvQYS6
uhgxivgGIwfR3va5rFT2H19LCkZMCIe6Oo+FurqIiIMrBABE4QqGDdz50Wfj Rh0vMIEjLieX
Mq2BMSYI4VBX177POwqGDeRtedSVNWPgCgHIIXib7fJpY2vW/OOaGUXnjB2W uEBPhhEjxj5q
+WZV/d6yC07hkbq1d2BtYnfQN+nXr9/9N//o4Vd23rfmn33n3SZzSk5bOn9W Fl9sQnCFVmHh
i35AX8aW15+39Vt49fTfXnchx/FcxhfQeFv/zDQkhDulNjmOGGPfHj1kVCDN wBUCkEMwJoRD
x7KY177PgqdNAAAAUWH3ePaZ1dk2AQBgAXCFqTPvuvnZNgEAYA1whalz6OCe bJsAALAGuMIU
yS8Yn20TAACWAVeYIu2tzdk2AYDeT8ZiDlxBBgAAuEIAAIArBAAAgisEAACC KwQAAIIrBAAA
gisEAACCKwQAAIIrBAAAwtMmKYMH7wDoTcAVpggevAMgA+DBOwAAyBxwhQAA AFcIAABwhekg
v2C8/JP51jNTj6hgoIYrS6AHgcsm1iNdUckvGN+Lr66IXevFHQR9CkSF6ULu B+XxkbQtxYwK
ifyrXM1kKYWano4ZiaKeFKzVLKiQGHcQoSXIDIgKU+fN9T6F5MezSk2WlRyl 3JWow0nFRjdL
JSUxuWF+b8Jx0OygvKx6wEEvZt518zP5+iC4wm6heOmd9MuZnxqL5798Q7HX ZKn21mZJWV1K
UbNmKXWjxrvMWJtwHBJ2UA5eMdh3yPxrdeEKu4tVf7j0JtQJUQdiejrJljLA pLWKeLOb4BWD
IH1grdB6DE5+vXU0Y4lBPfKJpFqoV1CzVFIGpKZsvgiWCEGGQVRoMerFfnES qp7PJtxQY6ys
nr1KF3kVOmYkxpixVq6pOQhmqrUwqATAALhCizFY/NLb0NORK5gppVfWTCnj IsZ16llr0GXz
HYQfBJkBrjA7KMLGtJbqQfT6DoKcBa4wO6R2nvd679DrOwhyFlw2AQAAuEIA AIArBAAAgisE
AACCKwQAAMIVZKvA0xEAWEK27iKAK7QM3AgCQDfJYkiBCTIAAMAVAgAAXCEA ABDWCtNKW8e3
7+5uXf/+/sa9rVNOLZh1zpipEwpGDD0u23YBAJQgKkwLAmPv7Pz8knte//vu tp/NmPTWsuvm
lp6xfd9Xl9zz+js7PxcYy7aBAIA4EBWmhS1NX7zg/+SBW0qnF4/hed5ms11w RlHp5JMv+dH4
FzbuJKILTj8x2zYCAGIgKrSeto5vf7N6y5UzTpP8IM/bxH8dZ42dd9FZv1m9 pa3jW3mRhPcQ
ZOAmA7xhDvRl4Aqt593drRefUyT6wS6uy3fYf9POm1498Nq34W95ni89++RL p096d3drUnVm
4KZF3BcJ+jJwhdaz/v39F58zVowH3/3v3+uOvXg078jSXQ+89slrPG/jef4n Uyesf3+/ZtmE
bxmWdsmLGLx92GBb3YQiMDSwwaBdAHoicIXW07i3dcppJ4oz4mcOPHPoyy+P HD363bGu2vdq
eJ7nOG5qsb1xr0ZUqHgpsPx9IAodxas/NDUVRfTq0XzPiZ6CGQsB6Ingson1 TDm1YMfHrRec
UWSz2X42vGzZrqXfdR47/HXH/T/8X47jeJ7/x67glFMLFKUU7zMyeBGSuqCe pvodSUm9YtT4
TcfwgKA3AVdoPbPOGfPW+4HSySfzvM15krOzs3PZe7X3n/e/cyfO5Xme4/i1 23bNOmeMopTC
c5lfuUt5jS9hwdTe5g5ATwQTZOuZOqGg4R/7tjQd4Hl+8IDB/2fS9R+WN908 +eYhxw3hON63
46NXN++cOkEZFephPvjSDOIk92rwdvZuXr9GeAh6AYgKrWfE0OMenD/9hY07 bbyt9OyTxfVB
MR707fjomTfff3D+dM1nTtSvDCYToVlS7y82U9CMDSm3C0BuAleYFqYX/4CI bvvjK5dOn/ST
qROmFtv/sSu4dtuuVzfvfHD+dHGvnIRvSUkBGOsAACAASURBVE7qzciaNevV aaYJM18B6NHA
FaYFnuMuOP3EN+6/9N3drY+v3XLrQ38Tn0H+hfNSPIMMQA4CV5hGRgw97rKp 9sum2rNtCAAg
AbhsAgAAcIUAAABXCAAAhLVCC8HtdQD0XOAKrQF3lgDQo8EEGQAA4AoBAACu EAAACK4QAAAI
rhAAAAiuEAAACK4QAAAIrhAAAAiuEAAACE+bWAWeugPAErL14BZcoWXg2TvQ TY59+y3H8ytf
371m80f7PuvItjmZo2DYwMvPH7v4unNGnXR6tmyAK+xz/Gntp0RUffMsIqp+ fD22c2e7ovT7
q9d9vLel87FF15ScNVb6yRYvXkxEVVVVvWxbYlewtfrx9X96bTdlD06MZfy+ TQ8f+jkRvVy2
R620+tG6e353j1EtHNenYiLxRUhvrvfNu27+oYN7SPUW41zmT2s/Fc89kFOI rvDC//vmXxZe
LfeDfQO26Z+f/HzZC/uev1c8j6STK2NnFqLCPgf8YG5SffOsA5807vus44Iz 7YwJjBERy7ZR
GYIxdt6pBdldE4ArBCBX4DgionBY6DtOkIiIWFdnZ1fnd9k1Aq4wjbR1fPvu 7tb17+9v3Nsq
vvFu6oSCrL/xrvrx9QgMcxBxgkxEghDuU66QMSaEQ+FQKLtmwBWmBYGxLU1f /Gb1lplnF/50
2mn33eD41yftG3YE//DMe+J7kHkxAABAhSCEiajveEPGmMDCgpBlV4hbrNPC lqYvntv40f03
zbh33rTzJ40edNz3ZpxRuKR85sO/nP23rQe2NH2RRdvEkJCLJ1vGZL5pa1tU 15Zy/bJQnSk+
y5Y9qBb26I9Oj7IJXKH1tHV8+5vVW644/5Rpk07ieZvNlmez2fLy8mw2W8lZ Y+fNPPM3q7e0
dXyrLphfMF78mG9LoZxUWSYjK96Q47hsNZ0+GOv+Kc0UaIjSycCBQ9LdhGaP uj1u3QKu0Hre
3d068+xCtR/keRvP847JJ196/sR3d7cqSok3DYiflJ9dMXPbgXgvmwHqUFHc liSasaRBqaSc
nV7NZtpSbKsNUHQkqSb0hIp2FZaY7770uzDGFI7C7b4z3b5Jzn//25HuJrR6 ZGaQ0ghcofWs
f3//zMl2TT8o/jt76oT17++XF1HcPCVtq+NEvchRlEjyFAJMETFSE1Gc1eLR qqlgXIqZDv3U
+gYSM9UqirNoPGKyUfPtSuOjrtZ891Pj+OOHHn/8UHFDLpF/lasZ65ipx3wr PQi4Qutp3Nt6
zik/0PODPM9PLbY37lVGhWrUcaJe5KjwpMYBprQmJV8rTPhHWVMhtVJS65Jj UnsKdcHUwoak
SqUcmZgZwIRIv4s6hqqtXa4Wihx//NBvvvnqm2++Eh2QXCIKRcPkasY60o9i rGOmFQM0e9TN
AewmuIJsPVNOLfjXJ+0zzijU9IM8z7+3Ozjl1AKrmtO8Hd9MPKh38BmHMHLP 1c3Dt3esEhr0
ItUOMtm/CqGu/jfffDl48PfF7cGDh6n3ymqwRsdMDYbINbN/2QSu0HpmnTNm w45g6dnjNP0g
z/Nrt+2edc4Yq5oTQz+FNzRYNEx4X6H5WK+b0ZC8npQryTpMtm6gucsk0n2F an7zmzuSMumb
b77MgI6ZGvRItkcZABNk65k6oeDN7R9t+/AzTT/o2/Hxq5t3Tp0QFxWqJ7xW GdOdqjQ9lCVu
S+E41HNkzcU4kzV3x6qUy1pYs/HUUj2pFDcGD/4+yRZDJaFCYq2Omb1J9SWL ICq0nhFDj3tw
/vQX/E02m80x+WSFH3zmzfcfnD9d/cyJ3BuKMZ0ZibysJNFTE0kYEhrPfzUV EpaSMA4kWfz1
DWOJnprJaynqxUqTTWj2UV6hGX011TfP+izQSESirrzEH//4p1//+peapb7+ +tCQIcPFjRNO
GM5YTCIK1bVZomOmBgPkPWIs8skucIVpYXrxD4jo9uWvXXr+xNlTJ0wttr+3 O7h22+5XN+8U
nzbRLKV2Wwklcven/mqAsT8ylui5SAOJ3KEYKydsPaEBmlWZ3GuyCU2Jumup RjrJrRV+/XW7
olRUIv/KZMoW6JiswUQ3KUfWCjFBTgs8x11w+olv3H/pWUXHP7Fu69nlD3le e+eMwuPeuP/S
C04/MbtP3SW8rxBkBfl9hQruvPM2vUnlCSfkS5+OjjaTU9GsE98jQfwvu+OP qDCNjBh63GVT
7ZdNtWfbENCTYCyJEKmj46C8aDrsSTuMMUFgJGTXCrjCPgfS0uQm0lphqKuL ESMijiL/PLLy
L7ff9vOsWmcxUo8YMSEc6uo8Furqyq5JcIUA5A5cwbCBOz/6bNyo4wUmcBR7 aO/of3vbq07E
HjHGBCEc6ura93lHwbCBiR88SBtwhX2OHHmPB7bV2z+/aOTl08bWrPnHNTOK zhkrv4GZHn9q
zdzLLyaiNa+8RUS9YPu/X39FRIwYMfZRyzer6veWXXDKytdVx2umwLtNUqFH v9sE5CxCOMTb
8h5+Zefzvj197Y13c0pOWzp/1qDjR+DdJj0evAoZgNRoJXrkdXrEnU0b4Aqt ASEhAD0a3FcI
AABwhQAAAFcIAAAEVwgAAARXCAAABFcIAAAEVwgAAIT7CoF5ho88TSERn7QB oPsojq551ykP
tnQDVwiSQJ4gOusJ5kAvI7tHF1yhNfSFp+7UR2df6DXIDFn/ywpXaBl98Nk7 xliO5HTBdi/Y
zi7ITJMKfTMzzfCRp2GCDNKH+uhCZhqQo8D9gfSR3aMLN9MAsxw6uOfQwT09 +vXtIMfhOI7j
uEMH9zz7zOoMN42oMI20dXz77u7W9e/vb9zbOuXUglnnjJk6oUD9BuQeR/Xj 63NhcQcAC0FU
mBYExt7Z+fkl97y+bVfrT6ed9sb9V/1sRvF7e7685J7X39n5uYBpJgA5hnZU uOjeLUuXTM+w
Kb2JLU1fPLfxo/tvmjFt0kk8b7PZ8macUVh69rhLfnTaC/4mIrrg9BOzbWPq iCGhYqacrYUe
juMy3LS6RUliPCYGpmruynzX+jK6UeGie7dk0o7eRFvHt79ZveWK80+R/KDN ZsvLy7PZbCVn
jZ0388zfrN7S1vGtvIh4g15+wXjpY1C/wd4M3+gnf8l3VtYQRWeR9eVLucPS G5McMRXoYTRB
hjdMjXd3t848u1DtB3nexvO8Y/LJl54/8d3d2q85bG9tFj96Tk28tyC79zaL 94IZwEWRS0gW
NKkVjEsl5UH0ajbTlmJbbYCiI+qySaHZNU1rKfnR0xMCTRKsFcIbpsD69/fP nGzX9IPiv7On
Tlj//n4LW1QEklKMKd+rUEhBYhIx/NELi/QUjEuZj6fU+gYSM9UqiotdsGTe qtk1vf6mMHpJ
dRPgCrL1NO5tve8Gh54f5Hl+arH9tj++ZFVz0j2oCkcmCaU7VKWIMgWJvEXp 8rH8BEvoHTQV
UisltS45JvWymrpgav4r2VKaY5LQVLWrUgjNm5HaOIMErhAXT1JgyqkF//qk fcYZhZp+kOf5
93YHp5xaoFlWcmead9hLXknhraQimsUVkZ2kJs7ENSXqUpoYXAQwLiUpdPMU zcFgJ7UxSQpj
vykZYOE49wWMXCH8YGrMOmfMhh3B0rPHafpBnufXbts965wxmmUV3k3t2lKY saq9qjpg1JNo
kvC+QvOxnjpESgp5PSlXkhksNNU47pMPqVXj3BfQXSuEH0yZqRMK3tz+0bYP P9P0g74dH7+6
eefUCdpRoQLpKgpF/ZT8o3CLCb2kYg1RqkEtSapaAzRPe0vcluLc1lxcS61d y71qCqaaNENx
MSeFGoCEdlQIP9gdRgw97sH501/wN9lsNsfkkxV+8Jk3339w/nQLnzmRT2/V bks9a05NIidh
SGg8L+vmbM44wFFc3zCW6KmZvJbS/ZBW3WJCM8yPHibISYHLJmlhevEPiOj2 5a9dev7E2VMn
TC22v7c7uHbb7lc373xw/nRxrxzJARnUqTfPVW+o1xDNV2UgUWDsj4wlJpf2 FcGUfMNA2cwF
E2MDNKsy2GvQtElTTTaUVCt6QqAJHrxLCzzHXXD6iW/cf+lZRcc/sW7r2eUP eV5754zC4964
/9ILTj+R7+Ezl4T3FQLQ40BUmEZGDD3usqn2y6bas20IACABcIXALOKLeDDn AulDOrrwmieQ
06R20y8AZsju0YW1QtAtqh9fLy0dYhvb3dnOLni3SSpovtsk20alHfWjYLhz DViF5oOGeLdJ
z6NP/SWQ6Ju9Br0SuEKQBFgfBOkju0cXXGG3yPzLaLKKL9sGgF6M8uiad938 TDYPV5g6Gf6p
AADpA64wdcQLJgCAXgBcYYr0hUvGAPQd4ApTAVdOAehl4BZrAACAKwQAALhC AAAguEIAACC4
QgAAILhCAAAguEIAACC4QgAAILhCAAAguEIAACC4QgAAILhCAAAguEIAACC4 QgAAILhCAAAg
uEIAACC4QgAAILhCAAAgCxP6410fAICeizWuEG8KBwD0aDBBBgAAuEIAAIAr BAAAgisEAACC
KwQAAIIrBAAAgisEAACCKwQAAIIrBAAAMv+0yVdffp5WOwAAIIuYdYUnDB3B 8/3M1/vVl58n
WwSA1HjsjY9/Nr2gPx3LtiGgB2PWFfJ8vy++Ch/8mjqPhTs7hZBAYYEEJhBR WOAYY4LAC0wI
Cez0on7jftD/6yOhYd+PFPmi7VhY4PJsyVmWgeeawwKXbJEM9CJZq5I1iZK3 KmcHKs9G40bx
t1wybuUre2+8cHiyNQAgkUQ6hoNf07BB/LEBfGeXEGYcCzNB4BixsMAJTAgL XDhMnV3CxweO
jftB/44jIanId9/2D7PkXaGQflfI0n+GJ9+LZK1KxRUmaVXODlSejT46cOTk kwZ8daSTeCx8
g9RJwhV2HgsfG8ALYSEc5sJhCgkcY2zJ0qV3uxeRwIWJQmEiRpyNI6Iv/xuW ihBPNoFxSV6i
YXzaXaEt+dMvA71I1qpkTaLkrcrZgeKIF4+3zi6O45L21wBIJOMKQ4IYD4bC LBQmIlqydCkR
PVC79I5f3i3qcBzxjBHRf7/tIqLOTqGzSyCBiCjyn3mSVM8MaerFqWNse/eH 1f+mxSTTVnWH
zPzcAgkccUTEiMEVgu6QlCvkQiESxMVBQbi/Zpkov+OXdzPGGDGOOBadpXx7 jBFRSKAw4wTi
GDEunOSRmv4Dm1HywU7aerFlb/jUMTbFv1NPTfwDJW1SMlaJ5NRASSgOKo5P fqUAgChJuEIm
sLBAxBhjJPnB229fKF48EYjjZSdMKIxkriCj8IgKQTdIwhV2hVkoTBxxS5Y+ IErcdy0koiNd
4jcmMI4nJjCOxHVDorBALMzCjOOJwsnOgNK/CJ5CC5nuhYk/KEmbRElblZsD pTyoOESFIHWS
iQoZYwJjxO6pXChGhbUPLbvzroUxBY6FGdlkp6/ABEHgmMDCPLEkV4O45G/g SJZw8qdf2nqh
rWZmsTBZkyj5sc2lgYohHlTS5J3nERWC1EniGO8Mc51hLkxcmLi7KxeJwuUP Lcvrz4U4Ej9d
AusM85TS6hIA3YPDB5+UP0lEhaFQZNrLEcd4VuleVFO7lIj+9ODSW+9aFBIo FBbvk42FA2GB
Cwn0nSjIvcsmqZCeXjR+LMT+DcT+/c5MaJX+yyapkJmfO8x1McyLgQUkN0EW XaGNF8Ihjoju
vGvh8oeW3XrXIiYwJhAJxBiTT+q6Quy7ThYKs7DA5SU5jWNcTj5tkrZeTBxj C4XZxDG2YyE6
rTBP+tdyk5KySiSnBkpCPKgEQSAinucxQQbdIQlXKAhCWAgzjhcERsQYMUHg b7ujUuhkISJB
EASBOBZZuxHv9goJrLNLIMbxTOCT/LufgUvQPEvai2SgF8lalaxJlLxVOTtQ vHjEEQ2wEe4r
BN0hCVc4eVy/jw58xwQuHD3KRa8XZjaOiCfGCYwJbEJhHhENGWQjotOL+n18 4JiNp5BAXJJ/
tG3pX20MJR9PZaAXyVqVrEmUvFU5O1Acz4nH2wnHfy/Z4gDIMesKt3zYMn3S qJNPGmBG+eWt
nztOP4GIxv2g/7gf9E/dOgBM8OLm/1x94YnZtgL0bMy6womjj39x0/6DX3/3 36OsK9zVGeI4
JgjR8FCam/TL479//ICrLzyRur786svPj3UKgYPH9nx2NC22A0BUcEK/iyYN oa4vO77Ktimg
J2PWFa56+GFpmyMyCA47iFb/u3tGAWCa/xB9sDHbRoCej1lXOP8XZWm1AwAA skgSl00A6Oks
uncLES1dMt1YQY1BEdA7QLZL0FeQ3JyevyMdlwc/2BeAKwR9AoX7M+8N4Qf7 CHCFoPej6fjM
eEP4wb4D1gpB7ycFjwYn2Ncw6wpXP1qXVjsAACCLmHWFf2spTajzwcpp3TMm dQ4d3DN85GnZ
ah0A0NMxu1b4VtXwhP8CAEAPxawrvHjxobeqhhv/m1ZDAQAgfSQRFSb0hmk1 VIQbemcGWgEA
9DXMrhXmSlR40Q+4oXeyjuWWV/yfhu1LaNIq58BkCy5evFhvV1VVVfeMAgBk CLOu0ExU+MFK
Sd1fyZXWun2sxiGJgl5XUUUDEZHTw+rL41XJ6QnUl9vNWHL9faVp8Ibtzz0/ 6MYn4/zgfxq2
PzfqXPdZSlW1XNPlGbhIAECukZa1Qq+rlDwep6y4v5IrqitjjDHGAmV1Lm9Q lAe9rlLyMZ/b
vMUnnvz9Gbeca+1M+T8NgY+vtp8X/foP765/SPtaP61tOGosBwD0dKyPCv2V XF1ZoH7mBldz
rLijhmkmKbaX1zMi8q9Lyuhho084c95Z1sWGypDwvHPIcaOfiIj8a2nQ7UsL jeUAgJ6OxVGh
GOXpTHX9lRzHcVxRXZnJubAeXx34+l/P/tOqObIiJCQiOmviX68eRPai2+2D bl96bllBIjkA
oIdj8RXkYHMD1ZZyHMcVVTTUlkoTYSISQ0PGmK+4Il6eHJ9/9OXmx7Zbt1bY /tzzg25UXS15
9++DllYXli0YuWFtuxk5AKBHY3FUGPF2jLGAx+nWDg8dNb7iug0pW/z0730W XjPRCAmJiKis
euJ5RFRQuKo834wcANCjydB9hV4XV+mPbPsrS2uLx6Vo79tfWHrtWDskBAD0 NdJyBdlfqZwg
l9f7qJQTKW3ySDfZRJYPS2sbKoo4juNcXmMzrL2HRi8kTAH5rTO4jQaAHkda okJpmiybIMem
zvKbCmVS5a700/7c8zRzsjUhofzWQtxZDUCPo6c9bWIl+e4nsd4HACBK29Mm fQvMiAHo6fTl
qNAaMB0GoBfQe6LC1m80n2cBAIDEIF8hAAD0tHyFAACQDhAVAgAAokIAAEhb VOiv5LjYo3ZE
RBT0uiKPm6gfKYk8dKIq03PoePq3q+7dkbV6Nq9eNeSqVUNWB7tvQcbZdi8/ akjks3izlTV/
9rRTrPbqpz+1st7Msu1epf3G/VLrJ1t/dsmWPWmJCs2nbiXRRZaSL/K4iSzt tQpu6J1c2VKN
Tw688KRj7yfZrGfG/AXrEr+dNRfZ712x67GWw4L4qZoRET975cJt3a77pOsb Wg4LjY/MUu+y
pH4LMbBn2hLh+evjMmMa9EtTP9n6s0ta7TEYB+ujQjF1a83MuOKOGp2H6oLe BXVlxh5QgnUs
p7e/aHt2kfyTYoKG/evWDLlq1ZCr3t7csuPKq+JDqh1vD7lq1ZCrVt27I3iv uOu3O/aLuyTl
q1Zdua5Dpl+/gmjFA6uiBUlRVVwl8fXEdqVQT1QeMyYBsRDsSu+zVzqfjVb1 7JVSaCYeK/7F
Q/hRVzoXD+FHDXE+u9l7tbix36Du+HqudF59pVdDPiR2LG67lx9VfIv/7Vsk k4iI9nuvHsLf
9XbtlVqhotp+MUQSdcS9CWIKnfoN6hGNv/rpT6PhWLQLmxdK8eyoKxM8Pq9b v35/k41qtfVT
qF+/X3q/rx5q/YjkXr+oEPlBr/Qa2z/qSufVquMnsks8Mp9emGCgDI6rzQtH DeGtzleYbOrW
YDMVN8dmzsEEZrCO5SNG3vk9G33PRsfZaMTIVBNZj5k99/DdpxB9+cdXaPkL Cw6/cM0jn9ZH
vMzkiw6/4LqDaMUD9StKXYdfuOYR+vtfdhDteHvIr/4+8e4Fh19YcPgF18Sn n4t4z6j+HZFd
C5ZMJhK97QO07oWIcF3h34vF+lt2XPmrv9P110TkpUSfHPo0hXp2vD3kgS8f eXjB4RcWLKf1
s30JO73tXv5K2ijGX42Xv3jX2xH5s1fyr10eiIRm6+jKK71EjqrDGxe8vZ7W CS3rzrhr9ouX
NQmNj9BrfqNz8rOnnVI9L01c7yeD+omIpi0RWpoec1wUjQpfKiciGlP+/GHh oYvcL6lCRU37
T7q+QYqPpi0RWtYlejmETv0G9cx7SWhZ5/bfXjTllTliF97aTET+xbNJqqTx 8heNvaFu/fr9
NY7+NJvQ0E+6ft1+6f2+emjqz1v+mOOOjS1LHNJQvHTHrIeWlxvZ3/SY4226 rEloOSw0PvLv
FRF/519c/KIobGma89rttY5HAkbhpO44RPpr8dMmweYGqm3gaiOlXOMDiowM NUT+Ss7lnSnK
gx83NdQ2OD0BVm6noNe1wFueKCMD61jODb0z1LE8z5KE/pdfPnkMEdHQ63/1 o1d+tc/fMvn6
UdF9pa7D8+1EdP3/LiCizav3UalLdE9E9iV3n7LigY82z7fP0KiViDr8Ww4R HZp91T6ZcJ+/
ZbLj/X1vj/1R0+yhomjGeafQp8P1f0G9eopozb6Lrr9GtHbM7LnrDqyabdxV /1u7Hmt5ySF+
Oen6hpbriYhov/e1iRtjx9CMZS+96Xx2f/m8MUQXPVY1g2j/aY47Lpk3hj4z rp7opOvvnjCk
aNTt4jf3S4fLE9SfHDr2Z4rYmTZjWRURbX5jFdWuGlIrUzljG9G0jBqVBvT7 pf376qOtP6b8
sl0Lt5EjeCV/Fz3W8tK4t3bNqUp4MNxxt3jAnFR0BgWidt5xd4tYcEx57SMv JvGCJDnR/lr8
tEnE2xFR0OtaOU4vdes61wYqj46j0xNRs5eXkcsbLE+Y7V/0hpYk7Pp+0Sjd fXecl8iQhESd
qRzlHHPyRYcnp1BPx9PdMSxNOKoOC5HnEDcvHHWlNxLo9VZk0U2vQrdfyf6+ 2vr2if8O7vfv
o8demvjis5vn7J6YavZSGTEXmQJ3bGxZ4sjQfYV6qVvt5fUeqoju8jdTmcm3 nliVuHDf7OgS
4eZX/v722FMc+p5xxnmnkK8+un4XvPeBfVR6cjQkHHrq2Khey44rr1rzdMtQ x/ThMn3xIu+a
p1tozDmnXPTJ3/+yQ6GfbD1DHdOHv/104+ao8h8TTpAdF0+8RbaY4l8sLpeM Kb9s1wOyRUD/
W7vmmAjZ/IsVCzdE8sVHIiLxEE+x/n8HxSKbF0Zb0bGfiIh2B6LrbrNrlTWZ rT/JemYse2jX
hfqXvDXGx7B+bXusw3T9+v3S/n0jmD4eiKb9+Ix9f3lj9+UXTfvxGa/98cUJ P3Yk0xHJzksW
rHgj2px/sXI8tcdfYxyk/ra3Nre3Ntc9/+iMlWzGSiZ+VXyW3LekvbV58q1b jf+Vsg5K7/J0
egIqGZHTE5+kMLbL7WOp0d7aLF2FNP15/xma88y695+hOVU0p4oW1TdFd637 c1VEOGfFI5/L
inxef9Gc6K4//11VW2TXRa83q4Vxcnk9cnmS9TS9vkIy/pE/K3uh9XnoothB sWBdVN70mPxg
XLBOaDm8cYH45aLHInvv2Cgu4jgeEVd/RIXYyoui8rhdGvWr9Ynu2BgzNbZU p9uElv2zHnrE
HTUy2gVNkzTrN1dPrF3lLrmpGuOjU7+ePXr2JytPtn7dfun+vqkcD7MeahJL iRv69kiDdsdG
qReRcZOt5y64wx0bTL3x1z2uNi4g4tpbm4nI79v08KGfE9HLZXuU9hCtfrTu by2lCaPC4SNP
U5fNDIcO7gkdd2qShXa8PeQBWvfCRTqLfQCAnsJnTzvd9Gh37sLpq0+b7F+3 ZsgD+4j2ze6p
dyYDAKSbdaa8MqebdyP21XyFY2bPPZzggisAIMeZ95Iwz6Kq+mpUCAAAMnpP VFgwmMuuAQCA
nguiQgAAQL5CAABAVAgAAISoEAAAKG1RodnUrZLMbGqadBD0urLVNAAgN0hL VJhM6tbYs3aB
uBKZI7ihrtjHdBKLAQD6BNZHhUmlbi2vjyVt3VBXvAj+CACQDSyOCpNO3SoR 9NYVz3ak3A8A
AOgGVmexbm6g2lKO47iiioba0vgFOEeNmIimuEK9MBfckB1PKM7cTb1PAADQ e7E4Kox4O3Hl
z60dHjpqfMV1GxTCLHlCctSwQFldT33PHgDAIjJ0X6Fe6tYImB0DALJKWp5B 9ldypbVEsneb
lNf7Kjku8pCw08PqHfLKgxvqimfXW9AbAABIibREhdI0WfGOJ0mqqNwuv5Cc cewzy5pKcV8h
AH2a3pOZJnXs5fWsV7+NCACQCDyDDAAAeAYZAAAQFQIAACEqBAAAQlQIAACE qBAAAAhRIQAA
UNqiQrOpW0nKV6PSz1U+eJmbu9rbot6xp3JuNRf9VH5gsjqvS3lzt79yk8t7 1ETR9kpuEyd+
XJ8a6Wjs1ZNbT9DbyEl2Rj6N1t7P7nVtUjZR2S7tNT2eMVP19TM3binQ7r1b 8/DTk1PQ64o/
Gfs07a3N7a3Ndc8/OmMlm7GSiV8VnyX3LWlvbZ5861bjf6XHSTxOcns8zlhW VuZzEzk9UqIG
pycQS9caVfO5ZXlck6S9tTnFklbhW1VFq5I2ojt9FgkEnc6gz709OqJq2tzO YDJyiwl4tjs9
RxhjPrdf7KvHaWBtAjzOXb6E8kDQ6W5LsQGZwTpkaNxSptk9p8r9vkl59w/A XoP1UWFSqVuJ
yB3Nw2Af72z6OJiSP88QOn9dW7a65laXbiTa+FwkKly9x1yF3qW1blkaCs2o xOvaxHGNXu9u
zZAquKGteFGhY/agug2yQCb4qSsawDSbcgAAIABJREFUH8WF2jpyMapyeY9G Ddgd2enfzekE
nrFAzNXoku1Sy+3lU+rLB8rLltdPiTyQqVl/1MhKv6TQ6A1G5BUNB0s1uxYd QJf3KNkL62vy
9cbTuF/a6I2npq7iJRXRN1XoyXUr8q+u5uZWu9buEY8611ox0I1MPlyrX3ZF pyDRXSnguM3T
tBSBIRFZHRXGorxAXFTIGBNDQ6JYeBgnVMqTI5NRofZf3VSiQu0/yeqoxOP0 E0WjnkDQSbEI
KBoNyUOVNjdJYVebm/wU2aUnF23ZRZLEt8vtE3ViDQU82yV9uYU+tz+hXJLE 91a3fhYIOkVT
A0EnxZXSjwr9RH4ivzqgU42nfru6+vrjlk7aPIuqnIte8nzB2BdbnHNWeb6Q yV9vU22LJBUV
MuZzkzPlIL03YXUW62RTt/rXkS9iSqCsuW+lRAh+3GRa1+2b4BC37IWrPEfW +YmIyL+7oniE
g4gof3ZxMBKw+NuaPBOjeTDyawL2yCtj9ORRnJ5zWX0hEZFjQo2DyN9WS7EQ rKjiCDUcFVuw
l9uLK7aL8tLakT6xlL5cG/36yV5YHxhRV7SJK2orC5SYS9Ux0sdKAp5BiRUN 2tXRNx43BZZF
hSIN9onlo4hG5RdTS/PniXuXNI7xzobmRFb0BcymYzBzBfmDleSoYayGiIiC XtfKcXqpW9e5
NlB5ORH51zWNvy0it4+jug3BcrzeRINB4+0aUv+6g1R7kKuVBO01jnwrm3VP YjWaFebXsJKa
iBG7OdenER+qK0+2fqLg0QYioiPNQSK7WXvt5VNM5XozaLfb6Cf3SCnph/Mk 3KSWGTJ0X6Fe
6lb7eOq7f5Hs44rNqh6pWBBb0tpQN2i2g4ja1zXZGSuRPp6mNj8ROUYUV3zq jyr7VwYbxC09
uR6OCZ6mDzWXxryu+EvAxYOM5cnWH/Q2cqXkYyWMTaJSxUrfkch6sn93bE0z KfTb1dFPctwy
ygebKz7pXg3+5gan5h/avgbX3tpMRH7fpocP/ZyIXi7TWPFf/Wjd/F+UmYgK p4n6UupWpycQ
DQwlmZi6Vfr7KJOT28dSzFt46OCe4SNPS6loUnzwMvfAvyLbYy8OPHC+XSEk IiLn9bfX/8RM
1OF1cc2LpD63V3If1sbtH+ljExxEXldjczHV1h6JVO85t35mm6tIPCcHeQJT yu1S2UGewJTy
4G6u9GCkDvdId+3BWqed1ReSX1M+SNGu21eiY5Jkz6aKBqWQ9OVBb2NRxRG1 XLN+e1TZ7Sup
oYjBTs+5kWsvsS5otiuORoLx1OmXvr72uBkGvN3Hv7q6dCMRkfP6a8q2PFfx CRGN8qyYXz6K
qGWr6463Gojowos9wbcqPiH33dU1pDwOI4eo6viMHbpEQa9rAdXrXNLsU5h1 hX9rKU0YFWbE
GWmTKVdoNf5Kbt3shP7f62qkVVOwcgAsx9wB2CfA0yZZxVHjaVpqvHTudW2q aDhSUZS7d/aC
nkrQu7TJAz8ogizWWaa8PsFCf3l9CWYvIC3YEx59fQhEhQAAgMw0AACAqBAA AAhRIQAAEKJC
AAAgRIUAAEBpiwp7cerWSE8SP0gPAOg5pCUq9LpKyeORJ/DwV3JFdWXRDDR1 ssw0laVNkdxc
PirtEf4luKGu2Mc0M00AAHoo1keFSaVuDX7c5F5UHtXxFddtSL0rAACQKlbn K/S6SsmnEzFF
psJFdWWSgn1ccW00iW7Qu7S2odnfzQ4BAEDyWBwVJp261VETKKvjoi7SY5wV MwcQZ/p4bBOA
XobFUWHE27FIQn+91K3yibC9vD5SpH5cM413WNCpNOKoYYGyup5ygQcAYJIM 3Veol7pVjr+y
lBYh8wAAIAuk5Qqyv1I5QS6v91Fp5J6Z0iZPLEFa7FYarpR8mHgCALJCWqJC aZosmyDHps5x
l5Jl4p6SQNI+s6ypFPcVAtCrQL7C5NF/kQ8AoIeCZ5ABAADPIAMAAKJCAAAg RIUAAECICgEA
gBAVAgAAISoEAABKW1SokbpVTx5L6dpLn+z1V25yeY+aUGyv5DZx4kf37e/t ldp79eTWE/Q2
cpKdkU+jtfebe12blE1Utkt7TY9nzFR9/cyNW69H9uCYxaey5CLS+lxDWqJC depWXbm/Ukrp
6qPSXukMHTUl9eUDTSjm17ASFrA7nXZfcZvOj55fwya5k5CnBafnXMZKfG5y +0oYK+lOPiGv
a7dfJSyvL/E4R/pYCRM/Abu8BdPjSfbyKYyVBDyD9FUyOm69maB3aTQHs/zB Ma/LgnNazNgS
0DrOLKlfxPqoUDN1q57cv67JsyqauvU2T9M6fzf6knNoRiVe1yaOa/R6d2uG VMENbcWLCh2z
B9VtkAUywU9d0fgo7pfXkYtRlct7NGpA1N34d3M6gWcsEHM1umS71HJ7+RSF JyqvnxJ5wFKz
/qiRlX5JodEbjMgrGg6WanYtOoAu71GyF9bX5OuNp3G/tNEbT01dadYiwyg8 8a+u5uZWu9bu
8d4tbsQCWvrgZW5udeRz99YgUXDtavFrRK1lq0u2V59YCObyel0xc2TGij3z V3Ic53JViqp+
cX/i6CpWj8vlkr2BQ1V/tI2iioaGCskkaeAqGmpL1QW07BfHWWZ0Iit16jeo R+p89DeNWuSv
5DiO2lub21ub655/dMZKNmMlE78qPkvuW9Le2jz51q3G/0Y8t9snJemS/kro yX1upycgU3LG
/rAkRXtrc2oFM0DAs93pOSKXeJx+ol2+yO6gU9pmzOMUt9vczmBU1uam7dFR anOTnyK79OSM
McZ8u0iS+Ha5faJOrKGAZ7ukL7fQ5/YnlEsS2S9pVD8LBJ2iqYGgk+JKRfur xOP0E/mJ/Iqh
Yxrjqd+urr7+uFlBm2dRlXPRS54vGPtii3POKs8XjDEWeH0VzXlJMtS3qooW bQmIG6uaGWt2
z6lyv8/Y+y/J1bTwuYmigxjwOIkiJ5HHSbHTyeemyNkUVfe5Rc2Axyk76zSQ K4iFxG2d+mNl
1FXFne2J7I/zDXGuQWmVcf1G9fjcRNEe+dxunyhy+xiz+BnkYHMD1TZwtZFS rvEBMSODnrzP
4vZNcIhb9sJVnsaVfnI4iPy7K4pHMCKi/NnFH1b6C2scRP62Js/EGruonV8T sDctICJ9eRSn
59xI+OaYUENE/rZaOljLHZSpDPITOYjs5fZibjtXIQpH+lhhxDQduTb69ZO9 sD5ArqJNFTTI
Eygx98uP9LEJdm/jgoSKBu3q6BuPm4Kg11VU0aAQOj2JDuAG+8T6UUSUX0wt zZ8TjWrfsKWF
qKV07r9kWjs3tJxf/sMzaU178IODtUT03p7bTmqlC0t1rSdxKsXqIxqxB+KD 3rpiWYZQR41v
ncsbLC+3Ezk9NQ6i4Hine3a5nYJGdot1LirmiqK/u9snNmBQf3Lo2J8pYr+d o6aGiPzraqm2
lqs16wrNrBV+sJIcNYzVEBFR0OtaOU4aOD05UUNzkEj6ppXHsDcyaLxdQ+pf d5BqD0p/MIja
axz5VjbrnsRqNCvMr2ElNREjdnOuT1l9oaE82fqJgkcbiIiOxP3cibCXT6k3 o2fQbrdJ8Vx1
nqR1c9mF17D5pymFoya6H/CtfI/cd19Da3atDLa456p0MkzsfCV/Jefyar6Y qPfg9rEaR5bv
K3Tc5qGPg+K2f2VF8WxHCpX0QI5ULIgtaW2oGzTbQUTt65rsTLpWwEo8TW1+ InKMKK741B9V
9q8MRkIUPbkejgmepg81l8a8rvhLwMWDjOXJ1h/0NnKl5GMljE2iUsVK35HI 7+/fHVvTTAr9
dnX0kxw3i8ifOX0UbXyu8oNow6urubmrvS1ENHz82JbajTT+xOHj6V+1n4wa f6JhTY7Z8ldi
kL9SXPSyl5c1LZX9Xv51TWUmQjZxPS1u/OSLj0TRACXF+puiv29ltBUd++Xa Qa+rtJZMoa4/
yXocNZ6m0ko/WbxWKJ+PE5Fibq8pj10X0pj1myUn1wrb3OSnuE9kScvj3O52 b5fkTs8RcRGN
yE+RZSyp7HZPILrwJ37cu9yyRUAtubJd2bgqdkn2aAgN5AHPdk25Zv2SstsX Mzi2eBfrgma7
22VHiu546vRLX19vPC3Bt6qK5lTRnCrn682eReJ2ZLmQvf+SuCuq0BYZ0NdX ieuG0kYi5FdT
Y79v/EXW6EJY5JSL7HX7xP+j56CoEHfuxV+qVSz5a+xQXtqVVyad8/pNaNnv 9HjcUSN9qkv8
cVcbDO00qkdRC9fe2kxEft+mhw/9nIheLtujbJdo9aN1f2spTRgVDh+Ztbj+ 0ME9WWw9Wbyu
Rlo1pW8vlgKQW+Bpk0zjdW2qaDhSUYQ7ewHIIXpGFmuO44iIMZa+JjJGeX1J r16CBqBHkutR
oXjzZDpqBgAACSujQvgsAEAPxcr7CtMxgYV7BQBkgFzPVyhe605HzQAAIJHr a4UicIgAgLSS
61EhAABkgDRFhUmkbjWVkKcng9StydIrU7fKj/NY4i9Z/qvMEPdQnZ8mcTSx kg54aRJH10Zt
+auLJnGxz7WZttEs90UtnOiyoLa0RIXmU7cGva5S8mk8WtOLQOpWA3pr6lZ1 SlFHDfO5nVS3
0i+meBCzWmU4zYG/sqJ4UewxJzudRTR5PI0eR0R0WjQXyrX1dBXRXxh9yOhD RpfU0V+DGTXT
JL9n9GGAznLSY8UWWGh9VJhU6lZ7eX0s422vA6lb5Ub20NSt0XHQSmUqz2Ev CQ1TlpaVaeVq
l9UTjdkMU65qtmumF0tr3aqMJ6IHZETj7NqlLiiLpkzxx0JFeSAmRpHXeiPR 5USOtsbvEvWv
VRWJUw7StaIap6zEgAMb6LRFdP5semNDnHxrZazdv7pijlJP/leX1VGhGOWp U7npyXs3mlFJ
eX2Jx3mkooIiUU9gRF1RLDKKZKlxjCiua4vK2iuL2soCYog0iUo/rE0gp/L6 EuYb2VCxvahu
BGMlzEfr/ETUXllKUqgVKGuTvEbQ21hXdq4o9xUfkTK16Ml10KnfXlgfsDvF vGT2gU4it29K
uZ3IXljP4qK/+L+JB0u5TUUVRxKOp0G/dO3UGTc9gl5XXVkg8uB+cUN0HPyV pRTLJFBWF/FK
9vL6+JSicf2aWeOjpcqQ3zHbF9Uuqyuq9FMkiGxoIB9jvuKK0rqyAAt4qG5D ULfdxPibG+I9
oZ1OEz2gnSYT2e3axd6pi3jJ+0pjoeKbZTFveG09feijf1bQj+voQ0a7fLTB T0R0wEtvlEX0
HyumHdEK/+qKyXf56BZXxJi/BmhyA10SoA8ZvemhP5vo1jt1NNNB5KDT6mLC rZV0C8XsvL8h
gVy0x+LMNIqZblwuXC25lBjCOK1uQnIyM00EzSzW8jQdAc/2yFffLnJHkpXE ckT7dsUVDwSd
0bQ02nKmVYrFp2Mxyuyil2lGmW5amcXaqH4WTb2zXfE762exjmS1SZzF2rhd LX2jcdNGfvxG
O62xqhMbD53szU5PIJrwWZ72WTvji88tKkSTMkfSOBu2a0QslXxiFhObGP3M iyTDjknEzwRi
W2J9i6rp1BNTDrB57jidLW72TEC1S6fCOHxsQlR/i5stjvZtsVOnU5ryaKMW P4OcfOrWvglS
t5oiF1K3EpFuKlO3L5XlHXv5qjJX5Yay6Hd/ZVFdWYDV24nE8yNhDam1myR/ YXR+vIS5aVdN
cpX8ntHvxS0/TXTRLlM/p1m2riOuliZFzxdG9HtH6rX1jPsKex1I3SqRa6lb TacylVJ+aqOd
UlTEXr6IKuRvCSiOrNMFvQtULw9Q2W/crj72ccXJF5K1S/c00X3JtCtfjCMi Epu30yVNcfIN
TXStPXFt96kWEDc0RWa74ueepsjemcVxV73v4yJma8sle0xOkBPOjuVTVPOp W5XBfq96zRNS
t/bE1K3JpDJVHr9GKUWVB7/sNUmy+bHT7RbzqxqnXNVv1xCTM+RnnLFZbWTq GmWx1gR5cfzE
WZqoSvUoZ9MBNk+tHxVOcMcm4/I58mLFLDvewsXxX+VNS/boygNsHjGzqVvn /6LMxLtNpqnL
ZgakbgUgMf5Kbt3sXnzPRnfA0yaZBqlbQdZw1HiaVNevARFZm5nmg8TrvSmC 1K0AWEJ5vaVX
LnoRuZ7FGkm6AAAZwMoryFwaSGvnAQBAxMq1wsSXppInrZ0HAACRXL+vEA4R AJABcn2tUATe
EACQVnI9KgQAgAyQpvsKk0jdKstiGUy1FzkNUrcmSy9M3RpL1lrpp/jcrcGI ir8yuVNAoS9m
9dKsQGrNwlNM+TAi0Z7KudVc9FP5gUHZdu/dZtQSE/S6LMx9a21mGhGPk9we jdwcarnPLT2E
53Obf4BIRU4+eJcSgaDTGfS5lRlcZLS5tTOp6MktRkr0ImWm8TgNrE2AcWaa aJNBZzRhTwpo
preRkZZx08pME800Y6TTzUaNEjwFjHcnhc+tPFd9q6poVVInYbN7TpX7fcsN SRnro8KkUrc6
alg0S43jtu5kQ85JkLpVbmSfT93qmF1cEWvOX1lXdpsjVkI7atNs1yjK04o3 dbEmBWzLVtfc
6tKNRBufi0SFq8Wnd+PiRNfadr3qYrRsdWmGlh+8LAm5u7fK+uW4zdO0VNPy 5F8UYm1UGEuJ
Foj7m6cnj/PvqeZiYLkdFWrmK4ylBggEnXGZCKKpBGKhSps7lpWgTZY7QE/O GItmHIhmbXD7
RJ34lApRfbmFPrc/oVySxP+SuvWzQNApmhoIOuPSQxhEhX5l4gZZzfFC/XZ1 9fXHTQt5POVz
S0lD4iKSgMcpTyaifZTLDn51ik511KbTrq5+LF0D08hOqNI3st8QrVAsQVT4 xRbnnFWeL+Qi
dVTY5llU5Xy9TbEdeH0VzXlJas+3qooWbYn1QzaxVBpJ6syoBlh8BTnY3EC1 DVLGPdf4gBj0
6ckjBL2uoopiXx+6TOz2TXCIW/bCVZ7GlX5yOIj8uyuKRzAiovzZxR9W+gtr HET+tibPxBq7
qJ1fE7A3LSAifXkUp+fcSPjmmFBDRP62WjpYyx2UqQzyEzmI7OX2Ym47VyEK R/pYJCmhnlwb
/frJXlgfIFfRpgoa5AmUmMtDMdLHJti9jQsSKhq0q6NvPG5q7OWLirmi6Di4 fayciMi/rpZq
azl5Duxio3aJyF5e1uTyBh3l5F3aVFZvT6ldQ9xSqnh7+SqPK3JcaZKC/SLB j5uIZidUI6Lg
2tVFT7dEv40qM9Ilovxxdmp4+hHuaSIi993V9WcTUfuGLS1ELaVz/yXT3Lmh 5fzyUURE5Bjv
LNVKgilLMWkOi59BTiF1a9DrKqogT4D1pUwtSN1qit6XurV8UbFrQ3Am1RUv MtMznXZ1cWoe
V7qkNQVscO3qoqfJs6K6fBRRy1bXHTsTFnHMr2bzyb+6unQj1T5Q3XT97fU/ ISKiC69h89Od
eCrLmWn8lVxRXRljfS2tNVK3SvSx1K2O2cUVRUUVxaq3LWmg3a4RDRULYkuW C4xbSXcK2OBn
LXRhqRi7+V95K1FGWiLaUzl3tbeFHPOr2Zpq34XU8NkhovyZ00fRxuekdUP/ 6mpu7mqvFGv6
mxu0/gBElwrNWBohHVeQzaZuDSgvlPSuK8hI3YrUrRoHtdaanQJ39HfRrPz/ b+/8w5u6zjz/
vbKBZMk0SeOEpERGQCDGcfcJXUrLr7EUHFYelniZ2ClN2G4f2zTFJMShlk0a 7xhSZxJsF1xa
hzSRadOHpt3FCeNkGTz8GMkFkxlwks6zDhgYsGyNAwZDQhoTLOues3/cq19X V/KVLVmS/X6e
+9hXR+fHe8+PV+859973qMe3lcHr+RVAGP/IobMamQvYD99FQZX/4Vnv6yzz hJS9f8wsnXyo
Et+z9ueL7xeoUoQnf29tBktoK4vgciS0um5955JpWKswjs5TyXUrQYwdCeMC NoQgdouwTXE/
YljobZOxhly3EklPgriAdTRu67CqKWS/h/Q0kxzvII8nyHUrMQ5ICBewhmhK QVYhQRBEvO8g
EwRBJAJkFRIEQZBVSBAEQVYhQRAEyCokCIJAzKzCCFy3+nsVGvFljBmhLowg iKQmJlZhY64J
VhXvg8HhnneQOee8K78p8R1ZG2u5raxuvz3echAEEVWibxVG6rp1OGcbBEEQ MSfa/gobc02w
8SIDHAHJQ4UDAOwWwVQHwGzlw7pwIwiCiAFRtgodnS2QPJnPLG6pM3knvKHC AUimIefcllWc
+BNkAMZaG0zjdlMqgpiYRHmtUNZqXPZdHuC6VS3cH2OtLavpSHQuK5bYLSbY JpyHRYIY38T5
ucLGXN/tWLvFVDe8c0qCIIjoExPPNJ7FP+UeJsHhRQdsFkEQpK/NVn7AGIVr IgiCiJAo720i
EWqHFbXwiHdjiS92i2CqK7MlkcQEQWiA/BVGRpJpboIgtEHvIBMEQdA7yARB EGQVEgRBgKxC
giAIkFVIEAQBsgoJgiBAViFBEARiZhVG4Lo1bHjS09+4eYvlo7gUbbe05jbe 0BCx3yK0CtIR
cpf6fov6t6HCo4+jsV3wyikf7dH1idGY26oswtLv/VZzffpEDR1/7OqN0EhM rELtrlvDh48D
rnZeiFfRxtrsA0X/SUPEtFqezbsMZrPBlnUlhHJJq+UPlUUQHhPM1m9znm0r Q5ktm/Ps0fSY
xtzT9qDAogPZVvM9Np7NpaPL4F+C5vqEoWgB59ld1qmho4xpvRFaiL5VGJHr 1jDhicdH+4Qn
tghPbLF8dMbyxBbhiS3C5jZH4FdBgX+oA+pe3eJJCEBOm/v6vlxPktz/2x8m f/vrUpwzjZv9
IodD1SppzG0VhPbGxtOqJpXjyJWsihnGlVObjvgZMo7uXI99FGCyhwiXrKrc xhseATzqxn5a
CGF4+gyx3PZcv6+Cww1FCxSaqOjAAvkFd9X8PUJa7N4I7Y0OOby45bJJ9dI8 FZjbeAOGGQdq
00LVZ/jrUidUfQLyxIh8v8WR/r7O/r7Opj/+elkDX9bApY+Ko/ql6v6+zvkl beH/Si64UGbz
OuPifq65IgqPlP6+zhGnjYjOsoIqFFRhVyfnV6wVVWUf8q73d6HgXZsnhm1X FSqOdfnFL/tQ
kckVa0WV+f0rQefq+ctxKt61XuT84jFzwS7rRS2idllPmq0D/iFWsx04JUva 5TB7zzm3mqXz
K2Vmh1fMMpy0dnnP7ZC/ChUuXf4peENsp8psUhxfQV3Wk974/hLayuzDhntD AntKyPx5l8Ms
idrlMCMgled6lVjNdsAO2BVVx1XqM3S5IeOHrjduKwMAsycCMdZE24t1Zwvq WoQ6OZXXA02k
4YnNI9/nP34QQNGrW4D+xv9zCbhkeuLf/GL8vyOXlhTdG5X8ZVoMmQfuBZCW hUudnwIjzLzM
Ns8onRlm7LK2N9hhNAL208VZd3MASFuZ9YnFPqPWCNivdFgzaw1S7LTaLkPH egChwz2Yrd+W
zTfjvFoA9it1uFwnXPaLMtUOGAFDkSFLOCkUS4H32PgMWbQQ4eqEzh+GGQe6 kDuztRhTrV3Z
2nrWPTY+z9DYvn7YiGHKDRE/bL3R2+1xJsqeaXzt6WjMbZgd4Lo1kvCEpmzh g8ogj/KKVf6A
+f5oPKw0NcOgEmrffxl1l70/SEB/rTEtCqV5KXuI16pmmFbLs+Xxbz8t5Hbz AzPChkeaP+C4
0QIAA50OwKBVXkPRggNa4oUpl0g26LnC0ZK2fOm9+Oc/eG8T21/fIjzxeuMl 6dNdGbM8ES+1
5frCPXx0tHgs76sMFK/3LWkdaZq60gigf3+HgXvvFfBsa8cVOwDj3VnF3XZP ZHuDo0U6CxUe
CuM8a8cnqk8HNOYG3gLOmho+PNL8HY3tggk2ns35QzApVvoGzktF2E/71jQj InS5IeKHrTfP
UuEIBCGiQ3TXCiVsnntjipWPSMO1M0ZrhbZdVZDW8hQLdh++6wmvQoH/2l/A V77wi8fM8prg
MWtFFTzriar5ewPN73dKkZWlK7hSBjsCDnlJy2o+WVZ20htutg5Ii2iAHfIy ljftSWuXZ+FP
OspOlfktAqqFK8v1W5tTfOWVRyUwTHiX9aRquGr+3shlNp/AvsU73yWolnvS ryeGrM8Q1xU6
fqj6lIfAKBbLiVEj9Pd1ArDbWn9x9UcA9uWfCVaXr/+66Z1LpmGtwrvuidoc MVKuXj4Tx9KT
hcbcduxakBSLEBMMu0XYlhzr5OMXettkotCY21rcMlA8k57sTUCMtbRvWLwh L9YThaID2UXx
loEgEhayCgmCIOgOMkEQBFmFBEEQALTeQf7x0/ljLVqE6FL/Kt4iEASRrGi9 bZL43H7H3Trd
JO3xP7v2aaRJiHHMm/94/vGl0yZjMN6CEPFh/KhCnW7Sxc/Ey9fhGhRdLuZm EBkYZwBEJnDO
GdMxztyMf3PmpNn3Tb4+4L7z63KSi1cGRSakpmgti3MedflFJmiMGXU541h0 IpSemoLZ9+rW
/c3shn84+8NHaMl7gjJ+VCGAy9dx51Td4BSda4iJXOAiZ0zg4CITGGciE0QR riF23jk4+77J
nw+4vUlufjVZ5JGoQhYDVchjoBG0yRnHohOh9NQU/Ltz4IH7p3w24IJO6+o5 Mc4YV6rQNSgO
TtExkYmiIIpwM4FzXr1t2+ayCjBBBNwiwCGkCACufSl6k0CHFMYFzTeRuC76 qjBF8+iNupxx
LDoRShegk7qEa0gQBK16mRhnjC9V6GaSPegWuVsEgOpt2wC8Wrdt47ObpTiC AB3nAL78agiA
y8VcQwwMAOR/WtAcMRZERc656Slne8Tgv2NQ9IiJUekMTIAAgIOTKpywjDNV KLjdYNLiIGMv
19ZI4Ruf3cw55+ACBO6ZAn01yAG4GUQuMAgcXBA1D4MYjBcOzcZRlOQ8dlac m56i+Ltobrgu
EYsqGvsLV5Tun62g0zwJJ8YX40oVcsZFBnDOObx68JlnyqWbJwyCzm/UucXo T3KJZEdHVuFE
ZVypwiGRu0UIEKq3vSqFlG2qzbX9AAAV/ElEQVQqBzAwJH3ijAs6cMYFSOuG gMjARS5yQQeI
2mdVMVhb155lbOUM+wMRi6Lje+HKdhfIKpygjCtVyDnnjHPwFy3lklVYt72m dFO5L4LARY4U
v+HOOGNM4IyLOnDNK0yC5uc/tCNqHr1RklP9q/CLhbGoojG/cGXpHMw7Sdfp yCqcoIyrRwdc
ouASBRGCCGGzpUIKrN9ekzpZcAuQjiHGXaIOkSxRERMJgY6JeYwrq9Dtlqe9 AgSu45ayitq6
bQB++fNtJZsq3AxuUXr21mdciExwM9yUAuJ62yQCoiFn+3nm+9vl+3szvOEV 3yqKUemiMMRp
XjzRGVeqkHP5GZoUHRPdAoDSTeX122tKNlVwxjkDGDjn/pPAITe/6eJukYtM SNW8FMWFuL5t
EiU5M9NT3CLPTE8ZdOPBGanev2NQtD9jf+GK0lMZGGMAdDodTZAnLONKFTLG RCZyQccYBzgH
Z0y3YaOFubgbYIwxBoHLC0PSo2Ruxl1DDFzQcabTbEvE4uazjmsd6FGXM45F J0LpOqlTAFNS
QM8VTljGlSqcP3vSvztvciaInjEjaT2RpwiADlxgnDM+b0YqgK9NTQHwzZmT zjsHU3RwMwia
LYKUGKwzujWbPFGXM45FJ0Lpgk6QusTtt92iVRRi3DF+VOGxTy4tfejeB+6f oiXyvrZPjd+8
HcDs+ybPvm9yjEUjkoC9R3vXPPKNeEtBxI3xowoz9bftbe25fP3mlzf4kDjk cgsCZ8xjHnon
PpNSdV+/bcqaR76BoWufXft00MW6Lg+e+Y8boTMmxj/Tbp+U89DXMHTt88/i LQoRJ5SuWwmC
ICYg4+q5QoIgiJHhmyA/d9cbcZSDIAgijsgTZIIgiIkMTZAJgiBIFRIEQSge prHbWuMlB0EQ
RBzxqUK7rdVoyo6jKKGw21of/x496CPzzv9+IzGbafQkbA+MBYlzsYkjiUZi JLAuprmPHrut
9fHvrQM4HdLx+PfWkfFOEFEnCd424Zpf1ycIghgZpAoJgiCSQxWSu2mCIGJL UqjCAKvwh8/v
TEnR6QRBp0tJSRVSdKmpqbqU1JTU1NTUlJTUSSmpKSmpKbrN6/PiJTBBEElH EqhCBKrCby94
cOHDWaJbFEXx0sXLd379jiG3e0h0MzcTReZmjDHW5byE5JlWl1uek05qan8R PpAgiBgx6kes
nU0Fa5qc4UNGBw/kZPuZQ0f+xXa0/di//PnCf1z+t45znee6Hd0Xey/1X7l2 /YsvBm7eHAQE
njwA2F7/5vb6N8stz0kh5ZbnpJDgy+ejXC6IdusQCc3YNHdUSol3z1RRhQXT MtLko6Zt7CUK
gnPmfzz8n+f83aan/lfpky9u/P4jy/6LZX3+T370t6VF//3ZH64q+R9/8/RT 5qLvrbhlyiRv
/JVTbpssHz9tDcwqOofjtyv/22+7/U8iPLxXur3+zYry0oryUkkJql5+8E0k XwdyNhVMK94j
fzhRFWnzOZv8mj6j6vhIGiuKFMS6EwZc74hKie7oPV7jrfy0rSeilWukJFQf 0EbvnjUZadMy
0tY0ORUtEqqBvOF+EdSsQlP1x32d/X2d/fuQlwAWRLAiaPvo3AcfnWv78zk3 E9s+Otf2Z+k4
L5188Odz/qnw6M4zX31+86vPb/4Tf3TVbx1RV4VgAGOc8fS177+3Vh95Dq+8 WrepdJ10sV5j
EMCm0nWvvFo3rCrMtF3oAQA4j7bAhHNSgzl7TplmpUda196mb68+tTPOTb+3 vdpkqv64r3xJ
7MoYZVfX5+/9Y74+GoI43y5OW41mSZi+zmbY42aFJFIf0Mb0tX/s7G+vNmlP odZwYSfIi40b
bBd6nE0Fa5r2bPX8cvp+S70/pBesklb2mSRAQMziPU5JAddUrZF+bWRFLv3s ON8uln+I1Lqj
QhG43eKSb81Z9K05Sx6eI7rcS741Z8nD0jFbOln08By3e8inODiHdL5sRemh s47ut1ateus3
L9xxy62VrZzx7rdW3XrHLbf6fVxVuXmVFHLH5lbGA+I8/ptuKY43h+7fbNh4 6NDGB2+9Y9UL
latWvdUdHJ+z7t88LmV4ixQh6Pj7V2q82lBiU+m6v3+lJrwVKbGi5GyXEwB6 zs0t3Tj3lKMX
AJwX8NgifXArhGkvf5wXbPPS9eGb3v+nVe4MvXvW1LQFN6hKT/DLdli09Bzv tfjbeqqlqzJM
V/eI7RP4RNW0mraAGlBeoGrNhKL1PdS3+5T+kqryJSEqfM/WAJMtdFUHFqel EpTVfsE2Lz2w
C3nyDFXK8Zq0acV7jmtuL9WeIGXiHEYtREBwvckN1LvHUmmzVc6fllHwdm84 Veh8+40GybKw
VZ57tLO/r3wJTlQtqMzc19nf1/nxjrN5khlvOzunVgpBqcUr9ImqBRdK5Z8X c7MULsXcV9iw
ugrSyc4mp7Np0/Nzpd/D5nmygeOPYqVs0DV0pK3jcFvHkbYO15B4pK0j+Bh0 iX5La/L/7t9u
r895YAbn/PBzZ8xXbwxsXcaPvpDx3EMtV28MXO187ZP/+sJRzjk//MncX169 MXD1Rssz9ea/
a+VHX8g495OBqzcGrt44veqdZ37XHZDD/f/zl/U5OfWdA1ebn36Ag/Pg+N2/ 21Ayr2Xg6o2B
qy0PnesKvWIY/sJDxUyfg+ajvUBvF2alLzZmvveBE2g7tDvTMD1cKyjbCwBg q5wvdb7VZ+sL
FyJ80+vTJYPUebQlswQHjwPoPYdZ6coGVZXBm602VHsOoH/S2i+bdXNLd5+A n5AeM0GtdK1d
PTChPr+0ZPdBac543N5QYvQIHxwzRM2Evr5m29yZSvNSdaxJ4oUaO2pJNFeC p6oVfSA4zxCl
OJsKVqO5z7pWr729gnqCNxMMoxYiQ1Fvcuj0tbXSzKNz75PT1e4g2yrnT6sE AFP1x3/M1zub
YKouXiwJ2nPKVL19MQDol5lNz9vbCmfBZM7We0Mu9GCWHBO7G6bt9mRa2ANv zFkm0yz5BIA+
PROVedPQ3Fe+pKpcRZ5AO+jmoGv5kizp/HBbh/fcn8NtH/pSHS7NmFoKADk7 Ov/hqfSePcjZ
8eOlDBzoudCRs+NXSxk40o2P5ZQc/NPTDyDnsUf0DBxYurwUOy/8aXYHflU/ 9VeevDc4+AO+
HABIukkyPwF0X1DG1+dkodQ8lbd8ueWvX65SvbX94osv+K8PAthe/+am0nUv v/yKSoUEol9m
xu5eOHuakb4W0+fA3oPertOFK6rCt4K3veAbg1KLA3A2FViasmsRrumryleU vNHlBM7NXVE4
q373Ceh7Ts1L1+sR0KDOpnoVGTzZakS150hyLqi0yXFmOZ3wCimjUgN+1xu+ qwclXPJoYd6h
E1sXL2w7dLa+sBzoCREzX71mwl1gkKJUH2se8fRqY8fZVB+cZNhKUEqi7APB YqgIZqucv6Cw
2avRNLYXENAT/DMZVi1EhKLe1FBThd66GHXxAfk4m+rV4y3c2te5FSeqpmXk wa82PSimhIMu
V/Phf4UggPOpt05tPvyvwTkOuly+VDk7Tu97Uu5nnMmKizMOQHnOA0I8YQE5 AOh5u84vji+J
fBIUn2PZX/pexvGf3na3GSUtf6laFihtZeWL/uuDAKSPkjasrn5Zvdq86NMz X7O3PYrMR/MB
ZD+GVmfvOcySXynX2gpBedrs8q9aaNLn4KDzxLnTs4r1i/JO/77NKcsQ0KDt s0Yow7A4mwoW
tOS1d+7VS+MWcF6wBcscpj+H7+rB3y5+qn7n79uAg6fNxXrAGTKmM0TNhCLT 1tLqzF8b8ahb
qKxq7dcyLNr6gDf/5sda8rae6K9aGDJOcHuFy2QYtRB1InyYRp+eaau0StP+ oy023xwhKMQv
5jA4m6re7gUWbu07Um+Sl738UUwPXTfdeTnfyVu+MC/nO0Nud17Od4IP1023 33QyeILpOdPP
eOjw86//iXPOu23NhzfmLPX/9k8Hf5GzyrjUFydUnjh81uEN1wfF7/79T99y cr7o5S/aG3JO
ne8OOeHdVLruZz+r/tnPqv3XDYedIAMLV5Scrd95do5k6xnQbHnjlLRQGLYV glvQx3F7g8JO
UWt6/TIzdkplTc9+DAcPYY4+qEGhuSeMAI+F6zzaYoO05NfS6t+FtPdDBeoJ p2c/dvbgVrtc
vaFjqtdMaIp3oHSBb72sbWtNW9ixJhO6qkc4GP2R+kCwGCEES3/S2owfFLzd Gy5PRXsF4ctk
OLWgxHnBBulKfR3AebTFFt4YB+C56xjpI9YLt7ZXFyzISAOAwua+hXD2BM4y FsLZExQTMFV/
XBsiS306nl+e9jwAmHYc2RskuMIq/Pz6X9Y+W+P9+Pumg6q5+lJx7rPgAMn0 84R8t7rj56uz
7r0NANb/4/XvcmcXDv8k82ubIIes0XP4xQGW//yTX8AvB0C/ZtPGb+R+bVfO xvXgD3D+XWX8
d2fwZxbc9gwA5PzyxD49C9Zmku576aWXJLFfeuklrzYMvk8STPoc2E6bt0tV p58F2+7MjdMB
qLeCor388X6Fwua+fL2zye+7oKYHoE+HDXm10wHoDWh4b9bHegCKBp0OjT0h EGkmNX/ahZDG
jj6/dF6GJLCppNAkCbnPnrYgo9RTlkoNaDWO1BPql5lPPX+htG/6MDHVayYk +ietH6N4/rQM
+XPJ7/qxcEnwWFMmC1PV/kkiqQRFHwCC211FCQAAllT97uC05QUlhVC1JVXa SwU5kx3VmWHV
gpeqaRkNALC0vr1cD2xt7ynw6wB+GkkNfX5pSUbetN2mHUd8m38mrJOuFeaV Y1ee8w9/W4r6
d74f8WMoY8jBlv2J2VijJMqd8HhN2iFjuPlaXEmcEZc4kmgkRgInwYt3alPC 2BUmrQ+SB4hk
pW1rRt5r0qnHdCUIDSSBKhzTt4nvf+LdvWNbIhFVllR19lfFWwgiCUkCVahl sYwgCGI0kCok
CIJIDlVIC3cEQcQW3x3keEsSEtMjEbxnPRGw/bPqI1kEQYwcn1WYsDfUaYKs IGFbiiCSl1G7
biUIgkh+lGuFd93zYFzkIAgiQdhUuk7hHGQioHLb5IvPk8FdI0EQMeDQPx2Q TiaaHlC/gzzk
ujHGchAEkWhMKD1Aa4UEQRCkCgmCiArx3rJulAynCke/K9iwJHkNEsT4J2CQ 9u5Zo3mDlORB
g1WYYBvgEQQx1ugX5cHjEtX5QTNkD6zjiUgmyFo2wPPbnMy3j2q4Dc/8N506 sWeNd+vVE1Xa
t+YiCCK2TM9+TNpNzLeZosp2gwi0H0PtCJiQRKAKI90Ar39fYcPqmrZhNjzz 33Rq4dqNhQ2H
TgDSjmI/inyrB4IgYoLeMNd2rhe+zRTVtq9TJ5L99uKHBlXo2Qxw/ntm2Q94 4C5oxd69r16z
t8G3fQEWGzfgbNfxnlPYnSf9JiyotEk7CYTa8GyxccNr9jag7dDuDY+S302C SBjksdnbdbpw
hTz8Pbbe6t043RNSwTnVNEDiocEzzeg3wItgw7OFK0p+cPC4Ea8VriAHnASR QCxcUfJG1/EP
mucZ90LD9nX+RGsTzVgyuodpwm/KddzeYDJnL9aw25bfD8WSwupTq39wasdT sd7rjyCIiFjy
6NzS1ZWZ3ulaqO3rPMNZDh/xpoNjyyj9FYbdAE9lxyy1Dc/8Np3a++R06Bfl mZZi2XQQBJFQ
LDZuAOTZcajt6/T523fIW/f5tiEc4aaDY4pyx7u77nnwi8+dI3/hxtlUYMH2 0Vzq8Zq0nbMS
s7IIYtxjt7W2fXBye/2bo9IDSUjCebFuO7R7w8ZO0oMEQYwlKqrQ65piRNy9 4Wmct7WeH3EG
f/1r02Crnfw0E0RcGZ0eSD6UqnBT6bq4yEEQROIwAfWAUhVOQJeNBEEouHr5 zETz4qxUhVcv
n4mLHARBJBQTTRWQQ3+CIJRMQKuQ/BUSBEGQKiQIghg7VehozM1tdIxRYQRB EJFBViFBEASp
QoIgiOioQkdjrmCxyx/sFsFil8Jk/CbG/tNk77kvKk2hCYKID9FQhYaiirK6 /XYAgH1/XdlK
I2AoOsAlbFnFDfbQie2WmZ0VUsyu/Kb1pAwJgogD0ZkgG1fKutC+v8O6wQj4 2XqmOnScd4RK
6TjfgTqTFHNmcUtLZ8iYBEEQMSNKa4XGDdaO/XbY93fkLzcAjsbcmU35XZKt ZzWHT2u2dnEv
tcboCEQQBBEB0bptYlie37HfImtCADDLZ44jTS3+ET12nxxumJ3VEnYCTRAE EXuidgfZsDy/
ow4VRQYAMBRVZBXPFARBENZ3ZvmsQkPRLmuHKSDcWNvlCaIbJwRBxAkVL9bx FokgiDhD7yAT
BEFMRMhJF0EQKkw0VUBOugiCUEITZIIgiIkIqUKCIIjEUYXBXrzIrxdBJBR2 i/TMm9fjgMy4
GKpjqwpVq2xc1CNBjHfsFlOH9GbYuHwnLFqq0NGYq/ypUMFQdOCA9BD2cIEE QSQUjvMdyJpt
iLcYMSNqL94VHVi5X/G6SLDzLo8BGOCXy2cVdjbkqr10Ql68CCLO2C0zi1sk zym5jXZVF3zB
IzWpRm4UJ8jGWs75Lqz3riWoOe8CAEfj+uIsm+zBy88VTUtHxi7JgQOKfd66 yIsXQcQdY22X
1Sx5TjlQZFR1wacc10k2cqO9Vij5KVy5X1KHKs67ABhmZ6HOJEWo9Vt28Hhw MCzPN3u9dZEX
L4JINFRd8CnGdbKN3GirQqmO9q+Ul1YVzrtkjLVc1pfBN6NUIC9eBJE4hHTB FzSuk2rkRlEV
2i2CIKzHroCrDnLeBcDRaGl0AMZa3mU1q7h1dRxpavHOpsmLF0EkGqou+BTj Gkk2cqN4B3n/
Ss550L3gAOddctBsyB68Zjbl7/J90+IL7fIpU/LiRRCJREgXfIpxnWQjl5x0 EQShhN5BJgiC
mIiQky6CIFSYaKqAnHQRBKGEJsgEQRATEVKFBEEQpAoJgiBIFRIEQYBUIUEQ BEgVEgRBgFQh
QRAESBUSBEEg+BHrz659Ghc5CIJIHHSpfzXRVIFSFd5+x9063STt6T+79mmk SQiCIBINpSrU
6SZd/Ey8fB2uQdHlYm4GkYFxBkBkAuecMR3jzM34N2dOmn3f5OsD7ju/Lie5 eGVQZEJqSjyu
Y9RwzuMtwkRBZEK8RRgJydixk7RXx6WHKFUhgMvXcedU3eAUnWuIiVzgImdM 4OAiExhnIhNE
Ea4hdt45OPu+yZ8PuL1Jbn41WeRJqwpZUnaaZETkpArHiCTt1XHpISqq0DUo Dk7RMZGJoiCK
cDOBc169bdvmsgowQQTcIsAhpAgArn0pepNAhxTGheS8FcN1SdlpkpGU5Byf ydixk7RXx6WH
qKlCN5PsQbfI3SIAVG/bBuDVum0bn90sxREE6DgH8OVXQwBcLuYaYmAAIP9L OpJTamLMSMqO
nTwiz01POdsjBv8dMwFUVaHgdoNJi4OMvVxbI4VvfHYz55yDCxA4dNJP5FeD HICbQeQCg8DB
BTEppz9ITqmTEY6kNFWSsmMnlcjHzopz01MUfxfNVdFRseD/A1kIKXJjzfy/ AAAAAElFTkSu
QmCC
--------------020307060008090302050307--
Re: seeing the invisible [message #594553 is a reply to message #47983] |
Tue, 06 July 2004 15:07  |
> if (!visible)
I think a dashed border would be nicer than just cyan one.
Any idea how to do that in Swing?
thanx!
Marcus
Re: seeing the invisible [message #594741 is a reply to message #48134] |
Wed, 07 July 2004 10:32  |
I haven't tried it, but supposedly there is a tutorial/demo of a dashed
border for Swing here:
"Marcus Beyer" <mb@thomas-daily.de> wrote in message
news:ccet8j$8n2$2@eclipse.org...
> > if (!visible)
> thanx!
> Marcus
Re: seeing the invisible [message #594798 is a reply to message #48783] |
import java.awt.*;
import java.util.*;
* @param c
* @param visible
if (visible)
else
* set dashed border
return;
oldInsets.left / 2,
halfBorder);
Color color;
int thickness;
int dashWidth;
int dashHeight;
int thickness,
int dashWidth,
int dashHeight)
this.color = color;
Graphics g,
int x,
int y,
int width,
int height)
g.setColor (color);
int startPoint;
dashWidth,
thickness);
startPoint,
thickness,
dashHeight);
return false;
QmCC
Current Time: Mon Jul 14 04:47:55 EDT 2025
Powered by FUDForum. Page generated in 0.11201 seconds
