Home » Archived » BIRT » Setting Visibility at Runtime
Setting Visibility at Runtime [message #47962] Sun, 19 June 2005 09:13 Go to next message
Originally posted by: jainrahul_16.rediffmail.com
Hi Everyone,
I am trying to set a table invisible (if the corresponding query returns
no record), and display "No Records Found !" instead.
I tried using the 'visibility' option but I could not figure out how to
insert a tag in the design file at RUNTIME at the appropriate location
which would set the table invisible.
Any help would be greatly appreciated.
Thanks a lot
Rahul
Re: Setting Visibility at Runtime [message #48432 is a reply to message #47962] Mon, 20 June 2005 16:46 Go to previous messageGo to next message
I too would be interesting in information on how this might be
accomplished (though I haven't really looked into it at all) :D
Rahul Jain wrote:
> Hi Everyone,
> Thanks a lot
> Rahul
Re: Setting Visibility at Runtime [message #50122 is a reply to message #48432] Wed, 22 June 2005 23:56 Go to previous messageGo to next message
This use case has been thought of while designing the Table/List report item,.
one way of doing it would be
- Add a label element to the table header or footer, with text = "No records
found"
- Define the visibility rule on the lablel, hide in all views , with
expression= Total.count > 0
Let me know if this works.
--Rima Kanguri
> Rahul Jain wrote:
> > Hi Everyone,
> > Thanks a lot
> > Rahul
Re: Setting Visibility at Runtime [message #50214 is a reply to message #50122] Thu, 23 June 2005 02:27 Go to previous messageGo to next message
Originally posted by: juergen.schwarz.gefasoft.de
Rima Kanguri schrieb:
> found"
I tried this for the visibility of the table, but the Total.count seems
not to be recognized.
Re: Setting Visibility at Runtime [message #50752 is a reply to message #50214] Thu, 23 June 2005 15:04 Go to previous messageGo to next message
> > Hi,
> > found"
Juergen,
-- One minor correction above, the right expression syntax is Total.count() > 0,
-- Visibility of the table should work
-- Return type of Total.count() is numeric, looks like there is a bug, if the number
of records are 0, Total.count() returns null. I will log a bug in bugzilla.
--Rima
BIRT Committer.
Re: Setting Visibility at Runtime [message #51136 is a reply to message #50752] Fri, 24 June 2005 02:28 Go to previous messageGo to next message
Thanks a lot, this works!
How did you know the Total.count()? I could not find it in the list of
available object in the report designer.
>>>Hi,
>>>found"
> Juergen,
> --Rima
> BIRT Committer.
Re: Setting Visibility at Runtime [message #61306 is a reply to message #51136] Fri, 22 July 2005 20:06 Go to previous messageGo to next message
This works for Table/List but can we do something similar to Chart?
I keep getting this error message when there is no data:
There are errors on the report page:
Error1:Failed to render Chart
The dataset used by the Chart is invalid
-l.t.
Re: Setting Visibility at Runtime [message #61460 is a reply to message #61306] Mon, 25 July 2005 00:34 Go to previous message
Please log a bug in bugzilla.
Thanks.
--Rima
Previous Topic:report parameter of type date/time causes problem
Next Topic:"invalid design file" ?
Current Time: Mon Jul 14 04:16:45 EDT 2025
Powered by FUDForum. Page generated in 0.05579 seconds
