Home » Eclipse Projects » Subversive » Subversive is 'mutating' .svn files to higher revision, breaking other clients
Subversive is 'mutating' .svn files to higher revision, breaking other clients [message #47867] Thu, 25 June 2009 15:27 Go to next message
I am trying to setup a brand new Galileo environment. I am using
eclipse-jee-galileo-win32.zip and added:
- Subversive SVN Team Provider (Incubation) 0.7.8.I20090506-1500
- Subversive SVN Connectors 2.2.0.I20090505-1500
- JavaHL 1.5.4 Win32 Binaries 2.2.0.I20090505-1500
With this combination, I can connect to the SVN server at the Eclipse
Foundation.
However, the Foundation is running a v 1.4 server (r21228; see 'Powered by'
at the bottom of
http://dev.eclipse.org/svnroot/rt/org.eclipse.persistence/tr unk)
We are experiencing problems tunnelling svn+ssh thru our corporate
HTTP proxy/firewall - svn clients v1.5 and v1.6 experience hangs and
generally poor performance.
So, my 'outside-of-eclipse' SVN client is v1.4 based - however, updates
done 'inside-of-eclipse' result in:
Error: This client is too old to work with working copy
'C:\_eclipselink\trunk\dbws\org.eclipse.persistence.dbws\MET A-INF'; please
get a newer Subversion client
Is there any configuration to tell the provider/connector or native win32
binaries to leave the working copy at the 1.4-format?
Re: Subversive is 'mutating' .svn files to higher revision, breaking other clients [message #47897 is a reply to message #47867] Fri, 26 June 2009 03:45 Go to previous message
Hi Mike,
it is not good idea to mix SVN formats inside and outside Eclipse. I do not use JavaHL, but SVNKit
since it is pure java and independent from native libraries. And starting with Subversive 0.7.8,
only SVNKit 1.2.* is supported, which in turn supports SVN 1.5 and 1.6. Therefore, we have started
to upgrade our out-side-of-eclipse clients to SVN 1.5 to match this. Otherwise, we would have to
stay at an older version of Subversive (0.7.7) and corresponding SVNKit.
So either you downgrade to Subversive 0.7.7 and use related Polarion connectors or (what I would
suggest) you upgrade your local SVN client from 1.4. to 1.5. It would still work with a 1.4 server
as we do so. Then you could upgrade your complete working copy by doing "svn cleanup" in the head of
the working copy. The "format" file in the .svn sub-folders would then go from "8" (1.4) to "9" (1.5.).
Feel free to ask for further details if you need so. We still use Eclipse 3.3.2, so I cannot answer
3.4 or 3.5 related questions yet.
Cheers, Jörg
> Foundation.
> at the bottom of
> please get a newer Subversion client
> win32 binaries to leave the working copy at the 1.4-format?
Previous Topic:Error: unable connect...
Next Topic:New Merge dialog?
Current Time: Sat Jul 26 01:48:25 EDT 2025
Powered by FUDForum. Page generated in 0.03932 seconds
