Home » Eclipse Projects » GEF » Problems with Help
Problems with Help [message #47826] Thu, 05 December 2002 14:48 Go to next message
I have no Reference in a last few builds for both GEF and Draw2D. Anyone
with the same problems?
as
BTW, everything is OK with Developer's Guide in both cases.
Re: Problems with Help [message #48008 is a reply to message #47826] Thu, 05 December 2002 15:45 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
Which Eclipse version?
"Alex Selkov" <as@empproject.com> wrote in message
news:asoabo$6nk$1@rogue.oti.com...
> as
Re: Problems with Help [message #48068 is a reply to message #48008] Thu, 05 December 2002 18:45 Go to previous message
Latest build. 200212041234.
Another one problem with the latest Eclipse (starting from M3?) - NPE in
Properties. In all cases where getPropertyDescriptors() uses "new" such as
LogicDiagram. Reproduced by change in router property.
!ENTRY org.eclipse.ui 4 4 Dec 06, 2002 02:32:25.421
!MESSAGE Unhandled exception caught in event loop.
!ENTRY org.eclipse.ui 4 0 Dec 06, 2002 02:32:25.421
!MESSAGE java.lang.NullPointerException
!STACK 0
org.eclipse.ui.part.CellEditorActionHandler.removeCellEditor (CellEditorActio
nHandler.java:468)
org.eclipse.ui.views.properties.PropertySheetPage$3.cellEdit orDeactivated(Pr
opertySheetPage.java:185)
org.eclipse.ui.views.properties.PropertySheetViewer.fireCell EditorDeactivate
d(PropertySheetViewer.java:396)
org.eclipse.ui.views.properties.PropertySheetViewer.deactiva teCellEditor(Pro
pertySheetViewer.java:319)
org.eclipse.ui.views.properties.PropertySheetViewer.handleSe lect(PropertyShe
etViewer.java:549)
org.eclipse.ui.views.properties.PropertySheetViewer.access$6 (PropertySheetVi
ewer.java:545)
org.eclipse.ui.views.properties.PropertySheetViewer$3.widget Selected(Propert
ySheetViewer.java:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:87)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :77)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:825)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:850)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:834)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:6 41)
at org.eclipse.swt.custom.TableTree.onSelection(TableTree.java: 449)
at org.eclipse.swt.custom.TableTree$1.handleEvent(TableTree.jav a:95)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:1692)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :1410)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1405)
at org.eclipse.ui.internal.Workbench.run(Workbench.java:1388)
org.eclipse.core.internal.boot.InternalBootLoader.run(Intern alBootLoader.jav
a:841)
at org.eclipse.core.boot.BootLoader.run(BootLoader.java:462)
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl
..java:25)
at org.eclipse.core.launcher.Main.basicRun(Main.java:247)
at org.eclipse.core.launcher.Main.run(Main.java:703)
at org.eclipse.core.launcher.Main.main(Main.java:539)
"Randy Hudson" <hudsonr@us.eye-bee-em.com>
Previous Topic:How to limit edit part size for resizing?
Next Topic:Using SWT controls as Figure?
Current Time: Sat Jul 12 08:24:54 EDT 2025
Powered by FUDForum. Page generated in 0.04218 seconds
