Home » Eclipse Projects » Subversive » Share Project Wizard - Simple vrs. Advanced Mode
Share Project Wizard - Simple vrs. Advanced Mode [message #47780] Wed, 24 June 2009 18:33 Go to next message
is it possible to change the default in the Share Project Wizard to
"Advanced Mode" via a setting? I didn't find anything in the svn
preferences.
I believe the best way would be if the last selected value would be
remembered and re-used. Shall I open a bug report for this?
Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #48185 is a reply to message #47780] Fri, 03 July 2009 09:42 Go to previous messageGo to next message
Hello Lars,
It's not possible to change the default to advanced mode.
We consider that Share operation is quite rare and remembering mode options
will not give any effects for average user.
> preferences.
> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #48416 is a reply to message #48185] Sun, 05 July 2009 03:00 Go to previous messageGo to next message
Hi Igor,
thanks for the reply. I had a look at the coding
(SelectProjectNamePage.java) and I believe I could change this myself (I
will also submit a patch which can can then consider).
My problem is that I don't know how to use org.eclipse.team.svn.sources
to export / create the plug-ins. I'll post another question for this in
this newsgroup.
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
>> preferences.
>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #48595 is a reply to message #48185] Mon, 06 July 2009 17:26 Go to previous messageGo to next message
I posted https://bugs.eclipse.org/bugs/show_bug.cgi?id=282583
Igor Burilo wrote:
> Hello Lars,
>> preferences.
>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #48850 is a reply to message #48595] Wed, 08 July 2009 10:23 Go to previous messageGo to next message
Hello Lars,
Thanks a lot, we'll review it
> Igor Burilo wrote:
>> Hello Lars,
>> options will not give any effects for average user.
>>> Hi,
>>> preferences.
>>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #49147 is a reply to message #48850] Thu, 09 July 2009 14:53 Go to previous messageGo to next message
Hi Igor,
I'm not sure if this is interesting for you but I blogged over the
process of creating this patch: http://www.vogella.de/blog/?p=443
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
>> Igor Burilo wrote:
>>> Hello Lars,
>>>> Hi,
>>>> preferences.
>>>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #49613 is a reply to message #49147] Mon, 20 July 2009 06:17 Go to previous messageGo to next message
Hello Lars,
Thanks a lot for your attention to Subversive project. Of course,we're
interested in your work with Subversive. We think that such info can be
valuable to other people and in order not to loose it, we created Resources
page on Subversive web site(http://www.eclipse.org/subversive/resources.php)
where we added link to this article, of course if you don't mind :)
> Hi Igor,
> I'm not sure if this is interesting for you but I blogged over the process
> Best regards, Lars
> Igor Burilo wrote:
>> Hello Lars,
>>> Igor Burilo wrote:
>>>> Hello Lars,
>>>>> Hi,
>>>>> preferences.
>>>>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #49671 is a reply to message #49613] Mon, 20 July 2009 08:03 Go to previous messageGo to next message
Hi Igor,
thanks a lot, especially for applying (a modified version of) my patch.
Or course I'm happy that you added my article and blog entry at your
resource page.
From Bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=282583 it is not
clear to me if this patch will be released for Subversive for Eclipse
3.5 or only for a later version. Do you know this already?
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
>> Hi Igor,
>> Best regards, Lars
>> Igor Burilo wrote:
>>> Hello Lars,
>>>> Igor Burilo wrote:
>>>>> Hello Lars,
>>>>>> Hi,
>>>>>> preferences.
>>>>>> Best regards, Lars
Re: Share Project Wizard - Simple vrs. Advanced Mode [message #50076 is a reply to message #49671] Fri, 24 July 2009 03:45 Go to previous message
Hello Lars,
Only for later version.
> Hi Igor,
> resource page.
> clear to me if this patch will be released for Subversive for Eclipse 3.5
> Best regards, Lars
> Igor Burilo wrote:
>> Hello Lars,
>> Resources page on Subversive web
>> site(http://www.eclipse.org/subversive/resources.php) where we added link
>>> Hi Igor,
>>> Best regards, Lars
>>> Igor Burilo wrote:
>>>> Hello Lars,
>>>>> Igor Burilo wrote:
>>>>>> Hello Lars,
>>>>>>> Hi,
>>>>>>> preferences.
>>>>>>> Best regards, Lars
Previous Topic:Building a complete Range Difference
Next Topic:How to reconnect working copy
Current Time: Sun Jul 27 07:06:41 EDT 2025
Powered by FUDForum. Page generated in 0.05838 seconds
