Home » Eclipse Projects » GEF » line on figure and more
line on figure and more [message #47759] Thu, 05 December 2002 09:30 Go to next message
I want to draw simple lines (not even poly lines) on a figure and I
don't want to care about repainting them when dragging a figure to
another location. But simply line.setStart(), 2xline.addPoint() and
rectangle.add(line) does not work. How to achieve this?
Then there is ScrollPane with setVerticalScrollbar(). I created a
ScrollBar, called setSize on it and called
setVerticalScrollBar(ScrollBar) on ScrollPane. When I see the ScrollBar
the size change does not seem to have any effect.
Thank you,
Chris
Re: line on figure and more [message #47948 is a reply to message #47759] Thu, 05 December 2002 15:43 Go to previous messageGo to next message
Originally posted by: hudsonr.us.eye-bee-em.com
"Chris" <wibni@web.de> wrote in message news:3DEF62F1.3070808@web.de...
> Hello,
Use Graphics.drawLine(int, int, int, int); instead of a Figure just to draw
a line.
What did you want setSize() to acheive?
Re: line on figure and more [message #48158 is a reply to message #47948] Fri, 06 December 2002 04:18 Go to previous messageGo to next message
>>Hello,
> a line.
This line will not be a part of my figure and when I move my figure the
line won't follow.
Do I have to model my line as a part of the model hierarchy and create
an EditPart for it?
Well, I simply want a thinner scrollbar :)
Chris
Re: line on figure and more [message #48399 is a reply to message #48158] Fri, 06 December 2002 10:59 Go to previous message
"Chris" <wibni@web.de> wrote in message news:3DF06B64.4000907@web.de...
> >>Hello,
draw
> > a line.
> line won't follow.
> an EditPart for it?
The line will move if you paint it relative to the figures bounds:
class DiagonalLine extends Figure {
protected void paintFigure(Graphics g) {
g.drawLine(getBounds().getTopLeft(), getBounds().getBottomRight();
> Chris
Previous Topic:Naive question: can I have both a GEF editor and a property editor on the same model?
Next Topic:attaching label to connection and anchors
Current Time: Tue Jul 22 09:02:55 EDT 2025
Powered by FUDForum. Page generated in 0.03782 seconds
