Differences between connectors / preferred connector [message #47751] |
Wed, 24 June 2009 13:59  |
is there a place their the different connectors are described? Which one
is the recommended connectors which should be used?
In the update manager I see:
JavaHL (Version 1.5 and 1.6)
Native JavaHL (Version 1.5 and 1.6)
SVNKit (Version 1.2.2 and 1.5)
I also have one item "Subversive SVN Connectors". Will this install all
connectors?
Best regards, Lars
Re: Differences between connectors / preferred connector [message #48357 is a reply to message #48206] |
Sun, 05 July 2009 02:45  |
Hi Igor,
thank you for the information.
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
> I just created an issue about connectors on FAQ page, please see
> http://www.eclipse.org/subversive/documentation/faq.php#conn ectors.
> If you select only 'Subversive SVN Connectors' feature, it will not install
> all connectors. If you want to install the connector, you need to set it
> explicitly.
> There are following options:
> SVNKit:
> SVNKit 1.2.2 For SVN 1.5
> SVNKit 1.3.0 For SVN 1.6
> JavaHL:
> JavaHL 1.5.4 Win32 Binaries and Native JavaHL 1.5 For SVN 1.5
> JavaHL 1.6.0 Win32 Binaries and Native JavaHL 1.6 For SVN 1.6
> You have two features for JavaHL connector because the first one (Native
> JavaHL) is JavaHL wrapper and second one (JavaHL Win32) is JavaHL binaries
> specific to platform (in current case to Windows).
>> Hello,
>> connectors?
>> Best regards, Lars
FUDForum. Page generated in 0.04153 seconds
